Old 01-12-2015, 01:32 AM   #26
67 cst swb
67 cst swb's Avatar
Re: Any one have a 1967 truck with 327 engine?
So, A casting date of April 17th 1967 with an assembly date of May 5th 1967.
Interesting, so an 18 day difference.
What head casting numbers are on that engine? Are they original to that engine? Also, if they are originals... what are the casting casts on the heads?
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 01-12-2015, 08:03 PM   #27
colgad
colgad's Avatar
Heads are not original.
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 01-12-2015, 08:45 PM   #28
SS Tim
SS Tim's Avatar
And...
Tim, correct me if I am wrong here, but I am looking for a Flint cast block that was cast in late Nov 1966 thru Dec 19, 1966. Correct?
Are there any other specifics that play into things here?
Or, is there a better way to narrow it down to a block casting number I may be specifically looking for, such as Flint Only cast blocks?
Good progress and you pretty much have it down. What is important to note is that you are looking for a Flint ("V") engine assembled on 1220 (of 1966). The block was cast before that date possibly as late as L-19. However a little earlier is more likely or even much earlier. Looks like you have strong confirmation the casting is going to be a ...657. That will make things a little easier if poking through inventory lists.
A Flint engine assembly plant code is going to be a Flint casting.
SS Tim is offline   Reply With Quote
Old 01-12-2015, 08:48 PM   #29
Redline novdog
Redline novdog's Avatar
Thanks first owner for the pics. Good information! The truck still sits outside. Hopefully tomorrow
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 01-12-2015, 08:51 PM   #30
Redline novdog
Good info SS Tim.
Old 01-12-2015, 10:02 PM   #31
SS Tim
SS Tim's Avatar
Originally Posted by colgad View Post
I have one but it was born in 67 and it was a 4 speed
VO505YS
3892657
D177
Need to point out the oranges to tangerines comparison here.
Its four months later (give or take) and thats huge. The YS assembly code suffix is the basic build manual trans L30/327 used in C10-30s. Could just be a case of using up stockpiled castings.
Old 01-13-2015, 12:44 PM   #32
67 cst swb
67 cst swb's Avatar
I am mostly noticing the time difference from cast date t assembly date.
My Trucks:
Old 01-13-2015, 12:45 PM   #33
67 cst swb
67 cst swb's Avatar
I am mostly noticing the time difference from his casting date to assembly date.
I am still looking for a Dec 10, 1966 (L 10 6) to Dec 19, 1966 (L 19 6) block with casting of 3892657.
But the more examples I see the clearer the date differences in the casting date to assembly date are becoming.
SS Tim... your help has been hugely appreciated. Thank You !!
My Trucks:
Old 01-14-2015, 07:55 PM   #34
Redline novdog
Size:  32.6 KB For now this is as best I can do for a casting date. Where do you find the build date on 67 truck? I looked on the cab tag and the spid; nothing
Old 01-14-2015, 08:44 PM   #35
70cst10_05
70cst10_05's Avatar
Not much help right now, but my brother has a 67 cst 327/th400 laying in the weeds at my folks house. I know for a fact its bone stock, had the original shocks on it when they bought it several years ago. It will be a few weeks before I can get up to look at it, but I'll try to remember to grab the numbers off of it. Also, it will be not for sale, so therefore will probably be the one you want! lol. It was his first truck.
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 01-14-2015, 10:00 PM   #36
SS Tim
SS Tim's Avatar
So far that 3892657 is the most frequent block number to come up.
Your stamp code appears to be a V0303YR, which means: Flint, Mich - March 3rd - Powerglide.
I am curious to see the block cast date (rear Pass side on trans flange) to see when the block was cast in relation to assembled (March 3rd)
At 550% I am clearly seeing V0305YR for Redline novdog's engine assembly date as posted in the linked thread.
http://67-72chevytrucks.com/vboard/s...6&postcount=18
Originally Posted by Redline novdog View Post
Attachment 1349678 For now this is as best I can do for a casting date. Where do you find the build date on 67 truck? I looked on the cab tag and the spid; nothing
Sorry but the only thing definitive I can make out is the center character "8". Can anyone make a clearer sharpening of the image? Tried all my tricks to no avail. Redline were you able to read the number in person?
Build date is not listed on the truck. The engine's assembly code is the closest documented number and that is on the protect-o-plate along with a single digit for the build month of the vehicle. But being built before the truck there is an ambiguous timeframe between engine assembly and vehicle assembly. If you happen to also have a build sheet it will show the engine suffix code and the trucks "scheduled" built date.
Old 01-14-2015, 10:18 PM   #37
67 cst swb
67 cst swb's Avatar
It will be great to get info from that engine, such as, block casting number, cast date, cyl head casting number, cyl head casting date, intake casting number, intake casting date and of coarse the stamping number. As much info as you can get would be great.
Thank you for looking and Thank you everyone for your interest in this thread.
My Trucks:
Old 01-15-2015, 07:50 PM   #38
Redline novdog
Ok it is a better shot not perfect,but it is ( L 8 6 ). I actually could see it this time no ice melting in my eyes and camera.
Old 01-20-2015, 07:25 PM   #39
Redline novdog
I got the intake Part # tonight on my 327. It has a 4bbl (4jet is it called). The casting/part# is 3882858.
Old 01-21-2015, 12:11 PM   #40
67 cst swb
67 cst swb's Avatar
Attachment 1350152
Is this L 8 6 off the block?
My Trucks:
Old 01-22-2015, 07:05 AM   #41
Redline novdog
Yes, the L 8 6 is off the passenger side rear of block. The 3882858 is off the intake manifold. Hopefully in the next week I can pull the valve cover off the drivers side cyl. head. It is an older gasket seat spark plug head.The passenger side was a '71 cast date, but it has the newer taper seat spark plugs
Old 01-22-2015, 11:58 AM   #42
67 cst swb
67 cst swb's Avatar
Kinda wishing that block was for sale and much closer to me, oh... and for an affordable price.
Bummer
My Trucks:
Old 01-31-2015, 09:05 AM   #43
Redline novdog
http://peoria.craigslist.org/pts/4866540159.html
There is a 67/327 on this craigslist site.It is not mine nor do I know anything about it. It is a 657 casting by the pictures. Thought someone might be interested.
Old 02-10-2015, 03:23 PM   #44
Elliot949
Elliot949's Avatar
I really don't want to hijack this thread but man I am so confused after reading this thread... Can somebody tell me what this engine is?... It looks to me like it says VT22IYH
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 02-10-2015, 03:31 PM   #45
67 cst swb
67 cst swb's Avatar
Well, Im thinking it is
V = Flint, Mich
12 = Dec
21 = 21st
YH = Turbo-Hydro trans
Do you have the Casting number (rear drivers side on trans mount flange) or the casting date (rear passenger side on trans mount flange) see post #23 by FirstOwner69 in this thread for locations.
and... Might this engine be for sale? I am very interested to see the casting date and block casting number.
Hopefully SS Tim will reply shortly.
My Trucks:
Old 02-10-2015, 05:40 PM   #46
SS Tim
SS Tim's Avatar
What are you confused about? This thread is not intended as a general decoder "how to". It is all about finding the correct block for a specific truck's assembly date.
What we can tell you from you engine assembly code is:
V engine assembly plant, Flint
12 month, December
21 21st day of December
YH The suffix code, tells us the application it was assembled for. In this case either
67 C10-20 327 with three speed automatic (TH400)
or
68 C20-30 327 wih a three speed automatic (TH40)
But without a casting date I can't tell you if it is a 67 or 68 block. It could very well have been assembled in December of 66 (67MY) or December of 67 (68MY). The casting date is the "key" to determining the year of the motor.
The thread above stresses too heavily the casting number when in fact it dosen't matter, if the engine assembly code and casting date match the vehicle build. Of course you want to confirm the casting number usage to ensure it is not a restamp or undocumented suffix code reuse by the engine assembly plant.
Old 02-10-2015, 06:28 PM   #47
67 cst swb
67 cst swb's Avatar
Tim, I was mostly wanting it to be verified that this is not a V 1 22 IYH (edit, thinking about this statement. it would have to be a V0122xxx to be a January 22... nevermind)
I wasn't even sure that was possible. It was just one of those moments that I wanted a responsible adult to walk in the room and say we were on the right track.
As far as my focus on the casting number, It is more of a concluding that all V = Flint 327's are a 3892657 block (???) and because the general public knows the cast numbers in finding and having a block.
If I state I am looking for a xxxx code block, most people will not look for the info. If I make it specific to a block, people generally know where that is, if they see they have a 3892657 block they may
be curious to locate the other 2 needed/important numbers. If V stamped 327's could be a different block casting number, then I am all wet and shooting myself in the foot. So, my asking for the
block casting is more of a research/verification that I might be onto something. Unless there is something already known and Im just catching up or that I totally wrong and just haven't figured it out yet.
My Trucks:
Old 02-10-2015, 07:46 PM   #48
Redline novdog
Build or not.I'll get the cast# and date off the drivers side cylinder head now I know you are after info !
Old 02-10-2015, 09:50 PM   #49
Elliot949
Elliot949's Avatar
V = Flint, Mich
12 = Dec
21 = 21st
12 month, December
or
Ok... so the only other numbers I can see for now because the engine is in the truck is on the rear of the engine top by where the transmission mounts...
Drivers side says 3892657 and on the right side 1166...
Old 02-10-2015, 11:15 PM   #50
SS Tim
SS Tim's Avatar
Thanks for following up with the numbers!
Exactly what I expected to find. A December (l) 16th (16) 1966 (6) cast block with the previously decoded December 21st 1966 assembly date. The fact that it is both a YH and a ...657 block very strongly supports that narrowing the search to only ...657 blocks is going to yield "67 cst swb" a correct block. Of course he might just turn up a 67 Camaro Z28 block or a 67 Camaro SS350 block instead. :-)
Now Elliot949, Do you have a POP (Protect-O-Plate) or a build sheet to support that as the original engine assembly code?
