Old 12-06-2014, 10:20 AM   #26
Swar
Swar's Avatar
Re: Project: Nightmare
Originally Posted by reaper71 View Post
That sucks!!! those headers hang really low..any thought of changing them out for shorter ones?
Yea that's the plan, but I've dumped too much money into this beast already.
I'm not fixing it until it breaks. Plus, routing a new pipe around the mechanical clutch linkage is going to be a challenge.
Swar is offline   Reply With Quote
Old 12-11-2014, 10:23 AM   #27
Swar
Swar's Avatar
The next issue was the sway bar. The one I had was from Early Classic and it was made to bolt to the stock control arms. It wasn't going to work on the new arms. I called Choppin' Block and the guy happened to have a Porter Built sway bar that he said would work, so I bought it at a discount. Once I got it, I realized it just barely worked. I had to install it upside down for it to line up the best, and when I cut the wheel all the way, the tires rub on it.
If anyone knows of a better bar out there, please reply. The measurement between the two bolt holes for the end links is 44 inches.
Old 12-11-2014, 11:31 AM   #28
Swar
Swar's Avatar
Finally got it back on the road. I'm pretty happy with the ride, definitely a big improvement over coil springs. The time and the work to get to this point was insane though, I racked my brain trying to engineer the setup to get everything to work together, and I was literally watching the seasons change as I waited for parts, so be prepared for this kind of BS if you want to build your own air ride system. To put it in perspective, I think my engine build was easier.
I still have some air leaks around the tank and valves, I'll be posting about that soon.
Old 12-29-2014, 10:43 AM   #29
Swar
Swar's Avatar
I came up with an idea to correct the front shocks. These shocks were on it before I did the air ride. They just barely worked, too short, binding against the frame, causing them to leak. I needed to make room for longer shocks.
Old 12-29-2014, 10:50 AM   #30
Swar
Swar's Avatar
I couldn't get to the old shock bolts on the inside of the frame, so I just cut them off for now. I made some measurements and realized I could just cut out some of the inner fender for longer shocks. Turns out, stock rear shocks work. I found a piece of square tubing at Lowe's and drilled out the frame.
Old 12-29-2014, 10:56 AM   #31
Swar
Swar's Avatar
It's pretty simply and crude, but it works, that's what matters. I left some length on the square stock for when it comes time to lower it more.
For reference, Here's a shot of it aired up all the way...
Old 12-29-2014, 11:09 AM   #32
Swar
Swar's Avatar
Just wondering, am I the only one on this entire forum with Choppin' Block Control Arms?
I've had zero feedback about them, and I can't find anything on google...
Old 02-09-2015, 12:43 PM   #33
Swar
Swar's Avatar
It's been awhile since I posted anything, the weather's been too lousy to do any driving, so the truck's been sitting and waiting. The new garage is coming in handy for a lot of things.
I fixed some air leaks around my valves and changed the configuration at the same time to simplify and save space in the bed. This is was my initial setup:
Old 02-09-2015, 12:48 PM   #34
Swar
Swar's Avatar
And here's the new setup. I built a box with pressure-treated to keep the weather off it.
Old 02-09-2015, 12:55 PM   #35
Swar
Swar's Avatar
I had to keep it outside for a bit while they wired up the garage. Can't wait for a nice day to take it out on the roads, it looks like it wants to be driven.
Old 02-09-2015, 01:14 PM   #36
Justin@EntropyRad
Justin@EntropyRad's Avatar
I like it laid out on the whitewalls
Justin@EntropyRad is offline   Reply With Quote
Old 02-09-2015, 01:59 PM   #37
Swar
Swar's Avatar
Thanks, I want to slam it all the way to the ground eventually. I'm going to have to make some serious changes to do that though. More work coming soon!
Old 02-10-2015, 04:08 AM   #38
boynton
boynton's Avatar
Then you can push snow with your front bumper!
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 02-10-2015, 10:26 AM   #39
Swar
Swar's Avatar
I hate the snow. 400 hp and bald tires, this thing is useless in the winter.
As soon as the snow is off the roads, I'm going to burn rubber.
Old 02-15-2015, 11:00 PM   #40
low&slow
Lol I know how that is. My field is a muddy mess. Can't even move my truck. Wait till summer to drive it and I'll be doing the same thing. I got a new pair of drag radials and a pair of slicks I'd like to burn lol
low&slow is offline   Reply With Quote
Old 02-16-2015, 07:44 PM   #41
Swar
Swar's Avatar
Post a burn out video! I'll do the same!
Old 04-10-2015, 12:09 PM   #42
FRANKENSTEINC10
FRANKENSTEINC10's Avatar
uhm??!! am i the oly one that saw the Deer? i feel like im stocking you man, but the akwardness of you build has caught my eye!
FRANKENSTEINC10 is offline   Reply With Quote
Old 04-10-2015, 12:24 PM   #43
Swar
Swar's Avatar
Haha yea you're the first to comment on the deer. Thanks for checking out my build, that's what it's on here for!
Where's the link for yours?
Old 04-10-2015, 01:38 PM   #44
FRANKENSTEINC10
haven't gotten to that point yet unfortunately. Hopefully this year will bring a ton of parts to put my dad's old truck back together the right way and not with job weld and coat hangers. Lol.
