Old 03-31-2018, 10:56 AM   #26
dbaillargeon
Re: who's running a 305
Have a 305 v6 in my 1969 c30...love it and can't kill it
A lot to think about, not much to worry about...
dbaillargeon is offline   Reply With Quote
Old 03-31-2018, 11:13 AM   #27
LockDoc
The Older Generation
LockDoc's Avatar
The 305 v6 is a completely different engine than the OP was talking about but they are a great engine.
Since you brought this back to the top, I have a new 305 that was with a '72 C30 Dually I bought. I haven't used it since I put a GM crate 350 in the truck, but I would like to put it in something just to see how it would run.
Here is the spec sheet that came with it. Somebody put some serious cash in this thing.....
305 Engine Specs
1989 1 piece seal block
Balanced
Roller Cam
Hydraulic Roller Lifters
1.6 Roller Rockers
.010, .010, and .030 Over
Scat Rods
Mahle light Weight Graphite Coated Pistons
Low Drag Rings
1978-81 305 Heads, Fully Rebuilt
1.50” & 1.72” Valves
Exhaust Ports Cleaned Up For Smoother Flow
Edelbrock EPS powdercoated intake
Powder coated vintage style valve covers
This engine was built for fuel efficiency
0 miles on engine
LockDoc
Leon
Old 03-31-2018, 12:30 PM   #28
stewmagoo73
I have a 86 305 HO bored .30 over with a mild cam, HEI set up, tuned q jet. Great motor in my 67 c10. Hoping to FI Tech or possible 600 cfm Edelbrock carb, upgrade the ram horns to headers.
stewmagoo73 is offline   Reply With Quote
Old 03-31-2018, 12:42 PM   #29
jessemthompson
My question to you is this. What do you expect from this? Dependability? Power? It’s a small block Chevy. It’s going to be dependable. Chevy put them in full size trucks, blazers, Camaro’s, captrice’s etc... Power? It’s not terrible, but it’s not great either. It’s not going to run like a 350. I don’t need to tear up the drag strip in my truck, but I wouldn’t be satisfied with a 305 or as I’ve heard them called 3 slow 5. It all depends on what you’re looking for.
jessemthompson is offline   Reply With Quote
Old 03-31-2018, 09:58 PM   #30
HO455
Post Whore
HO455's Avatar
I'm currently going the opposite way right now. Pulling the 305 (ex 85 El Camino) out of my Burban. It used some oil and had low oil pressure so I'm sure it was a high miler. That being said it got the Burban around town pretty well but it was no jackrabbit off the line. The PO said he pulled his race car with it but I have my doubts about that. Too many hills around here. In my mind a stock manifold and a Q-jet off a 350 or smaller would be the best set up. The 305 isn't a bad way to go. In 1967 it would have been the second largest available.
RIP Bob Parks.
Old 04-01-2018, 07:37 AM   #31
Daman
I have a 305
Daman is offline   Reply With Quote
Old 04-01-2018, 01:23 PM   #32
fatbass
fatbass's Avatar
Wink Re: who's running a 305
Here's video of my 11 second 305 powered C10...
https://www.youtube.com/watch?v=dQw4w9WgXcQ&t=0m43s
'71 C/20 350/T350.
fatbass is offline   Reply With Quote
Old 04-01-2018, 04:33 PM   #33
rsavage
rsavage's Avatar
So you have a 3/4 ton pickup with a 2 barrel carb that does an 11 second quarter? It is April Fool's Day!!
Great video of your burn out.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-01-2018, 06:21 PM   #34
stewmagoo73
In another reply to my other post. It's your truck do as you deem necesaary. If you need a cruiser and not a drag truck it will be perfect.
