Old 08-20-2019, 08:25 PM   #26
Seanext
Re: DIY seat cover
I just bought a set of bucket seats and the passenger side foam is great but the driver side bottom in rough shape. Can it be repaired or just get new foam bottom?
Seanext is offline   Reply With Quote
Old 08-21-2019, 03:33 PM   #27
landarts
landarts
Re: DIY seat cover
I have done this both ways. I replaced buddy bucket seat foam top and bottom, makes them like brand new. Also makes you sit higher and stiff. I have repaired several bench seats drivers side foam. I used a electric knife like you cut the turkey with. Cut out shapes that are easy to replicated with the replacement foam, like squares and rectangles. Used a spray adhesive to attach new foam, then carve to fit contour. The trick is getting foam that is the right density.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-21-2019, 08:16 PM   #28
Seanext
Re: DIY seat cover
Where can you find the correct foam and what density foam ddi you use?
Old 08-21-2019, 08:30 PM   #29
Astro-Balls
Astro-Balls's Avatar
Re: DIY seat cover
American Cushion Industries sells the Best foam,
http://www.americancushionind.net
If you are in Northern California I can do your seats for you.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
