Old 11-25-2014, 11:02 PM   #26
BigRed76
BigRed76's Avatar
Re: 5.3 swap in K5, need new fuel tank for 2003 fuel evap system
Originally Posted by 93FatBottom View Post
Would you by chance have any examples or ideas of a quick cheap easy way to mount the sensor?
I think the simplest way would be to find a section of the EVAP line between the tank and the canister that is rubber, and tee into that rubber line with vacuum tees or something similar and then have the teed hose go right onto the nipple of the fuel tank pressure sensor.
If you're planning on using the factory charcoal canister up under the hood then it may be easiest to put the sensor up near the canister, that way the wiring for the sensor can be a lot shorter and help simplify your engine wiring harness.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 11-26-2014, 12:03 PM   #27
chebyshortbox65
chebyshortbox65's Avatar
I have got one through smog in one of the toughest counties in california riverside county pm me
chebyshortbox65 is offline   Reply With Quote
Old 11-26-2014, 12:11 PM   #28
chebyshortbox65
You can not use a resistor to fool the ecm to perform te fuel tank pressure check running resistor will throw a check engine lite for fuel sending unit stuck in range after so many miles without the fuel level changing you have to run the oem charcoal canister and purge selinoid and vent selinoid and they will check it with a scanner and make it function I ran my epoxy my pressure sensor to a 3/8 barbed fitting and put it in line between the tank and the charcoal canister. Also they do not like brass fittings on the evap line they *****ed about it
Old 11-26-2014, 01:13 PM   #29
NorCalAnthony
OP - I just talked to the tuner I plan on using and he confirmed that the fuel tank size can be adjusted in the PCM's programming. Once it's been adjusted to the K5's tank size you shouldn't have any issues with the fuel pressure sensor tripping a CEL for the fuel system taking too long/not long enough to pressurize.
chebyshortbox65 - Do you have a build thread somewhere for your CA approved smog swap? There aren't many out there and I'd love to see what all you had to do. Also, the resister idea ls1nova and I were referring to was for making the stock fuel gauge read correctly/have the correct sweep not to trick the PCM about the evap system (just wanted to make that clear so nobody gets bum info).
NorCalAnthony is offline   Reply With Quote
Old 11-26-2014, 06:43 PM   #30
chebyshortbox65
No worries there was a lot of talk of resistors trying to trick the ecm into starting the evap moniter test that's what I was talking about you have to turning off all smog equipment related codes with hp tuners and it will automatically set the readiness test everything still functions te same just doesn't do the test anymore. And no build thread I never got one started I am currently building a 64 biscayne with a 5.3 and will probably start a build thread on the next truck soon a 73 k10 to 2 wheel drive bagged and ls swapped. So far I have got 2 cars through the referre a 87 caprice and a 81 c10 I have done a few harnesses for guys that got them through as well
