Old 02-17-2016, 04:58 PM   #26
chase@ridetech
chase@ridetech's Avatar
Re: RIDETECH Coilovers on a 73-87
Originally Posted by G8DAN View Post
Are the shocks adjustable? Like your HQ shocks?
The coilovers are height adjustable. The HQ version also has adjustable rebound dampening.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 02-17-2016, 05:03 PM   #27
G8DAN
G8DAN's Avatar
How much of an increase is it to get the HQ version? Also how much caster do the control arms add?
G8DAN is offline   Reply With Quote
Old 02-17-2016, 05:12 PM   #28
chase@ridetech
Originally Posted by PowerdbyChevy79 View Post
are yall planning on making a crossmember with rack and pinion I love the ridetech but truth be told I dont like having to use the unisteer setup if I used the ridetech.. its the only reason I haven't pulled the trigger on the coilover kit yet..so im patiently waiting..
As of right now we are not planning on building a crossmember. You don't need to use a unisteer rack with our kit. Are you wanting to get rid of the factory style steering box?
Chase Mundy
Old 02-18-2016, 03:39 PM   #29
PowerdbyChevy79
PowerdbyChevy79's Avatar
yes sir.. I want to go with rack and pinion
1966 C10 "Mary"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1976 C35 Sierra Grande "Mr. Harvey"
1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339
1982 C10 Silverado "Lucy"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
Old 02-18-2016, 03:41 PM   #30
Robert8096
Robert8096's Avatar
Got a rear coilover setup for the rear?
Robert8096 is offline   Reply With Quote
Old 02-18-2016, 03:42 PM   #31
PowerdbyChevy79
your coilovers coupled with rack n pinion will make the truck handle nicely..thats what im after.. ive installed your kit in a 68 and installed the unisteer kit and it handles like a dream.. but im not a fan of the looks if the unisteer kit..i don't like that arm that sticks out..
1966 C10 "Mary"
Old 02-18-2016, 03:51 PM   #32
PowerdbyChevy79
Im working on this 67 right now..see tht arm that sticks up.on the driver side...i domt like that..with a built crossmember i wont have that... but i gotta say your coilover kit is pretty sweet..
1966 C10 "Mary"
Old 02-18-2016, 03:59 PM   #33
chase@ridetech
To go to the HQ from and RQ it adds 100.00.
Also, the arms are designed to set the caster at 5 Degrees.
Chase Mundy
Old 02-18-2016, 04:01 PM   #34
chase@ridetech
Not a bolt-in one yet for the square fender trucks, but we do plan to do one in the future.
Chase Mundy
Old 02-18-2016, 04:03 PM   #35
chase@ridetech
Your Frame is looking good!
Chase Mundy
Old 02-18-2016, 06:37 PM   #36
PowerdbyChevy79
thanks brother
1966 C10 "Mary"
Old 02-19-2016, 02:30 PM   #37
Robert8096
Robert8096's Avatar
Old 02-19-2016, 03:26 PM   #38
Houston Ben
Houston Ben's Avatar
Excuse my ignorance on coil-over setups, but do these require a sway bar as well?
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 02-19-2016, 05:16 PM   #39
chase@ridetech
It doesn't require a sway bar, but I always suggest using at least a front sway bar.
Chase Mundy
Old 02-19-2016, 05:31 PM   #40
HafTon
HafTon's Avatar
You don't have to have a sway bar but you will have a much better ride with one. Here is my 75 with Ridetech coilovers on the rear and front. First time attaching a pic here goes...
[ATTACH][ATTACH]Name:  1975 Front 5050.jpg
Size:  55.5 KB[/ATTACH][/ATTACH]
HafTon is offline   Reply With Quote
Old 03-04-2016, 11:35 AM   #41
chase@ridetech
I like your sway bar location.
Chase Mundy
Old 03-04-2016, 11:49 AM   #42
HafTon
HafTon's Avatar
Thanks. It made sense for this application on the '75 frame and the diff brackets. One bracket for coilover mounts, bars, and swaybar.
Old 04-24-2016, 02:38 PM   #43
smills413
Hafton-- which upper/lower control arms do you have? Stock crossmember? What 4 link is this? Thanks
smills413 is offline   Reply With Quote
Old 04-25-2016, 01:44 AM   #44
TurboLS
Not trying to steal this thread from Ridetech, but you should check out PorterBuilt. I am currently installing their full front and rear kit in my 76. The kit comes with Ridetech Coilovers front and rear.
1976 C-10 Stepside
2005 Chevy Avalanche Z71
2008 Subaru Wrx - Modified Track Car
2012 Harley Davidson Fatbob Custom
My build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703077
TurboLS is offline   Reply With Quote
Old 04-30-2016, 12:12 PM   #45
chase@ridetech
The PorterBuilt parts are some very well built parts! I used a PB Dropmember on of my C-10 builds a few years back. You can get Ridetech Q-series shocks or Ridetech Coilovers on any of their suspension kits.
Chase Mundy
Old 04-30-2016, 12:51 PM   #46
TurboLS
Here is a question for you, does Ridetch make Fox Shocks or does Fox make Ridetech? I was under the impression that they were 2 separate companies. My Ridetech Coilovers have Fox logos on them.
1976 C-10 Stepside
Old 05-31-2016, 11:28 PM   #47
chase@ridetech
Great Question! Fox builds our shock cartridges. Fox builds world class monotube shocks. We make the mounts, determine valve codes and select internal components. We also test and tune each application. When you buy a Ridetech shock, you buy a service that provides an application specific, painstakingly tested and tuned Fox shock.
So I guess the best answer is both!
Chase Mundy
Old 07-16-2017, 05:44 PM   #48
bpmathy
I know this is an older posting, but I just finished my 1971 GMC with the ridetec coil overs and the Rack and Pinion for No Limit Engineering. played a bit on alignment but it handles great.
bpmathy is offline   Reply With Quote
Old 07-18-2017, 12:41 PM   #49
moregrip
moregrip's Avatar
Are parts available separately?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 07-19-2017, 06:37 PM   #50
bpmathy
The coil over kit and coil overs themselves are separate. I got them from Jegs The rack and pinion is totally separate. I ordered it directly from No Limit Engineering. The parts to get the steering wheel to the rack I got through Summit, only because they were quick.
