Old 12-24-2014, 03:08 PM   #26
enaberif
Re: The backwards hustle!
Some brakes have a check valve installed so that when there is no vacuum you still have a small amount in the booster.
Have you tried to do as I suggested above to see if you even have vacuum in the booster after you shut the truck off?
enaberif is offline   Reply With Quote
Old 12-24-2014, 03:10 PM   #27
homemade87
Originally Posted by 74CustomK20 View Post
I changed it when. I went from hydroboost to vacuum. I will get one Friday amist the chaos.
I am confused now . You said you had the filter originally . Hydro does not need one of these .
homemade87 is offline   Reply With Quote
Old 12-24-2014, 03:16 PM   #28
74CustomK20
74CustomK20's Avatar
Enaberif - I haven't tried as my wiring is fried. That is my other goal before I go back to work.
My 79 started out vacuum with filter thingy. Got rid of filter n worked fine. Then when I got a 77 cab with hydroboost I got rid of hydroboost to go back to vacuum with new booster and that is when the problem arose. Does that help?
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 12-24-2014, 07:26 PM   #29
86c20
86c20's Avatar
i think we need pics at this point. lets see what you have it maybe something is mixed matched. i know that check valve i have had problems with on some car i worked on it did the same thing i think. now i am guessing against myself. pics will help i think
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
downgrade, manual to power brakes
