Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-01-2015, 09:44 PM   #26
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: Project "Man Pedal"
Almost done. Drive shafts are in. clutch hydraulics all hooked up. All that's left is the exhaust, I need a dry day to get it installed. Once I drive it and everything checks out I will put the instrument cluster in and the tranny hump. So close. ....
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-12-2015, 11:34 PM   #27
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
She moved under her own power today! Just over 4 montHs off the road. Ran good, but the 4 month old gas needs to be drained. I plan on buttoning up the interior this weekend.
Old 03-13-2015, 11:44 AM   #28
argonaut
argonaut's Avatar
Awesome! How is the new clutch working out for you?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-13-2015, 11:48 PM   #29
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Works good, I had to bench bleed it. Nice and smooth, I like it better than the mechanical linkage.
Old 04-04-2015, 11:25 PM   #30
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I had a set back, seems the input shaft bearing was bad and gave up the ghost. So, I decided to find another tranny and swap it in. I picked one up with bell housing and shifter for $200 last weekend. Me and my sons got it installed today, took about 4 hours. Works great, put about 30 miles on it. Now I have another side project some day, rebuild the SM465. But first I need to finish the interior.
Old 04-05-2015, 01:23 AM   #31
argonaut
argonaut's Avatar
I bet it feels good to be driving it around again.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 04-08-2015, 06:24 AM   #32
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
It does Jason. Now I am going to freshen up 2 10-bolt axles I bought with lower gears and slide those under the K5.
Old 02-08-2016, 10:05 PM   #33
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Been awhile for an update. Bought some cucv axles a month ago and the dana 60 front is under the blazer. Once I get the perches moved the 14 bolt will make it under the rear. I need to hook up the drag link and brake lines and the front is ready to roll. I will get some pics tomorrow.
Old 02-12-2016, 10:04 PM   #34
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Ordered new perches, u-bolts and top plates from ORD as well as brake lines. Going to get the old perches off this weekend and replace the rear brakes and an axle seal. this way I will be ready to bolt her in after the perches cool.
Old 03-23-2016, 12:51 PM   #35
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Work is progressing, bought a plasma cutter and some 4" front and rear leaf springs. I hope to hit this hard this weekend, the wife will be at work and looks like some decent weather.
Old 03-24-2016, 12:52 AM   #36
El Dorado Jim
Nice build, I also love the manual trans, have one in all three of my pickups,wife has the automatic, we need pics!
El Dorado Jim is offline   Reply With Quote
Old 03-24-2016, 08:05 AM   #37
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I will take some this weekend. I also found a cab for my son's M1031, the 6.2 runs strong just need to swap cabs. The nice thing is the cab has a manual steering column and is an 86 too. That will clean up the K5 interior. Going to add that to the list of things to do.
Old 03-26-2016, 08:01 PM   #38
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Scored an 86 cab with manual, tilt steering column with a nice GMC steering wheel. Going to put it in the K5. I also took the pedals/hydro boost set-up off too. I might sell them, not sure at the moment. Pics to follow.
Old 03-26-2016, 09:12 PM   #39
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Here's the dana 60 installed and the 14 bolt with perches removed and the 4" lift springs next to it.
Old 04-06-2016, 07:05 AM   #40
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Made lots of progress. Got the 14 bolt under the rear w/ the wrong 4" lift springs. (bought 56" springs vice 52" springs, guy didn't know what he had) Put the 4" lift springs in the front. Things left to do:
Hook up new brake hoses front and rear and new front calipers
New front driveshaft
Install new to me manual tilt steering column
Install steering correction (probably a 3" block on the Dana 60, not ready for crossover)
Replace wrong rear springs
Old 04-14-2016, 06:45 AM   #41
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Updates:
Hook up new brake hoses front and rear and new front calipers (front done)
New front driveshaft (going to swap to a sm465/np208 combo and use a longer front driveshaft I have and get the rear cut down from a short bed)
Install steering correction (probably a 3" block on the Dana 60, not ready for crossover) (I have the block and studs)
Replace wrong rear springs (all done)
Old 04-14-2016, 08:25 PM   #42
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
All the brakes are done.
I forgot about the axle shock mounts. Need to weld those on.
Old 04-17-2016, 07:54 PM   #43
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Drove her today, still need to finish a few things. Here's a couple pics. The SM465/NP208 combo is going in, that way I will have a longer front driveshaft. All the ORD stuff was perfect. U-bolts front (with studs) and rear and the rear spring plates and perches. I used a 3" steering block, but I am going to go crossover, hopefully by the end of the summer. Going to keep the tires at about 36" or less.
Old 04-22-2016, 06:22 PM   #44
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I got my "new" manual steering column in. Ordered some shocks. I hope to have the tranny swapped and the rear driveshaft at the driveline shop Monday.
Old 05-26-2016, 06:55 AM   #45
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Swapping trannys this week. New shocks are on, steering column is in.
Old 05-26-2016, 01:45 PM   #46
junksaver
Progress looks good. Do you have any pics of the blazer?
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
Old 06-07-2016, 02:23 PM   #47
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Thanks. I will get some. I just got my rear driveshaft made and going to install today. Should be back on the road.
Old 06-07-2016, 02:26 PM   #48
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
This project would have moved along faster if I didn't have to swap axles in my son's jeep. We went from 3.08s to 4.10s with 33s. Made a big difference and he can use overdrive now.
Old 06-12-2016, 08:15 PM   #49
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Here's some exterior pics. The 315s were on my son's truck and I bought the M/T 2 clones locally. I like the stance.
Now time to work on the interior.
Old 07-26-2016, 12:34 PM   #50
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I know I started another thread with these pics but felt they need to go in here too. I might have another tranny issue and debating putting in a th400/np205 combo from the K30 I just got. Stay tuned....
