Old 09-03-2014, 12:34 AM   #26
pimpston65
pimpston65's Avatar
Re: 327 fan setup
Originally Posted by pimpston65 View Post
i got this one from a guy claiming correct for L6 with ac
ive seen this style also and the uber rare modulated one thats in the chevy books for AC V8, a guy on ebay wanted $600 last yr i have a pic somewhere only ever seen one, every and it was from a vette
pimpston65 is offline   Reply With Quote
Old 09-03-2014, 02:02 AM   #27
B_Bob
Re: 327 fan setup
Originally Posted by Chevy1966 View Post
So is the 7-blade fan with a thermal clutch the ultimate solution for the best cooling (with A/C)? Although I understand how it works mechanically, guess I am not totally sure how the fan clutch affects the cooling. When the clutch heats up, the fan turns slower, right? So is the idea that too much airflow is a bad thing? I really want to thank everyone to some great replies to my post. PS: BBob, that's a good looking engine - is that in your ride now?
Wish it was mine. That's jdoisher's Maggie's Custom. If you haven't read that thread yet, I highly recommend it. Here's a link:
http://67-72chevytrucks.com/vboard/s...d.php?t=531177
I will do my best to copy it though!
B_Bob is offline   Reply With Quote
Old 09-03-2014, 04:37 PM   #28
Budman56
Budman56's Avatar
Re: 327 fan setup
That makes me sick to my stomach, did you see the photo of the fan on my truck the exact one you show in your photo, I through it away because I didn't want it at that time and was going with electric fans.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 09-03-2014, 04:43 PM   #29
60-66
60-66's Avatar
Re: 327 fan setup
Originally Posted by Budman56 View Post
That makes me sick stomach, did you see the photo of the on on my truck, I through it away because I didn't want it at that time and was going with electric fans.
Don't feel to bad Budman, its the Style of clutch that's so rare and a slightly different fan blade that made that combination Pimpston posted DIFFERENT than yours and so valuable. You did through away about $50.00 , not 600.00
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-03-2014, 06:53 PM   #30
AcampoDave
AcampoDave's Avatar
Re: 327 fan setup
Just because, he wanted 600 bucks doesn't mean he got it or that it's worth it.
AcampoDave is offline   Reply With Quote
Old 09-03-2014, 07:04 PM   #31
60-66
60-66's Avatar
Re: 327 fan setup
Very true but I've seen just the clutches used for that price. Just a select few that would spend for that piece, not something I need luckily
Old 09-03-2014, 07:31 PM   #32
AcampoDave
AcampoDave's Avatar
Re: 327 fan setup
Yeah, for some lucky guys, their 600 bucks only feels like my 60 bucks....I just put a vintage air on my truck and I currently run a stainless steel 26" flex fan with 6 blades. Now I wonder if perhaps I would've been better off with a thermo-clutch. I went with the flex fan because it looks very similar to the factory fans on Caddies from the 70's. I figured if it works on a 472 or a 500 big block it should be overkill for a 283 with air.
Old 09-03-2014, 07:59 PM   #33
yelmer
Re: 327 fan setup
The blade
yelmer is offline   Reply With Quote
Old 09-03-2014, 11:02 PM   #34
Budman56
Budman56's Avatar
Re: 327 fan setup
they look the same to me both have 5 blades both were flex fans and both had the same clutch. am I wrong?
MY 65 C20 BUILD
Old 09-04-2014, 12:18 AM   #35
pimpston65
pimpston65's Avatar
Re: 327 fan setup
the $600 clutch is for a 64 vette they only made a few, the deal is it has a selectable modulator on it, guess it make the clutch "active". i saw the same one in the 60's truck parts book 283 V8 with AC is what it calls for next to the bumper guards, i finally found one on ebay and offered $400 and the guy said its worth more, i gave him a piece of my mind about it being worthless if no one buys it, once it didnt sale i never saw it again... so they do exisit, just at what cost??? i got mine from a member on the 67-72 forum for less then a C-note,blades and all(painted) so im good...
Old 09-04-2014, 02:39 AM   #36
Chevy1966
Re: 327 fan setup
Originally Posted by yelmer View Post
The oct 67 chevrolet parts book lists 65 -66 series 10-30 c.a.c. H.d. Radiator 327 part 3883159 fan blade 2nd design also the clutch for the blade is part 3883158 serie 10 -30 w a.c. H.d rad 327 2nd design
Ok, I am overloaded now... I asked what time is it, and you explained how to build a watch! But it is all good info - thanks!!! So if you were me, would you track down these two parts for the fan and clutch as posted by Yelmer, or go with that 7-bladed beast? Really appreciate all the help! --Rob
66 Custom Camper 327 AC PS PB
66 C20 292
76 C25 Sierra Classic
76 C25 Sierra Grande
76 Camper Special
77 Sierra Grande
02 Suburban - the DD
Chevy1966 is offline   Reply With Quote
Old 09-04-2014, 09:23 AM   #37
60-66
60-66's Avatar
Re: 327 fan setup
Quote "I'm trying to take the setup back to the way it came from the factory. thanks - Rob "
This was your original statement that prompted the guys who like learning about original to chime in. I know I learned some things as I did a couple hours research on this fan blade. Try this guy for a great deal .
http://67-72chevytrucks.com/vboard/s...ght=clutch+fan
Old 09-04-2014, 10:19 AM   #38
pimpston65
pimpston65's Avatar
Re: 327 fan setup
hey 60-66 thats where i got my setup from, item was spot on!!!
