Old 11-22-2014, 11:31 PM   #26
CRGRS 66
CRGRS 66's Avatar
Re: 350 fan shroud questions.
Sounds good, keep us posted, and put up pictures of your install when you get there. Always interested to see different approaches. I will be interested to see your wiring solution.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 11-22-2014, 11:37 PM   #27
j.rigby15r
j.rigby15r's Avatar
In thinking of doing the Volvo relay with the BMW temp relay. You can find it all on ebay for around $ 40.
j.rigby15r is offline   Reply With Quote
Old 11-23-2014, 12:34 PM   #28
cab_01
cab_01's Avatar
I personally like the normal clutch fan. It will always work if the motor is running. To me it looks better. Here is the spacer that was talked about.
Here is the shroud. I used aluminum. Was pretty easy to make or you could buy from Summit.
cab_01 is offline   Reply With Quote
Old 11-23-2014, 04:21 PM   #29
64shortbox
64shortbox's Avatar
cab_01, Fantastic job on both your shroud and your fan positioning. 1/2 in and 1/2 out of the opening for best air flow. You do nice work.
I ended up using an electric fan because my truck would get hot here in the San Joaquin Valley during the HOT summers idling in traffic with the A/C on, waiting in the drive through with the A/C on. I needed massive amounts of airflow at idle is the reason I went with an electric. Going down the road I'm fine but idling at 8 or 9 hundred RPM just didn't cut it sitting still in the heat.
64shortbox is offline   Reply With Quote
Old 11-23-2014, 11:20 PM   #30
Kenfuzed
Kenfuzed's Avatar
I put together the shroud from Summit and it worked out pretty good. I had to do some extra cutting to trim the ring strip down to 2" so the fan wouldn't be buried inside the shroud. The ring strip is 3" wide in the kit but since I have my engine moved to the forward position it needed to be modified.
Even though you went with an electric fan you should still consider some sort of shroud to pull air through the entire radiator.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 11-24-2014, 06:26 AM   #31
j.rigby15r
j.rigby15r's Avatar
I've got a fan shroud coming. The Taurus fan is completely shrouded, if you look at the pictures posted by Shortbox you can see what I'm talking about.
Old 11-24-2014, 04:51 PM   #32
Kenfuzed
Kenfuzed's Avatar
Nice, post pics and an update when you install it.
Enjoying the ride!
Old 11-24-2014, 10:05 PM   #33
cab_01
cab_01's Avatar
Thank you sir. I live in east San Diego county and it gets hot but not like you get up there.
