Old 02-28-2015, 04:06 PM   #26
57chevyman
57chevyman's Avatar
Re: ride height
^^ yes there's 9 leaf springs there .....
I put the 2" drop spindles in front and removed the 5" blocks in back....
It looks like it's sitting nice now....we mocked up a bed side with fender attached (three guys holding it while I looked)..
I would have taken out a few leaf springs but I gotta see how the truck looks with the bed installed
I also did away with the rods that where keeping the 5 inch blocks stable
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 03-01-2015, 09:24 AM   #27
Katrina/10
Katrina/10's Avatar
Re: ride height
I think you have made the truck look a lot better!
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-01-2015, 04:14 PM   #28
_Ogre
_Ogre's Avatar
Re: ride height
agreed, it may drop the back end an inch or 2 with the full bed on there
shop air compressor timer
Old 03-01-2015, 04:21 PM   #29
57chevyman
57chevyman's Avatar
Re: ride height
If that's the case And the back ends up too low with the full bed installed, will I need to put a small block back in, or can I shim up the back of the bed to even it out ? I'm also installing a 16 gallon rear fuel tank. Hopefully the 9 leaf springs will work in my favor and keep the back from going too low.
Frank
1957 Chevy 3100
Old 05-30-2015, 11:45 PM   #30
57chevyman
57chevyman's Avatar
Re: ride height
with 2" drop spindles in front, and 5" blocks removed from rear....
Frank
1957 Chevy 3100
Old 05-31-2015, 08:45 PM   #31
thotfulspot
Re: ride height
Much better looking. Blocks are an accident waiting to happen. I've seen too many full size trucks spit out blocks offroad. Instead of just removing leafs it's best to find a good spring shop to build you a set at the correct. Extra leafs don't always mean it will ride worse. I've built a few Jeeps with custom spring packs and it makes a huge difference in the ride quality. When doing custom springs a good shop will measure the weight front and rear on a truck scale and build the new spring packs to match the weight. It's not all that expensive compared to reworking the rest of the suspension to try to use too heavy of springs.
thotfulspot is offline   Reply With Quote
Old 06-01-2015, 01:07 AM   #32
Coupeguy2001
Coupeguy2001's Avatar
Re: ride height
Just for grins, do some research on line, and find out how much an air conditioner kit weighs for your truck, buy a bag of concrete, make it weigh the same as the kit, double trash bag it, set it on the front of the engine with some strips of wood, close the hood and see the new ride height.
All you might need to do is just add air conditioning, then adjust the rear to suit.
I wanted my truck a little lower, so I bought some steel bar stock, and made some rear shackles that were an inch and a half longer. They fit perfect.
On the front, I installed a subframe. I adjusted the front with the "horse shoe" spacers under some big block springs.
Since your truck already had the later suspension, you can also get the lowered springs if they don't bottom out.
Coupeguy2001 is offline   Reply With Quote
