04-24-2015, 12:55 PM | #26 |
Re: designed drop trailing arms
Why the fixed poly & not their swivel joints? The thickness/stiffness of the construction of your arms w/the poly bushings are going to have more binding vs OE arms/bushings.
04-24-2015, 05:39 PM | #27 |
Hey scoti. I understand your concerns. I'm using 3/16 material and not 1/4 like I first said. Also there swivel joints are more then twice the price. All I would have to do is order some swivel joints if these don't workout but I would like to try them first. I'm honestly thinking I'm going to be fine but you could be right.
04-24-2015, 05:42 PM | #28 |
Started to weld one of them up today
04-24-2015, 05:44 PM | #29 |
Another
04-24-2015, 05:45 PM | #30 |
It won't let me post more then one pic at a time.
04-24-2015, 06:18 PM | #31 | |
04-29-2015, 12:56 AM | #32 |
More progress
04-29-2015, 07:51 AM | #33 |
I'm watching this one, going to bag it this summer. Looks awesome.
04-29-2015, 01:14 PM | #34 |
I like what i see so far
04-30-2015, 02:02 AM | #35 |
Here is one more weld picture and a picture of one trailing arm almost done!
04-30-2015, 08:37 AM | #36 |
Those arms look cool, and your welds are grade A!
04-30-2015, 09:13 AM | #37 |
dazed and confused
Nice!
members met: redbaron69, billsbowtie,nc67 |
04-30-2015, 11:47 AM | #38 |
very nice! curious about the pricepoint on these? and do they allow more clearance with the frame for bagged trucks?
04-30-2015, 03:48 PM | #39 |
Never Ending Projects
Very cool idea. I am not an engineer but I would be concerned with how thin the area behind the spring mount and axle kick up might be. Without having a pivoting joint in the front (like suggested above), all of the axle twisting is likely to get concentrated in this area and eventually could fail. That would be very bad at speed. Just my opinion. Either way, nice fab and welding work!
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-06-2015, 03:08 PM | #40 |
I honestly see no way this will fail. If this was on a 4x4 where there is a ton Of travel I would be going a different route. But with a slammed truck trying to get a couple more inches that only has a few inches of travel with a small notch I do not see a problem. I'm confident is my welds and fabrication. But that's my opinion.
05-06-2015, 03:11 PM | #41 |
Both are 98% done. Just need to make a little piece to fit behind the spring/bag mount.
05-06-2015, 03:12 PM | #42 |
One more pic of both trailing arms.
06-02-2015, 10:32 PM | #43 |
well the trailing arms are done and installed.
no issues on the install and the truck drives great. in the end the trailing arms lowered the truck just under three inches. here are a couple photos of the install and truck afterwards. |
