Old 12-11-2014, 05:33 PM   #26
Wt195713
Wt195713's Avatar
Re: Project Firewater- 59 fleet
Nope, i was wrong, y'all were right, i spent the past day fixing and laying on motor mounts. here she is:
not my sbc but this one worked just fine for mock up. mine is being shipped the 17th from northern speed shop.
1959 Short Bed Fleetside Big Window (bagged/383 stroker)
https://67-72chevytrucks.com/vboard/...d.php?t=651883
Instagram - @slammedapache
TikTok - @tylerwaltz
(OO)=======(OO)
Wt195713 is offline   Reply With Quote
Old 12-11-2014, 10:49 PM   #27
ricott
Congrats on your truck. I (barely) remember being 20 and working to get (and keep) my "hot rod" car running. You're have a great start, and I'm glad you discovered (and corrected) your error. WE have all done it, and some have been really expensive (at least for me)!!!
Ricky
ricott is offline   Reply With Quote
Old 12-11-2014, 11:06 PM   #28
Kim57
Kim57's Avatar
Looks like you made good progress in the change.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-11-2014, 11:09 PM   #29
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Glad you got it figured out! Nice progress.
ChuckDriver is offline   Reply With Quote
Old 12-12-2014, 08:18 AM   #30
dubie
dubie's Avatar
Does that factory front cross member need to be removed? I see some people do and some people don't after installing an IFS
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 12-12-2014, 02:02 PM   #31
Wt195713
Wt195713's Avatar
Ricky
I saw you lived in dallas for a little while. What salvage yard were you getting parts from?! The ones by me don't even know what a car older than 1990 looks like.....
(OO)=======(OO)
Old 12-12-2014, 02:06 PM   #32
Wt195713
Wt195713's Avatar
Maybe it's the mounts they use? I could see how a fan would interfere but I'm going the electric fan route. I left it for the fact that I had no reason to strip it out and jeopardize frame integrity.
(OO)=======(OO)
Old 12-12-2014, 02:50 PM   #33
Russell Ashley
Russell Ashley's Avatar
I also didn't want to remove the crossmember but I did have to trim a couple of inches off of it to get the rack mounted. This must be different with 58-59 trucks if you were able to mount yours without trimming it. As a caution, did you mark the centerline of the axle before you removed it? Most everyone moves the wheels forward when converting to independent front suspension to center the wheels in the fenders better. I moved mine 3/4ths of an inch forward but some move them more than that.
Russell Ashley is offline   Reply With Quote
Old 12-12-2014, 03:16 PM   #34
Wt195713
Wt195713's Avatar
I was sure to mark it. What kit is that? I like how they integrated your motor mounts!!!
(OO)=======(OO)
Old 12-12-2014, 03:46 PM   #35
ricott
The LS based engines and trannys for my last three builds came from Settlemires used parts in Walnut, MS. All of the sheet metal parts have come from Craig's List or E Bay within 700 miles of Memphis, with most of them from Oklahoma or Missouri. I miss Dallas (lived there 14 years), because there was a great fab shop that I used.
Old 12-12-2014, 05:32 PM   #36
Russell Ashley
My setup is a bolt-in from Scott's Hotrods. The engine mounts are also from Scott's but not actually part of the kit. I purchased them from Scott's after realizing that the front engine mounts weren't going to be useable after trimming the cross member.
Old 12-13-2014, 03:43 AM   #37
Wt195713
Wt195713's Avatar
Anybody have tips to patch the firewall?
(OO)=======(OO)
Old 12-13-2014, 05:13 PM   #38
OrrieG
OrrieG's Avatar
No tips, just tedious. I did mine when my wife when out of town to visit our new grandkid, I had work committments so I could not go. I had two weekends and one week of evenings to work on the truck. I wanted to get rid of all the holes but keep the recesses. Took Saturday to weld in the 40+ holes (ranging from screw size to 1.25" dia), long Sunday to grind, fill, regrind the welds. Had one evening to repair floor pan areas under the battery box. After that about 16 hours during the week and next week end of fine JB Weld filling, plastic work, priming and paint. Paint is same single stage chassis black I used on the frame and inner fenders. I had not made up my mind on the paint color, black works with anything.
For the larger holes I made 16 ga. plugs and held them in place with a magnet from behind. For smaller ones I have a flattened piece of copper pipe I hole behind the holes. Here are the photos.
OrrieG is offline   Reply With Quote
Old 12-15-2014, 06:40 PM   #39
Wt195713
Wt195713's Avatar
Yeah, I did have to trim the front also. Always easier coming out than going in
(OO)=======(OO)
Old 03-25-2015, 05:40 PM   #40
Wt195713
Wt195713's Avatar
Size:  51.4 KBName:  IMG_1880.jpg
put the bags on the mustang ii today. hopefully i can get to 4 link this weekend. I am already excited about the look. I can't wait for my air management to arrive so i can start playing. i also picked up a 150db train horn just because it seemed fun.
(OO)=======(OO)
Old 03-26-2015, 08:30 AM   #41
Kim57
Kim57's Avatar
Nice looking parts.
Kim
My build thread
Old 09-03-2015, 01:29 PM   #42
Wt195713
Wt195713's Avatar
airbags, 4 link, step notch, and on-board air ride are done in the rear. About finish all the air lines. Finally got wheels and tires 383 should be here this month. I see the end coming. Name:  image.jpg
(OO)=======(OO)
Old 09-03-2015, 01:32 PM   #43
Wt195713
Wt195713's Avatar
(OO)=======(OO)
Old 09-03-2015, 01:33 PM   #44
Wt195713
Wt195713's Avatar
(OO)=======(OO)
Old 09-03-2015, 03:12 PM   #45
ChuckDriver
Looking good!!
Old 09-03-2015, 03:17 PM   #46
oldman3
oldman3's Avatar
Nice update, looks good...Jim
oldman3 is offline   Reply With Quote
Old 09-03-2015, 05:20 PM   #47
Kim57
Kim57's Avatar
Looking good.
Kim
My build thread
Old 09-03-2015, 05:30 PM   #48
RockinKees
RockinKees's Avatar
You're going pretty fast with your build!
It's looking very good!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 09-06-2015, 06:27 PM   #49
Nut Case
Nut Case's Avatar
Wt195713, where are you going to mount the train horn, and where did it come from? Thanks Nut Case
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-10-2015, 05:22 PM   #50
Wt195713
Wt195713's Avatar
under the core support and eBay. i am running a solenoid from my 7 gallon tank for my air ride right to the horn.
(OO)=======(OO)
