Old 12-22-2014, 06:48 PM   #26
57chevyman
57chevyman's Avatar
Re: custom shifter knobs
thanks for the help.. i added a little more stain. even tho this product says it has the polyeurathane mixed in, im pretty sure i need to clear it tomorrow. would you say that i should sand with 200 grit before the clear, and in between clear coats? im not good at this, and i always seem to screw it up somehow!
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 12-22-2014, 08:13 PM   #27
iowaboynca
iowaboynca's Avatar
yes that should be the case, that will help smooth it out.
On a side note, if you do the second one, sand it out before stain, then sand in between the clear coats and it will come out smooth like a cue ball.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 12-22-2014, 09:00 PM   #28
57chevyman
57chevyman's Avatar
i found what i need on ebay... 1/2-13 internal threads and four tabs that bend down to lock the insert in place.
Frank
1957 Chevy 3100
Old 12-22-2014, 09:14 PM   #29
57chevyman
57chevyman's Avatar
or would a t-nut be better?
t-nuts are cheaper than the threaded inserts... four of these for the price of one of the inserts...
Frank
1957 Chevy 3100
Old 12-23-2014, 10:40 AM   #30
57chevyman
57chevyman's Avatar
This is what it looks like now with 4 coats of the stain/polyeurethane combo...
it really looks good. its smooth all the way around.
im asking those with knowledge in wood finishing, because i have none...
at this point do i
1. call it done
2. add a couple of coats of clear
3. sand this with 200 grit and then do the clear
it looks so good now, im afraid to touch it with sandpaper and screw it up.
Frank
1957 Chevy 3100
Old 12-23-2014, 11:01 AM   #31
57chevyman
57chevyman's Avatar
I couldn't wait . Here it is mocked up inside the truck . I can't really install it until I get the threaded insert.... But check this out
Frank
1957 Chevy 3100
Old 12-23-2014, 12:10 PM   #32
iowaboynca
iowaboynca's Avatar
at this point do i
1. call it done
If you're happy with it, then you are done!
Old 12-23-2014, 12:12 PM   #33
Kim57
Kim57's Avatar
Looks real good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-23-2014, 12:14 PM   #34
57chevyman
57chevyman's Avatar
I'm gonna call it done. Just need to figure out the threaded part. I just realized , the auto parts store probably sells adapter kits for shifters .
Frank
1957 Chevy 3100
Old 12-23-2014, 01:02 PM   #35
57chevyman
57chevyman's Avatar
Found this at harbor freight for 2 bucks. This will work
Frank
1957 Chevy 3100
Old 12-23-2014, 03:06 PM   #36
57chevyman
57chevyman's Avatar
Damn. My old shifter knob screws on perfectly to my 1/2-13 bolt . These things that I just bough also thread perfectly onto the bolt. But it slips on right over the threads on my shifter . So if my shifter threads are smaller than 1/2" I'm gonna try a 3/8 insert
Frank
1957 Chevy 3100
Old 12-23-2014, 04:22 PM   #37
OrrieG
OrrieG's Avatar
Sealant and a little push always worked for me! We don't need no stinking adaptors.....
OrrieG is offline   Reply With Quote
Old 12-23-2014, 05:13 PM   #38
57chevyman
57chevyman's Avatar
with another trip to the hardware store with my original shifter knob, i realized that the threads are 7/16-14 , not 1/2-13
of course 7/16 is an odd size for the hardware store...more of an automotive size. yeah no kidding, its for my shifter LOL. looks like i may have to order 7/16-14 inserts on ebay..
nothing is ever easy . but my nice shifter knob will be worth it in the end. i may make a few of them and see if i can make a few bucks selling them on ebay, CL
so far ive found a 16mm to 7/16-14 shifter adapter for $11 delivered
or ten of the 7/16-14 threaded inserts with four locking tabs for $27 delivered
Frank
1957 Chevy 3100
Old 12-24-2014, 02:33 AM   #39
57chevyman
57chevyman's Avatar
Good lord this shifter is making me nuts. The threads are bigger than 7/16, but smaller than 1/2. Is it metric 12mm?
My black plastic shifter knob is happy screwing onto all different sizes 1/2, 7/16, 12mm, and my shifter handle, but I've yet to find something that will screw on to my shifter! Only thing I didn't try yet is a 12mm
Frank
1957 Chevy 3100
Old 12-24-2014, 03:14 AM   #40
57chevyman
57chevyman's Avatar
I think the threads are 1/2-13 after all..... In this pic , the large 1/2-13 rod coupler screws onto the shifter handle as it should. The 7/16-14 nut is too small . The 1/2-13 "thread repair insert" on left slides right onto the shifter over the threads
Frank
1957 Chevy 3100
Old 12-24-2014, 05:15 AM   #41
tinyjaime
Originally Posted by eagleuh1 View Post
Check the stove bolt forums. There's a guy that makes custom knobs, very nice quality too. Jim
I bought one and the quality is outstanding, however the shifter knob meant more than just screwing on a knob. I wanted it because I kept the original 235 "stovebolt" but up graded the transmission from the sm420 to a t5. I modified the SM420 shifter to work on the T5 and installed a spacer to make the throw a short one vrs the long throw. Next week I will have the shifter powder coated and I am done.
Yes they come in 2 colors and are very comfortable.
If you make one I guess it will be a lot cheaper and mean something to you too.
Maybe if your truck is a V8 you might not want the stovebolt knob
BTW what your doing so far looks great it matches the steering wheel perfect
tinyjaime is offline   Reply With Quote
Old 12-24-2014, 02:49 PM   #42
57chevyman
57chevyman's Avatar
Thank you!
Frank
1957 Chevy 3100
Old 12-24-2014, 02:53 PM   #43
57chevyman
57chevyman's Avatar
didnt expect to have such a hard time figuring out what threads my shifter has. and on top of that, every store that sells brass inserts for wood only go up to 3/8".
Since the 1/2-13 rod coupler screws on to my shifter tightly, im going with that. i just ordered some threaded inserts with the four locking tabs.
Frank
1957 Chevy 3100
Old 12-31-2014, 03:59 AM   #44
57chevyman
57chevyman's Avatar
Finally done with the shifter knob! i got the 1/2-13 threaded inserts so i have nice metal threads in the knob.
Frank
1957 Chevy 3100
Old 12-31-2014, 12:04 PM   #45
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 12-31-2014, 12:16 PM   #46
iowaboynca
iowaboynca's Avatar
Lookin' good!
