Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-22-2014, 07:48 PM   #26
adammoore
Re: Swapping manual to power seats
Ok. Do you think I have a bad seat? I looked and the passenger seat has only two wires and they are red with a white line and black wire
adammoore is offline   Reply With Quote
Old 09-22-2014, 07:51 PM   #27
adammoore
Ok. Do you think I have a bad seat? I looked at the passenger seat and it only has two wires and they are red with a white line and black
Old 09-22-2014, 08:16 PM   #28
vidman
vidman's Avatar
My passenger seat had 6 or 8 wires and it worked fine, but the drivers had about 200 wires. I was told by 2 good chevy mechanics that the only way to get them to work was to rewire the whole assembly and bypass all the computer stuff. so it was a lot easier for me to bring them back and look for a non memory set
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 09-23-2014, 10:04 PM   #29
Gonepostal
Gonepostal's Avatar
I just took the lrg red hook to 12v + and lrg black to 12v- then started adding wires to the + side till the seat moved then started removing other wires till it stopped moving and those are the ones you need for your seat. I used a jump box for testing. All functions work and they are memory seats that I have.
US Army Bomb Squad 83-96
There is no problem that a suitable amount of explosives cannot solve
Gonepostal is offline   Reply With Quote
Old 09-24-2014, 12:45 PM   #30
_Ogre
_Ogre's Avatar
probably not a bad seat, it's just going to take some work to get it operational
if that is above your skill set then try to take it back
realistically you have 3 motors with 2 wires each
figure out how to hook up 2 wires to a motor to test it
shop air compressor timer
Old 09-29-2014, 01:40 AM   #31
adammoore
I guess I had a bad seat! They let me bring it back and they had a lot more seats come in and we found one that would plug right into my truck and worked fine.
I would like to thank everyone for y'all's help!!!
Adam
Old 03-03-2015, 02:01 PM   #32
RUN GMC
RUN GMC's Avatar
Did you find your seats locally in North Alabama......curious Im looking to upgrade seat in my 87 GMC.........thanks......
RUN GMC is offline   Reply With Quote
Old 03-04-2015, 06:06 AM   #33
adammoore
I got them at:
Peek Auto Parts
(256) 734-0675
1937 2nd Ave SW, Cullman Alabama 35055
Old 03-04-2015, 07:52 AM   #34
RUN GMC
RUN GMC's Avatar
Ok.....thanks I know where its at....I have to go to Hanceville next week........
Old 03-16-2015, 01:26 PM   #35
Jim53066
Jim53066's Avatar
I realize that the OP has his issue worked out, but I thought I would post my rendition of wiring the same type seat.
I used 99 Cadillac seats that also had the memory position sensors. I eliminated the memory wiring part and wired them with new switches. I used one rocker switch for each motor, with the switch reversing the polarity of the motors.
It actually worked well, and I was able to fit the switches where the openings of the old switches went.
Jim
Jim53066 is offline   Reply With Quote
electrical, power seats, seat, wiring diagrams
