10-13-2014, 12:29 AM | #26 |
60-66 Nut
Re: Narrowing a 68/newer 3/4 ton rear axle, anyone done it?
Why scrap it? Why not put it on CL or some other classifieds. Even if you sell it for $50.00. You'd be lucky to get $10.00 out of it for scrap.
Not all full floater 14 bolts are dually differentials. They were used on C/K20/2500's as well.
10-13-2014, 01:36 AM | #27 |
I can toss it CL and see if I can get something for it. You guys are right, a few bucks is better than nothing.
I've been searching CL tonight for K2500 suburban's. See if I can find one being parted out and give that a try. If I pop a wheel now I know what I'm looking for. Hopefully... Matt |
10-13-2014, 01:42 AM | #28 | |
And yes, I've driven it a few miles. The clutch was a little week and so were the brakes. I guess after sitting 30 years you have to expect that. I replaced the dizzy last week with an HEI, new plugs, wires..that made a big difference. I replaced the manifold gaskets, had a healthy leak. The oil lines leading to the oil filter on the manifold were leaking, at least one was, so I ordered up new ones. I've also got a new master cylinder and slave coming this week. After driving it a few feet I knew I wanted to gear it up. The thing is geared like a grain truck. Matt |
10-13-2014, 03:37 PM | #29 |
buckroseau- Here's a post I made about axle widths awhile ago. Read the response #4.
http://67-72chevytrucks.com/vboard/s...d.php?t=620030
It only has original paint once |
10-13-2014, 03:59 PM | #30 |
I ended up buying another axle this morning. It was in a running 97 c3500. This time I had the seller pull the wheels so I could measure. It was 65.625 exactly. Paid a little more but at least I have one now. Heading back over to the guys place tomorrow after work with my torch to cut it out. I'll take a few pics tomorrow night and post them up. This axle is not a full floater.
10-13-2014, 04:50 PM | #31 | |
Great, It sounds like you found what you needed.
10-13-2014, 10:48 PM | #32 |
It would seem so? I will take a few pics of the axle when I get it home tomorrow night.
Few pics from tonight. New oil lines showed up today so decided to throw those on real quick. When I replaced the exhaust manifold gasket and tipped the manifold away from the engine the old, dried up lines cracked and broke. Got the HEI tweeked a bit as well. This thing starts like it's fuel injected now. Matt |
10-14-2014, 11:14 PM | #33 |
Went and got the axle later this afternoon. $200 bucks of goodness. I cut the existing mounts off, didn't get a pic of that. I think tomorrow I'm going to drop it off at the sandblaster and get it cleaned up prior to working on it.
Matt Last edited by buckroseau; 10-14-2014 at 11:23 PM. |
10-14-2014, 11:42 PM | #34 |
That is actually a full floating 10.5" 14 bolt, not the 9.5" semi floating version.
I might have to see about getting one... |
10-14-2014, 11:44 PM | #35 |
Was it a dually or a SRW truck?
10-14-2014, 11:50 PM | #36 |
10-15-2014, 01:08 AM | #37 |
60-66 Nut
If you need a set of trailing arm mounts, let me know. I make them specifically for the larger axle tubes on the 14 bolts.
10-15-2014, 11:29 AM | #38 | |
I ended up torching the brackets off last night and also removing the drums and brake parts. Flap disc'd the axle smooth. Just dropped it off at the sandblaster a few minutes ago. Just easier to work with clean metal. Matt |
10-20-2014, 09:28 PM | #39 |
Picked up the axle from the sandblaster today. Not building a show truck by any means but much nicer to work and weld clean metal.
When I got home tonight I shot a heavy coat of ppg dp90 keep it from rusting. I left the axle tube bare where I need to weld in brackets. Matt |
10-21-2014, 12:56 AM | #40 |
60-66 Nut
Looks good
I agree on the blasting to get it cleaned up and nice to weld on. That's how I do it when possible.
10-21-2014, 01:20 AM | #41 |
Looks good.
10-21-2014, 09:34 AM | #42 |
Looking real good buckroseau! I have the same truck ('62 C20 w/235) with the same gearing (Owner's Guide says either 4:57 or 5:14). The first time I took it out, I was stunned that I can only move about 10 feet in 1st gear before I have to shift! Probably great for hauling stuff, but not highway cruising (I have yet to leave my neighborhood going over 40mph).
Where did you get the oil filter lines? I need to order some as well. Keep an eye on your clutch hose. Mine leaked, and I think this is common. I ordered my new line from Inline Tube (part no: CTH60001). I ordered from them about a month ago and the line needed a little bit of persuasion to get in, but it's solid once in place. It looks like they changed their search function since I ordered from them, and now I can't locate the page it was on. You may have to call/email them for info. I'm subscribing to this one, as I plan to do the same kind of axle swap.
Michael - 1962 C20 LB stepside (project thread) - sold - 1963 Chevy C10 LB stepside (donor) - 1963 Chevy C10 LB Custom flatbed (project thread) - sold - 1979 K20 LB fleetside (project thread) Favorite exchange on the board so far: ol_Curt: "Jason, do you have power steering?" jason65: "No, but I lift weights." |
10-21-2014, 11:19 PM | #43 |
Managed to get the old axle out tonight. I will say it didn't come out easy. But with help of the torch and the BFH it eventually came out.
Need to fab up a jig now to mark a few things. Plan on cutting the pan hard bracket off and welding that onto the new axle as well. Question on the those 2 swing arm. Are those flat stock pieces of metal that are kinda peeling away factory? I'm sure they are, but just wanted to make sure. I ordered a reinforcement kit and I'm wondering those should be cut off? Matt Last edited by buckroseau; 10-21-2014 at 11:26 PM. |
10-21-2014, 11:33 PM | #44 | |
Link to the oil lines I bought off the ebay. http://www.ebay.com/itm/281431999623...%3AMEBIDX%3AIT |
10-22-2014, 12:40 AM | #45 |
My '62 C20 has those metal strips on the trailing arms too. It's funny, because I was also wondering if they were factory.
I'm glad to hear someone else heard the same howling at 40mph! I thought I was gonna have one more thing to dig into.
10-22-2014, 01:32 AM | #46 |
60-66 Nut
The C20's had those extra reinforcements on the trailing arms. The bad part about those is that they trap dirt and moisture and rust away both parts.
10-22-2014, 10:39 PM | #47 |
Started fabbing up the jig tonight to transfer the mount locations over to the new axle. Also marked the pan hard bracket location and brake tab location.
Question: anyone know if speedway or anyone else makes a T or hose that goes from the 3/16 brake line to metric? |
10-23-2014, 12:46 AM | #48 |
60-66 Nut
You can buy Metric to SAE line adapter fittings. They are Edelmann #271300 or Weatherhead #1442.
10-23-2014, 10:53 PM | #49 |
Few pics from tonight. Copying a few other people on other threads to do the axle swap. Welded up a pinion angle bracket. Also used the 3/4" washer trick in the mounting hole. Used the tractor to move the old axle out and new axle in. Lot easier than doing it by hand.
Matt |
10-23-2014, 10:59 PM | #50 |
Few more pics. I got Captainfab's axle brackets tacked in the with the welder. Few side pics of the pinion angle. Sure seems steep, but that's what the other axle angle was I guess.
Matt |
