#26 |
Re: Hey Big Block guys, what diff gears are you running?
I have a .100 over 454 and 4.10. Would really like to try a 3.54 and/or some kind of OD.
Mats.. ---------------------------------------------------- 1971 Cheyenne Super Custom Camper 475CBB/TH400/AC 1992 Silverado Sport Truck 1988 Silverado 2500 Ext Longbed 4x4 2001 GMC Sierra SLT 4x4 1990 Chevrolet K3500 1965 Pontiac Grand Prix 1980 Z 28 350/4-speed/AC/T-top 1980 Camaro Coupe V6/3-speed 1979 Buick Century Wagon |
#27 |
Do the TH200 4R. The gear split is SO much better than the TH700R4 1-2 spread. And the TH200 has more overdrive. The 3.73 is ideal for the 200. Don't waste your money doing something with the rear only to go OD later. Just save for that point.
One thing you haven't mentioned is tire. You can get away with a lot more gear depending on tire height. A 26" tall tire will be screaming at 70 mph compared to a 31" tire.
#28 |
My truck is a C20 with 265/75x15 which is 30.65 tall.
#29 |
You are Correct Mike! I did forget to mention that I did switch to taller tires and it has helped a bit with the rpm's.
As mentioned before I'm going the route of the "built 200". I went to the swap-meet this weekend and a transmission vendor there gave me a strange look when I said I wanted to use a "built" 200 for my big block. He was trying to tell me that It would be a bad idea to use a 200 and then he continued by trying to sell me one if his "built" 700's.. I found his antics to be pretty shady...especially when I said the motor was a big block 454..he asked..is that a Chevy engine? ![]() |
#30 | |
The 3.54 gearing from your current 4.10 at your current tire height would decrease the rpm's about 450-500 (about 2590) at 65mph..that's a decent drop in rpm's. Although cruising at 70mph with about 2000 would be ideal IMO. In that case.. you're looking at $200-$300 for gears versus $1000 for a transmission Last edited by FstCarsNGuitars; 11-26-2014 at 11:36 AM. |
#31 |
Hi Steeveedee,
I have the exact year and model truck you have. My truck has the 402 with the TH400 and 3.54 gears in the diff. When on the freeway hitting 65, my RPM's are close to 4K. Does your truck also run that high? Is there anything I can do, keeping the original tranny and diff, to improve the RPM's so they are not running so high? I would like to use it as a daily driver and hit the freeways from time to time. Any advice or input would be greatly appreciated. God bless, Tbone
70 CST C20 |
#32 |
TBone, old thread, but I wonder if your tach. is in error. To turn 4000 RPM at 65 mph you'd have little short 20" diameter rear tires according to this previously posted calculator :http://www.csgnetwork.com/multirpmcalc.html
What size are your rear tires ?
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
#33 | |
Who Changed This?
![]() Join Date: Jan 2013
According to the calculator posted above, my truck runs about 3 grand. If your tach is set for a 6-cyl, it will show about 4 grand. 3 grand is still pretty wound up. I drive 55 all the time on the freeway for that reason, and the tall camper shell really kicked my mileage in the butt. That's about 2500 RPM, which is tolerable. I'm retired, so I'm in no hurry to get anywhere if I'm driving the truck. ![]()
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 08-03-2018 at 10:59 PM. Reason: Thar's --> That's typo |
#34 |
My 72 SWB, 454/TH350 trans and 3.73 gears is hitting about 4000-4200 at 65 MPH, I am just going to go with a 700R4, I'm not racing it just a cruiser so it should be fine.
![]() Pops |
#35 | |
Awesome! Thanks for the calculator! The motor that came in the truck when I bought it was a SBC 350. I am returning the original size BBC 402 that belongs in it. I am a novice with rebulding an engine. Wish I knew someone local that could assist me so I don't blow this thing up upon initial startup. I am also trying to figure out the correct pulleys that belong on this. I am running Power Steering, & AC. I think I am supposed to have 3 grove crank pulley and 2 groove water pump pulley. BUT, don't know the diameters of the pulleys that I need to purchase. I am even thinking of rebuilding the TH400 since it is the original on the truck. Thanks for the calculator! God Bless! Tbone
70 CST C20 |
#36 |
Who Changed This?
Get yourself a book like this- https://www.amazon.com/Hotrod-Big-Bl.../dp/0912656042
To help with your rebuild. All kinds of good pointers, even if you aren't looking to make it into a FARMTRUCK- https://www.youtube.com/watch?v=sCuGNMOHIy4
