#26 |
Re: How to select carb?
This is not meant to be a hijack thread but how do you tell which carb is on it now and how many cfm it is? I have the same issue here . I want an easy driver that runs smooth and economical Erik
#27 |
#28 | ||
But I bought his book and rebuild kit and did the rest of it myself. Take lots of pics pulling it apart for reference during reassembly. Take your time, and be patient. Follow all of his guidance in the book. I couldn't be happier. Truck has been running great ever since.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
#29 |
Currently installed Holley carb # List-3310-3. Link showing specs.
http://1970mgr.org/_HolleyCarbs.htm |
#30 |
Anyone know what carb this is by any chance.
Thanks, Mondo |
#31 |
Holley 4360.
Quadrajet replacement. 450 cfm. |
#32 |
![]() Join Date: Aug 2014
#33 |
I went a slightly different direction on my truck and have been very happy with it. I installed a Street Demon 625. http://www.demoncarbs.com/1900.asp
It was easy to set up, runs great. I have decent economy (13 mpg mixed driving) when I drive easy, and a good kick ion the pants when I jump on it. The carb is basically Holley's redesign of the Carter/Edelbrock design. Very easy to tune, looks nice, works great, pretty inexpensive. I actually bought mine on Amazon. Had it on there for over a year now and no issues.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
#34 |
![]() Join Date: Jan 2012
sounds like you need a bolt on. Like previous hope you checked timing or previous owner didn't pop in a big cam. Weak valve springs carboned up valves.Low vacuum. worn out spark plugs,couple of less than desirable plug wires. If get where I'm goin buy a autoparts store carb and bolt it on.hopefully you hit it.there is more to it than carb.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
#35 | |
![]() Join Date: Nov 2006
You didn't mention which kind of manifold is in place, relevant info for your carb selection and desired results. Search out some carb sizing calculators and run a number of them, I'm pretty sure you will be surprised at the recommended sizing. The right sizing will provide the best metering signal, which translates to efficiency and good throttle response. Too big of a carb makes for sluggish air flow and poor signal. I'm with the "you're probably over-carb'd" camp. |
#36 |
![]() Join Date: Jul 2006
I agree with the timing comments. Make sure your initial timing is right. Also make sure your total timin is correct. Adjust initial for highest vacuum. I really like Barry Grant carbs. I've had mine since 2004 and haven't had to adjust it since then. For your application id go with a 625 Road Demon.
#37 | |
Truck has an Edelbrock Performer EPS Intake Manifold. Has an ACCEL HEI Super Coil 140003 distributor. |
#38 |
But what's your initial timing?
#39 |
Curious guys, why not a 2 bbl Rochester -well rebuilt?
Figure out what you want--then figure out what you are willing to give up to get it. |
#40 | |
The timing chorus has a valid point. Pretty much the golden rule to make sure your ignition is spot on before you go diddling with the carb. For that matter, you might want to check your cam timing and balancer timing mark accuracy before you bet your butt on any observed ignition timing numbers. In what condition are your timing chain and harmonic balancer? How many miles on those components? Way back when, I had a buddy "accidentally" discover he had horribly bad plug wires, after he had replaced the carb without curing the problem (rough running/ misfiring). New wires did the trick. Don't you just hate it when a simple question bogs down into such complication?! |
#41 |
Two barrel carbs big enough to work have primaries that are bigger than on a four barrel. Big primaries equal lower velocity and efficiency.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
