Old 11-01-2014, 01:20 AM   #26
Captainfab
60-66 Nut
Re: Road Draft Tube Conversion
Bump for HumphreyMurdoc
Old 12-14-2015, 05:42 PM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Nice thread.
66 C20 Service Truck:
Old 03-28-2016, 01:47 PM   #28
Figuarus
Figuarus's Avatar
Update : Possible issue
So I goaded my dad into driving my truck to Los Angeles instead of taking his Honda, and while down there, I noticed something.
On the back of the manifold, there is a vacuum port between the carb and the distributor. I previously had the pcv line from the road draft tube connected there.
I had noticed that the driver side valve cover breather is allowing oil droplets to land on the valve cover and film it over. I thought this to be unusual since the PCV valve and line should pull air IN through the breather, not allow it to film over with oil.
I pulled it the other day to inspect it thinking that the line was blocked or something, and noticed oil in the line. Nothing creamy, but there was lots of oil residue.
I decided to move the line to the front vacuum port on the front of the quadrajet, and after driving about 700 miles, i took the hose off, and saw more oil in the line.
Could this be because of a missing baffle in the valley, or is there something else going on here?
I remember seeing a thread a long while back where someone filled a small soup can with steel wool, and had that act as a catch can for extra oil. I'm assuming that it was done due to blow-by issues, but I cannot for the life of me find the thread.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 03-28-2016, 02:33 PM   #29
65chevysub
65chevysub's Avatar
Sorry to break in on this thread. I have the ventilator that came with my 283 but it's not in the engine. My pcv is hooked up to the adapter and going to my carb. My question is, should the ventilator be mounted in the engine for everything to work properly, or will it work without the ventilator?_ I have the same problem of oil all over the back and botton of the engine) Is there a gasket for the block adapter?
65chevysub is offline   Reply With Quote
Old 03-28-2016, 11:36 PM   #30
Captainfab
60-66 Nut
The canister that sits in the lifter valley and connected to the road draft port is there to help keep oil from being ejected/sucked thru that port. If your engine has a bit of blowby, there is only so much you can do to keep the outside of the engine clean of oil.
