#26 |
Re: New doors
Glued the weather stripping round one of the doors today
yoshi's 49 project |
#27 |
Re: New doors
Can anyone tell me how the outer window weather seal rubber strip is held in? Thanks
#28 |
Re: New doors
Let me know if you need something I didn't list
Overall length 19 3/4" As measured from outside, back of channel is 3/4" wide sides of channel are 1/2" tall tops of channel sides are cut at approx 45* hole in top is slotted, 1/2" in length, beginning 3 1/2" from the top of channel rectangular hole in middle, back of channel begins 9 3/8" from top of channel and is 1 1/4" long stepped bracket riveted to the bottom is 2 1/4" tall 3/4" x 1/2" x 3/4" the holes punched in the stepped bracket are 1 5/16" center to center
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 |
#29 |
Re: New doors
Thanks Bret, but it looks like they changed the design in 1951, my one is pre 51. Many thanks though
#30 |
![]() Join Date: Mar 2011
Re: New doors
Yoshi, not sure but I think this is what you are looking for. If it is you just remove the old rubber and slide in the new. May have to remove the old rubber with a screwdriver. Lube up the new rubber and install. Hope this helps...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#31 |
Re: New doors
Thanks Oldman, I have new doors on my project so no old rubber to remove. I'm not sure that I even have the Chanel for the rubber to slide into or is it part of the reveal moulding?
#32 |
Re: New doors
The outside rubber slides into a slot in the door inside under the window opening. The inside felt staples to the inside window moulding.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#33 |
Re: New doors
Like Brian said, it should be part of the door. You may have to remove your glass to be able to see the channel, and install the rubber...Jim
#34 |
Re: New doors
There's no glass in yet, I think I have to bend the channel up a little to hold the rubber in. I've made the window channels-
#35 |
Re: New doors
Had a couple of pieces of galvanised steel folded up then i made up a couple of the window channels that im missing
#36 |
Re: New doors
Those are some nice pieces you made up..Jim
#37 |
Re: New doors
This look right?
#38 |
Re: New doors
I can't get it to go in the channel 1" from the hinge end
#39 |
Re: New doors
I've spent a total of 3hrs on this door, I've turned the rubber round, I've hit it with a hammer. If you thought hanging a door is stressful! I did the other door in 30 mins. I just can't get the last 1/2" to go in
#40 |
Re: New doors
I can't make out exactly what any of that looks like, you need way closer photos. There is a slot in the channel about 1/4 of the way forward from the rear as I remember. Here are some shots of one of my doors. You tuck it in from one side then into the other side. Then you fold up the flap to hold it from moving.
Brian ![]() ![]() ![]()
#41 |
Re: New doors
Close up at hinge side
#42 |
Re: New doors
Close up of where the tab is
#43 |
Re: New doors
I can't make out anything like mine has, does that door even have the slotted channel mine does?
Brian
#44 |
Re: New doors
For some reason both pics are upside down
#45 |
Re: New doors
The rubber is suppose to slide in on a round "rope" like end right into the slot which is shaped like pipe split open.
Brian
#46 |
Re: New doors
This is what the cross section of the rubber looks like and the metal is a tube like piece that the rubber slips into.
Brian ![]()
#47 |
![]() Join Date: Aug 2010
Re: New doors
When aligning doors (fitting) it makes a big difference if the door is fully loaded ( glass, reg, latches, etc.) on how they hang.
The door on my '57 fit great nice gaps all around then I pulled the glass, etc. out to install Altman latches and power window regulators, at this point the door was lighter and no longer closed . It raised up 1/4" without the guts in it. With any luck it will settle back down when reassembled and be in line.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
#48 |
Re: New doors
My rubber looks more like this
#49 |
Re: New doors
Wrong, yep, "Reproduction" it's "similar" but never exact, I would say that is a hundred miles from exact. Unless it was different in some years or something like that, all I have ever seen is the one I have shown you.
Brian
#50 |
Re: New doors
Ok thanks, I'll live with it for now
