#26 | |
Re: rear sway bar or not?
#27 | |
Old member
![]() Quote:
Huh! Hell boy is fake auto crossing! I hear you! ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#28 | |
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
#29 | |
![]() Join Date: Nov 2007
#30 |
Anybody have any pics of how these above-mentioned sway bars install? The one cat mentioned how low to the ground it was. That would be the only thing to concern me.
In general- a sway bar on both ends is a big yes. There's a reason almost every vehicle produced after 90s, or even most from 80s, comes from the factory with front and rear sway bars. Less floppy body roll is safer in everyday, "oh crap" type maneuvers. A stiffer rear sway bar will increase oversteer tendancy. So rwd vehicles generally need a stiffer bar in front and a little thinner, weaker in rear. While a fwd can be happier with real stiff rear sway bar. I'm just getting going on my truck and not sure what bars to source for it. |
#31 |
Thanks! I like the no limit mounting. That post went up while I was typing ha
#32 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#33 |
You should check out their panhard bar and shock relocation kit as well. I have the setup and will be doing the sway bar as well.. this pic is from mock up...
#34 |
CPP rear bar
#35 |
Another
#36 |
this is mine
#37 |
![]() Join Date: Apr 2012
http://www.vikingspeedshop.com/the-t...out-sway-bars/I found this pretty informative on sway bars.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
