#26 |
So,, what else you got???
![]() Join Date: May 2010
Re: End of summer,, day two....
Hey Bill. I had another member ask me something about the lamps condition. If you do not care, let me give him first shot at it. Thanks, Fred.
Our paypal is specialtyretail@yahoo.com Please DO NOTsend paypal funds as a gift, right is right. Thanks.... Sorry, we CANNOT ship larger parts. Thanks.
#27 |
![]() Join Date: Oct 2013
#28 |
Hey Jody. One of the legs is broken off of one side of the mounting clips. I cannot get a good pic, keeps coming out fuzzy. One side, clip is good, other side, clip is missing a leg. Thanks, Fred.
#29 | |
Please let me know on the exhaust hanger brackets (I sent you in PM) if you get a chance.
1967 GMC SWB 383 Stroker w/Saginaw 4sp 1979 Chev C30 Scottsdale Flatbed 350 4sp 2000 Chev 3500 Flatbed 454 Automatic 1978 GMC 6500 Flatbed Dump 366 5sp + 2sp 1965 Chev K10 LWB 230 4sp 1985 Chev K30 Flatbed 350 4sp |
#30 |
Here are a couple of pics. They did not come out too good. You can blow through them, no problem. Thanks, Fred.
#31 |
Good deal. I did not want to mislead anyone, especially over truck parts. Thanks, Fred.
#32 |
I'll take a pair of fender braces, and the washer nozzles. Thanks.
#33 |
Consider them yours. Thanks, Fred.
#34 |
Pmt sent
#35 |
![]() Join Date: May 2012
Fred, you wouldn't have any old engine wiring harnesses laying around? I looking for one for my 71, bad ones okay, I need to patch a couple of wires. It's the lower one on the firewall that runs up to the lights and alternator
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68 |
#36 |
No sure if it was you that posted the lower alternator bracket for sale, Ill take it if you still have it.
Thanks again! |
#37 |
Right now I just have a lower power steering pump bracket listed. I will look for an alternator bracket. Is it for the short or long pump? Mounts on drivers or passenger side? Thanks, Fred.
#38 |
Fred, I will take the A/C stuff as long as the door is not broken. You should see the door panels I got from you, they look great! Let me know about the A/C stuff, if it is a go, I will send you a paypal.
Mike |
#39 |
Let me look & see what I can find. You are needing the engine harness, not the headlight & voltage regulator harness correct? Thanks, Fred.
#40 |
Going out Thursday. Thanks, Fred.
#41 |
Hey Mike. If you mean the flapper, yes, it works with the lever. Glad the door panels worked out for you, I had no use for them and was happy to see someone be able to put them back in service. Thanks, Fred.
#42 |
Paypal is on the way.
Thanks, Mike |
#43 |
Hey Mike. I should be able to get them sent out Thursday. Thanks, Fred.
#44 |
Hey Fred,
What kind of deal can you make me on sending those pulleys my way? Are they in good shape with no nicks,bends and gouges especially where the belt rides? If you say they are all good, I'm interested. Thanks much again, Bob |
#45 |
Hey Bob. I will go over them real good this evening and verify there are no issues. They were removed from a running, driving truck, it had just rusted plumb off the frame. Thanks, Fred.
#46 |
short pump mounted to driver side head THANKS!
#47 |
I will sort through my stuff & see what I have. Thanks, Fred.
#48 |
Thanks appreciate it!
#49 |
Fred, what I'm having problems with now is my alternator wiring The po changed it over to a one wire but he some other wires in that harness, also the wire from the battery block on the fender to the firewall. It's the one that has the two rubber connects that hold fuses. I have the two female connectors but not the two ends that go the the block and the fuse box
mike
#50 |
OK Fred,thanks much. Let me know on those pulleys what you find out.
Bob |
