Old 09-28-2014, 01:04 PM   #26
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Would y'all recommend the Petronix ignitior ?
Okay, I bought the petronix kit, how do I install it in the distributor and wire it through the distributor? I tried removing the wire grommet that the wire goes to the coil from the distributor but it won't come out...clueless
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 09-29-2014, 01:09 PM   #27
_Ogre
_Ogre's Avatar
i'd suggest reading and following the instructions that came with the unit
shop air compressor timer
Old 09-29-2014, 01:12 PM   #28
SCHRUMGMC
SCHRUMGMC's Avatar
I found out how to install it, only thing I am awaiting is changing out distributors
1971 GMC Sierra
1959 GMC 100
Old 09-29-2014, 01:19 PM   #29
OrrieG
OrrieG's Avatar
I mis posted this in your chroming thread.
It is link to dist r&r instructions.
http://speedprint.com/deves50/doc/enginetiming.pdf
Make sure BEFORE your remove it the engine is at #1 cylinder top dead center with the rotor pointing at the #1 wire connector on the cap. Take a picture or make a detailed drawing of the distributor orientation to the block, you do not want to be a tooth off when you reinstall the new distributor. Then follow the instructions listed above. DO NOT turn the engine over until the new dist. is installed.
OrrieG is offline   Reply With Quote
Old 09-29-2014, 01:25 PM   #30
SCHRUMGMC
SCHRUMGMC's Avatar
I read that Orrie, thanks for the info but I am not touching it until I get someone who knows what they're doing Lol
1971 GMC Sierra
1959 GMC 100
Old 09-29-2014, 03:00 PM   #31
Rude Dude
Rude Dude's Avatar
Cheap insurance, do not forget to carry the old points and condenser in the truck just incase the module fails odd things happen at the most unpredictable time or place, murphys law.
Rude Dude is offline   Reply With Quote
Old 09-29-2014, 06:37 PM   #32
SCHRUMGMC
SCHRUMGMC's Avatar
We had to rip the thing that the coil wire goes to grommet to pieces to get it out of there.. Don't think points could ever go back in... oh well
1971 GMC Sierra
1959 GMC 100
Old 09-30-2014, 04:46 AM   #33
Old Crow
Old Crow's Avatar
It's just a grommet. You can get an assortment at any auto parts store.
Only Pertronix unit I've ever seen to fail in person was caused by leaving the key on with the engine off. You can burn up a points setup the same way.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
