#26 |
Re: Easy Green
Here is my repair panel. If I were to use this whole piece would I have to do anymore to ac vent area than just cut whole for it? I haven't looked real close at mine yet to see if there are any factory brackets.
1972 K5 Auto 4x4 factory air 2007 Silverado extended cab Z71 |
#27 |
Registered 1971 K5
Re: Easy Green
Just the cut out for the ac vent to slide in. Behind the dash you have two holes where the studs from the vent will slide into and tighten with nuts.
#28 |
Re: Easy Green
Here is a better picture of the radio area. I think after starring at it for awhile I have worked up the courage to use entire repair panel. I think there will less welding and an overall smoother finish. I didn't realize how easy it was going to be to take out the AC vent. and with no brackets should be easy enough.
one of the POs left the original rubber floor mat under carpet and after removing that I found a paper like material glued to the floor. Is this factory or did someone come in later and put that in? I scrapped off all of the loose paper and I guess I will leave the rest. I found what looks to be some factory markings on the passenger side under seat. I guess the glue for the paper didn't stick to makings. Cool! I am overall very happy with what I found under everything. The only serious rust I found was in the lower passenger side kick panel and a small spot under where the door sill plates would sit. everything on the floor is surface and will clean up nicely. Ill take out the rear carpet soon so hopefully no surprises there. This blazer has an auxiliary gas tank that sits right under the rear seat under the floor. I am thinking about taking it out and changing everything back to factory. It has everything from the tank to hoses to valve to filler neck and a switch so fuel gauge will read it while in use. I'm not sure of brand and its not a saddle tank so not sure if anyone would want it. I personally like it better because it doesn't take up any interior space. Not sure of number of gallons it will hold either. Someone let me know if there is a market for it. I will take some pictures.
#29 |
Re: Easy Green
Got the old center dash cut. And the new repair pieces sitting in place. Was scared to death to cut it but it guess anything I do will be an improvement.
#30 |
Re: Easy Green
Dash
#31 |
Re: Easy Green
I also bought all new parchment upholstery. Carpet is next to buy and a few minor interior parts and I should have everything I need to finish interior.
#32 |
Re: Easy Green
All the interior can do is get better, nice to have the parts ahead of time, keep posting, interesting job.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#33 |
Re: Easy Green
Got center AC vent hole cut and put into place. Stuck a couple things in their holes. Surprised myself, it doesn't look half bad. Ready to weld. Have to get welder ready, I ran out of welding gas last time I used it.
#34 |
Re: Easy Green
Sure makes the most sense welding the whole piece in, have seen a few just try to fix the radio area and really hard to make it look like it wasn't repaired.
#35 |
Re: Easy Green
Just because I'm looking what did you decide on the brush guard ?
Bought this thing bone stock with intentions to just add a lift and tires and the next thing I knew it was on my garage floor in a million pieces. Sometimes the best laid plans........
#36 |
Re: Easy Green
Plan on hanging on to it for now. I mostly likely won't put it back on right away. Hate to cover up brand new inner and out grill. I let you know if I change my mind.
#37 |
Re: Easy Green
Ok. Thanks, and just for the sake of it what would you ask for it
#38 |
Re: Easy Green
I don't even know. It is in near perfect condition. If I had to put a number on it it would be in the $250 range. Like I said I have no intentions of selling a this point.
#39 |
Re: Easy Green
Dwayne, here is the screw I am talking about. The other screw is drywall screw to give a comparable.
#40 |
Re: Easy Green
1 more
#41 |
Re: Easy Green
It has been awhile and the Blazer has done alot of sitting. I dropped the blazer off today to have all of the interior metal painted. He is going to repair the door speakers holes too. Should have it back in January. I'll hopefully post some progress pictures of paint work.
#42 |
Re: Easy Green
Dash getting close to paint!
#43 |
Re: Easy Green
One door repaired and the next getting close. Body guy is doing a great job. Wish I had enough to get entire thing painted. I guess Ill settle for just interior at this point. But at least Ill be able to put all of my interior back in.
#44 |
Re: Easy Green
Dash is done! He did a great job!! All new a/c vent and defrost hoses. New glove box liner. New dash cluster, dash pad, ignition bezel. He painted rear wheel tubs. I will not be putting carpet on those. He still has to paint the doors but everything is looking great for this interior makeover. Man I wish I was getting whole thing painted.
#45 |
Re: Easy Green
Another. I have a new steering wheel to put on.
#46 |
Re: Easy Green
Tubs
#47 |
Re: Easy Green
1 more
#48 |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: Easy Green
Dash came out really nice!!!
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#49 |
Re: Easy Green
Nice find and great job on getting the interior in shape!
#50 |
Re: Easy Green
The blazer is back home from the painting part of the interior make over. Sorry for multiple post for these pictures but it won't let me post but one at a time.
| Bookmarks |
