Old 12-28-2014, 11:54 AM   #26
cadillac_al
Re: Can't bleed brakes
When the prop valve sticks after losing the rear brakes, some people have had luck unsticking it by bleeding the front brakes. You already did that right? One of my mechanic friends says he unsticks them by jumping on the brakes hard several times. That has only worked once for me. If either of those two techniques don't work you may as well buy another prop valve. Maybe the Mightyvac will work here too. Good luck.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 12-28-2014, 11:01 PM   #27
86c20
86c20's Avatar
you will want to open the back i think that way the pressure is lower then on the front to slide the vavle over. before you do it i have had luck with taping on them first to help to get them to move better then crack the line. like was said tho if you have bleed them back and forth you may need a new prop vavle
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
