01-13-2015, 12:40 PM | #26 | |
Re: late 90's vortec 3500 ?s
-I did misunderstand about the cam. I thought I read that you were putting in a larger one. My apologies. -It is virtually impossible to tell by sight the difference in a stock distributor gear for a roller cam and a non-roller. They do need to be compatible or you may have issues. There is a lot of reading available out there, but much of it is on aftermarket cams. As inexpensive as a distributor gear is, to me it is cheap insurance and not worth the risk. The Camaro/Corvette reference is just an easy way of finding an application for a stock distributor. -Still not convinced about 4x2 vs: 4x4. This article from Super Chevy talks about 1/2 ton being different than some 3/4 and 1 ton castings. http://www.superchevy.com/how-to/97458/ I was-and still am-under the impression that they are all the same combustion chamber. Also the better/worse flow myth has been debunked. http://67-72chevytrucks.com/vboard/s...d.php?t=315686 and other places. Again, not trying to start a war. Just wanted the OP to do more research.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
01-13-2015, 12:52 PM | #27 |
The original spider injection system that came on most of these models was a single piece, which meant that if an injector went out, (and they usually did from what I have read), you had to replace the entire unit. However, most parts houses now sell a unit with where the individual injectors are removeable. I had to do the one on my tahoe, luckily the unit had already been replaced so I only had to buy a couple of $65 injectors rather than the $400 complete unit.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
01-13-2015, 12:53 PM | #28 |
I apologize also as I wasnt tryin to come off as a know it all.
They only made 90 million small blocks!! :-) The inspection of said cam gears was done by myself and a seasoned machinist with calipers and mics. We evn measured the pitch of the gears, depth, and crown. Unless its the MATERIAL thats different, that I wouldnt know. Its all good bro, we're all learnin. That said, I wouldnt recommend doing this to a fuel injected engine cause your really takin a step back. I did it just to say I did it. |
01-13-2015, 01:05 PM | #29 | |
Back to the point... I do want FI, and I do want the O.D. trans, I think that with FI and some engine mods I can really make this truck a whole lot of fun. I would like to find a ecm that allows for 2 maps so I could have my power/race map, and my fuel economy map.
01-13-2015, 01:10 PM | #30 | |
My budget is cheap as possible. If I buy an ls motor, it will likely end up in my 2001 sierra... I have had a hard time finding an ls complete package for under 2k in my area. And that is for a wrecked truck/van that has over 100k on it. I can find a running registered truck/tahoe/van with a 5700 in it for 1000, yank the power train and sell the rest. Either way i will be pulling the motor apart and doing some refreshing/inspection/installing, but the price point to start is a lot better with the late 90's stuff and I get true closed loop FI. I have had a number of vehicles with TBI and I wasn't overly impressed.
01-13-2015, 01:17 PM | #31 |
quick note, if you guys have never seen a power commander map, this is what it looks like.... SOOOO MUCH ADJUSTMENT
01-13-2015, 01:27 PM | #32 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-13-2015, 01:37 PM | #33 |
Well I'm basically in your area and if you can score a rig for a grand do it I haven't looked a lot but I haven't seen one. I will agree people around here are very proud of the LS stuff.
Also don't confuse it as a 5700 I'm still pretty sure 5700 is an LS car engine like the 6000 and 7000 This is a route I would seriously consider going myself when the time comes so please share your findings on ecm stuff wiring and programming. As for TBI yeah maybe it's no house of power but I have 300 k on my 93 and it still gets 17 mpg and gets me around just fine. Again my train for considering it is simplicity. |
01-13-2015, 01:40 PM | #34 |
Cheap and easy.
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
01-13-2015, 03:27 PM | #35 |
Was planning an ls swap for my 72, but my buddy sold me a great running 98 for 1200. I plan on using the motor and trans as well as the gas tank/pump and driveshaft (1 pc). Was trying to find info on swapping out the front crossmember and front suspension, but no one has answered.
01-13-2015, 03:47 PM | #36 | |
As far as roller cams needing compatible distributor gears, you are right they do need to be compatible. GM uses a hard steel cam and needs a melonized distributor gear. If you are talking aftermarket, some/most nowadays are pressed/melded together 2 pc cores with iron distributor drive gear and require flat tappet style compatible distributor gear. |
01-13-2015, 05:40 PM | #37 | |
I have a Howell harness on my Tuned Port. Very well made and terminated. I have another brand in another swap with cheap tiny wire and no loom. I saved $100-or did I?
01-13-2015, 09:34 PM | #38 | |
if your repining the 96-2000 black box pcm harness for the 411 pcm swap you will need to get the injector harness when you pull the 411 pcm from the salvage yard. old school efi makes a stand alone 411pcm vortec harness for around $600 or you can google 411 pcm swap the find a guy who goes by lextech on most forums and get the pinout from him just research 411pcm swaps for a few days and you should be able to find plenty of info on them
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
04-26-2015, 02:47 PM | #39 |
Thread Wizard Since 2002
67, I am looking into beginning this exact modification starting in a week or two. Just bought my 99 Burb donor yesterday. Did you have fitment issues with the factory manifolds or just decide on those ones since it was out? Did you run into any other surprises along the way, so far? I guess swapping this quazi old tech into our trucks has become far surpassed by LS swaps and it's actually tough to find much information on the actual process of the L31 swap. Thanks!
--70 C-10 Longbed --71 C-10 Longbed --72 K-20 Longbed --74 C-10 Shortbed --86 Toyota Tercel (His Driver) --05 Chevy Trailblazer (Her Driver) |
04-26-2015, 03:51 PM | #40 | |
I have always been a fan of headers. Used manifolds look so nasty to me. Just my preference. I hear that the stock manifolds do fit though. There are others running this combo, I know member johnt71 has stock manifolds although he's not active Anymore. Search johnt71 should turn up his thread. Still have not started mine but getting closer.
04-28-2015, 01:49 AM | #41 |
Cool! Looks good, man. It looks like you did away with that pesky fitting on the intake for the hose that goes to the heater core and replaced it with a standard type (barbed?) fitting?
Those factory fittings with the plastic, snap in piece are such a pain.
