Old 10-13-2015, 09:43 AM   #26
LVPhotos
LVPhotos's Avatar
Re: 62' c10 V8 motor mount help
I didn't have to. But seams alot did.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-14-2015, 12:25 AM   #27
Captainfab
60-66 Nut
I agree that you shouldn't have to. Worst case, I don't see the need for a spacer more than say 1/4". The reason that I recommend the '67-'72 small block frame brackets is that they fit the '60-'62 frames quite nicely. Much better than the '63-'66 or '67-'72 230/250 I6 brackets.
Old 10-14-2015, 02:55 PM   #28
markeb01
Senior Enthusiast
markeb01's Avatar
I needed the 1" spacers on mine. They are shown in the following thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=369663
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 10-14-2015, 04:16 PM   #29
Brad54
Brad54's Avatar
So if I'm reading all this correctly, it breaks down like this:
'60-'62 Frame
w/ Original torsion bar crossmember: factory '67-'72 small block mounts, bolt-on, no spacers needed.
'60-'62 Frame
w/ Later '63-up coil spring crossmember: '67-'72 small block mounts, require spacer blocks between top of frame and engine mount stand.
Is that correct?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 10-14-2015, 09:20 PM   #30
markeb01
Senior Enthusiast
markeb01's Avatar
I can only speak for my own truck, and I needed the spacers both for the original crossmember and again when I swapped in the 1973 front suspension.
Old 10-14-2015, 10:04 PM   #31
padresag
http://www.persh.org/pickup/perches.htm
this even shows some orig sbc side mounts for 60/62
and the next link is for rear trans c/member
http://www.persh.org/pickup/700R4.htm
ron
padresag is offline   Reply With Quote
Old 10-15-2015, 11:03 AM   #32
62step
Thanks for the info guys! I'm still searching for that other motor mount, but might just buy some new ones, although, I don't think anyone makes a new set do they?
Padresag, I will have to look at those links when I get home since I'm at work, they are blocked
62step is offline   Reply With Quote
