#26 |
Re: 69 C10 Prerunner project
This is that c20!
#27 |
#28 |
#29 |
I'd say, follow the other guys lead in the previous budget lift post if that is what you are looking for.
Terry Soon to be retired and moving to Bristol, TN. |
#30 |
I'm not sure how to find it or post a link, but member dinos63 has a very cool prerunner style, bagged (but lifted- with a huge amount of travel) 60-66 pickup. This truck would be a great inspiration for your build.
'70 GMC SWB step-side- 454, 4 speed, air bags (in progress) '09 CTS-V M6 '03 Sierra SWB Z71 '82 Yamaha Seca XJ650R Turbo! '04 Yamaha FZ6 |
#31 | |
I'd MUCH rather see someone take that truck and maybe shorten it. Or just restore, or rattle can detail, or whatever just don't cut it up for a pre-runner. But, in the end, it's his truck, his tastes, (not mine), and his call. Yes, I'm an Arizona Old Fart myself. LOL |
#32 | |
What I don't see addressed in this kit is steering geometry. As you can imagine, with the lower a-arm dropping so low, the spindle is going to drop as well. IF the tie-rods will adjust far enough to reach is in question (you will need longer tie rod ends), and even if they did they would be a such an acute angle that bump steer would be like super, super bad. You hit a bump and the steering takes on a mind of it's own, especially while not going straight, but going straight hitting bumps/dips/rises it's gonna toe in and out like nobody's business. Study this: https://www.google.com/search?q=bump...4LoBQ#imgdii=_ Maybe this company offers the tie rod modifications necessary to correct this condition that would exist if not addressed. The drag link/tie rods would need to keep their existing horizontal configuration thus a vertical link between the tie rod and the spindle would be needed. Not sure if that much of a link/adaptor is feasible. The picture below illustrates the fix for bumpsteer but in this case it's on a lowered vehicle, lowering can create the same problem so the spacer goes in the other way under the spindle. In your case, it would need to go in atop the spindle. You would be much better off to use modified/custom spindles to achieve the desired lift as that would keep the tie rod/spindle relationship stock and minimize bumpsteer. You would lose the extra suspension travel, but IMO you can't really have both worlds without extreme compromise and/or added cost. Whatever kind of rear axle you have, coil or leaf, you could likely just flip the axle housing over and/or install blocks, shackles etc. to get your rear lift. You would still have to address pinion angle (angle shims on the axle housing), and possibly driveshaft configuration. |
#33 | |
Yeah I know what you guys mean and no disrespect but yeah I'm not trying to blow is up to a full on prerunner I just want a simple lift. But I'm tired of seeing this trucks just lowered and not to be mean but when you guys lower you truck and C notch it and cut the bed up to make it fit, isn't that considering " cutting it up" I don't want to start an argument I just be yell at by some many people about how bad of an idea it is. But hey a least I can say it's something different. But right now my truck is on hold because my race bike motor took a 💩 and now I have to fix that lol. |
#34 |
But thank you guys for helping me I really appreciate it!
#35 |
But know that my budget is low how do you think I can be able to make my truck look like that? I want to run almost the same set up with the same amount of clearance. I was gonna say just to put a 2 inch spacer in the front and 1.5 inch spacer in the rear of the truck? |
#36 | |
Stick to your guns and do what YOU want and be happy. I hope you didn't think I was yelling at you I just said what I said but in the end it's your truck not mine. Yes, cutting is cutting raising or lowering. I hope you read what I said about steering geometry, as if you did you will realize I will help you no matter what you want to do I just want you to be safe and happy. Hope your racing bike does not eat too far in your wallet. Be safe. ![]() |
#37 | |
I think for now I just what to make it look like that c20 I posted up. I really like that c20 how it looks so I think I'm just gonna use a 2 inch spacer and a 1.5 spacer in the rear coils. Thanks for all the advise I really do appreciate it. Yeah right know I have my bike blow out rebuilding the motor. |
#38 |
This is how it used to look like lol. Dam motor had to go out when I decide to start my project truck. Lol
#39 |
Sesame Street, which one of these things is Not the same?
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#40 |
![]() Join Date: May 2014
I think what you're doing with the truck is a great idea. In that condition there are dozens of people on this site that would've bought it just to part out.
#41 |
#42 |
Hey guys so you know how I said I want to make my truck like that c20 I posted. So I text the guy with the c20 and ask him how it lifted the fro t and he told me he use a 2" coil spacer. But my question is instead of using a coil spacer can I use a 2" lift coil from a 88-98 c1500? And just you a ball joint spacer in the front?
#43 |
Airbagit.com offers a 3 inch lift kit for the 67-72 c-10 2wd. But only buy there upper a-arms and use a 3" lift coil spacer. The springs they offer in the kits do not fit the upper coil bucket and make a ton of noise. They require a 73+ upper cross shaft and can be bought at any auto parts store. With the coil spacer compared to the spring they offer I lost maybe 1/2 inch. It's on 30" BFG's for now, I could of gone 31 or 32 with no problems.
#44 | |
Hey if you don't mind can you post a picture of the upper a-arm? |
#45 |
I will post a picture a little later today.
#46 |
I was able to get outside of work real quick to snap a pic. Here ya go.
#47 |
My dad took a pic of this one at a race in Mexico, I think the San Felipe 250.
#48 |
#49 |
I used the stock lower a-arm and the upper goes right into the stock spindle. the a-arm came with a ball joint in it that bolted right up. been in the truck for about 4 years now no real issues. Make sure you don't order the springs from them, they are junk and don't fit right.
#50 | |
I would do a kit like this for the front.... http://www.roughcountry.com/gm-suspe...kit-231n2.html Lift spindles will help keep steering geometry in check & shouldn't require a cobbled spring + spacer or super stout tall spring to raise the truck. These kits are adaptable w/some parts swapping which can be done w/used parts that help keep within a budget. To adapt 88-up spindles, you need.... C20 lower a-arms (the 88-98 1/2 ton lower BJ fits the 6X-87 C20 lower arms). 88-98 upper BJ to the factory arms (bolt-in swap). 88-98 brakes (rotors, calipers, hoses). Then it's just a matter of adapting the tie-rods to the spindles. Read more about it here.... http://67-72chevytrucks.com/vboard/s...d.php?t=447061 For the rear, some bolt-on spring spacers could be utilized/fabbed. This (the spacer method) would be acceptable in a rear coil suspension application since the spring physically bolts in @ each end (vs a spacer & spring just getting stacked on top of each other in the front). My buddys son want's a 'pre-runner' looking 68. This was my suggested approach to him as it should maintain a fairly stock ride quality.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-28-2015 at 07:30 PM. |
