Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-18-2015, 08:52 PM   #26
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: All that glitters isn't gold
Looked at the other dead lifter. Its was the intake. The new fail is the exhaust side. In wondering if the lifter didn't hang shut, seem to be an issue with comp retro fit lifters?
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-18-2015, 09:13 PM   #27
HemiChallenger71
HemiChallenger71's Avatar
So these are comp retrofit hydraulic roller lifters?
Was the rocker arm loose on this lifter when you took it out?
The rest look 100% perfect?
HemiChallenger71 is offline   Reply With Quote
Old 01-18-2015, 09:35 PM   #28
KQQL IT
At the body shop.
KQQL IT's Avatar
Yes the retro fit comp cams lifter. The rest looked ok.
Nothing was loose.
Old 01-19-2015, 09:48 PM   #29
KQQL IT
At the body shop.
KQQL IT's Avatar
My next question is are those comp cams lifters?
Called them today and they said said they use a clip or E ring retainer.
This creates more questions than answers...
Old 01-23-2015, 10:09 AM   #30
hjewell2
hjewell2's Avatar
I had that happen once as well checked the oil like always before running down the track (it was very sunny that day) and I seen gold sparkles in the oil . Loaded it back up on the trailer went home cut open the oil filter and got sick to my stomach. The culprit was a broken valve stem no noise just a little lifter click on start up and went right away, no loss of oil pressure but made a mess. had to clean the block which meant disassembly. What a pain.
hjewell2 is offline   Reply With Quote
Old 01-23-2015, 10:51 PM   #31
Marv D
Registered Truck Offender
Marv D's Avatar
I had a cam grinder tell me Comp claimed their SBC retro hydraulic roller lifters were Morell. But when I received them they didn't look like the ones I took out that were also supposed to be Morell. Wish I could tell you what Morell and /or Comp really looked like.
Like anything that builds a internet reputation and doesn't have a storefront name (i.e. Morell lifters) just supplies MANY storefronts with lifters to re-box. You really have to be carefull in the claims.
That said... if you can get a real set of Morell's you should solve the failed lifter problem,, ASSUMING it's the lifters problem and not something else causing the lifter to fail.
Obviously lifters aren't bronze so what has failed is still a mystery???
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-24-2015, 01:34 AM   #32
KQQL IT
At the body shop.
KQQL IT's Avatar
The retainers appear to be brass. But with history of this engine and passes. I'm pulling it out.
New rods and pistons.
Some port work.
Springs lifters and what ever else is suspect and beat it like it owes me money...
Oh yeah freshen up the th400 and get a better converter.
Old 01-24-2015, 01:38 AM   #33
KQQL IT
At the body shop.
KQQL IT's Avatar
Oh and comp cams offered a new set of lifters at a deep discount.
The power of social media...
Old 03-08-2015, 02:22 PM   #34
SCOTI
SCOTI's Avatar
Is that 'deep discount' worth the risk of another failure (possibly one much worse)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-08-2015, 02:48 PM   #35
hotrod 80
mini truck racer
hotrod 80's Avatar
I have never had any problems with competition cams at all .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-08-2015, 02:57 PM   #36
KQQL IT
At the body shop.
KQQL IT's Avatar
The new ones are a different design, have a different retainer. Its a snap ring vs a pressed in brass retainer.
If the cam isn't hurt and the springs are junk, I can't blame the lifters either.
The 400 did have 100+ passes and 5/6k+ miles.
At this point it's still in the truck, and I'm kind of done with it.
Old 03-08-2015, 02:58 PM   #37
Hollow65
Hollow65's Avatar
I cruise mutiple forums and people have been complaining about the comp stuff lately. Like stated earlier I would hunt for some true Morells. I've had good luck with my lunati, no track passes but I abuse my truckevery time I drive it.
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 03-08-2015, 07:38 PM   #38
KQQL IT
At the body shop.
KQQL IT's Avatar
Those are 10 years old. Or so
Old 05-01-2015, 11:43 PM   #39
KQQL IT
At the body shop.
KQQL IT's Avatar
Well, it's gone to Lawrence machine in Hanford.
Some better rods and fix what needs fixing and whip it like a rental car.
Old 06-06-2015, 12:36 AM   #40
KQQL IT
At the body shop.
KQQL IT's Avatar
Comp cams sent me an Email $100 off summit price for a set of there short travel lifter hydraulic roller.
So some callies comp star rods freshen up the heads, new springs valves clean up the boogers.
Line hone zero deck and put it back together.
