Old 10-31-2014, 11:39 AM   #26
dfrank
dfrank's Avatar
Re: Quick fuel carb
Originally Posted by Mv7fd View Post
I replaced the cam lifters rods rockers timing chain and timing gear. It could be very possible that the rockers aren't right and i'll pull the distributor
If you are pulling the distributor than you might as well set the engine to TDC and the distributor rotor to #1 then re-install. If the distibutor doesn't want to go all the way in then just put light pressure on the rotor and have a helper bump the starter and it should just fall right in. It is much easier that way than pulling it in and out multiple times to adjust the oil pump drive shaft.
dfrank is offline   Reply With Quote
Old 10-31-2014, 12:01 PM   #27
Mv7fd
Re: Quick fuel carb
I just hope I figure it out soon I've had enough
Mv7fd is offline   Reply With Quote
Old 10-31-2014, 06:21 PM   #28
dfrank
dfrank's Avatar
Re: Quick fuel carb
If you give up just send it my way and I will take it! LOL
Old 10-31-2014, 06:22 PM   #29
Mv7fd
Re: Quick fuel carb
If sell it in a heart beat I'm so aggravated with it. The truck is in perfect shape I just can't make it run right
Old 11-01-2014, 02:54 PM   #30
Mv7fd
Re: Quick fuel carb
Well I haven't given up yet I picked up a performer intake for 50 bucks and my buddy gave me a used holley 600 cfm carb that he rebuilt and I am taking my distributor back and getting a new one so we shall see how it all turns out
Old 11-01-2014, 03:17 PM   #31
dfrank
dfrank's Avatar
Re: Quick fuel carb
You may have to re jet the carb and mess with the accelerator pump unless your motor is identical to the one the carb was previously tuned too. It should start and run fine though, just not ideal
Old 11-01-2014, 03:18 PM   #32
Mv7fd
Re: Quick fuel carb
He completely rebuilt it so it's not tuned to anything right now it's set back to stock
