11-25-2014, 01:09 AM | #26 | |
Re: Who is running manual valves?
Were did you get your fittings from? |
11-25-2014, 11:43 AM | #27 |
Never Ending Projects
You can get them directly at http://www.littlelarrys.net/
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
11-25-2014, 12:21 PM | #28 |
I think zipper is looking for the ptc fittings that TX used behind the valve block.
11-25-2014, 03:06 PM | #29 |
Newfisher do you have any videos of it in action? How loud was the dump inside the truck since you cant run a exhaust with those valves.
11-25-2014, 03:15 PM | #30 |
I don't have a video of the truck,it was sold earlier this year. I am still in contact with the owner. let me see if he can take one?
4-5 seconds down and 4-5 up. The exhaust noise out the backside wasn't obnoxious. It shoots under the dash and where you sit, you are not bothered by it. I have a V2 system now and If I do another manual system I would do the same set up from Borris. The Larry's paddles look good, but a little large to find a spot for. I didn't want to cut a hole in the dash of the 46 nor did I want the gauge /paddle pod to hang below it so I went with the V2. Everything is displayed on the screen and can tuck it away if I want. It was only a few hundred bux more than a manual set up if you search.
GOD BLESS AMERICA! |
11-27-2014, 11:24 AM | #31 |
I just came up with another question. If I decide to run the 1/4 line with the slower speeds is it going to be unecessary to have 2 compressors? I was going to buy 2 of the viar 444c's and a 5 gallon tank.
11-27-2014, 02:32 PM | #32 |
I would still do 2 compressors. The amount of air to refill the bags after deflation will have a single compressor running much harder.
11-27-2014, 03:29 PM | #33 |
Now I have a question when using manual valves running two compressors one tank how far away can the compressors be mounted from the tank? Say tank on one side of frame and compressors on the other. Would that effect speed?
11-27-2014, 04:34 PM | #34 |
Negligible most likely.
11-27-2014, 04:55 PM | #35 |
2 comps and a 5g would be perfect for 1/4 line. Im running a single comp now and if you dump and refill twice, the comp runs a while. With 2 that cycle would be much quicker.
11-29-2014, 08:51 PM | #36 |
Newfisher are you running 1, 1/4 line from the tank to the valves and then splitting it somehow?
11-30-2014, 11:21 PM | #37 |
Watch out for your cornhole !
Sorry I didn't see your question earlier.
I bought them, along with a ton of other stuff from tho robros.com I had to put that space in his website name due to board politics. Apparently there is bad blood between them and the admin here so when you type his website on here it gets censored. I know nothing about the feud that caused it, but he (Jason Thorbec ke) did me very right on all of my orders. I'm a very loyal customer to them.
11-30-2014, 11:31 PM | #38 |
are they the ptc fittings? I can't find the ones borris uses in those panels anywhere
11-30-2014, 11:33 PM | #39 |
Yes, they're push to connect.
Quality seems good. I used them throughout the system and I can set pressures and the entire system holds exact pressure for weeks without leaking off.
10-25-2017, 11:18 AM | #40 |
Any updates on those of you running the FourPlay Valve setup? Thinking about ordering and haven't been able to find much in the way of reviews.
