#26 |
Re: 51 chevy truck 2wheel to 4x4???
Thank you, sounds easy enough. I have to pick them up them up next week when they have them ready. They are still in the truck. Will I need any other parts off the Toyota? Suck as springs front and rear??? I will be using the 77 for tranny and transfer case. Thanks again for the help.
1964 GTO 1931 MODEL A 1950 ![]() Last edited by blm64Goat; 02-05-2015 at 02:55 PM. Reason: More Content |
#27 |
I would maybe look at the steering box & linkage just in case. As for springs the Toyotas ride very nice but I'm not sure on the lengths, anything can be incorporated. I guess it depends on what you plan on doing with it as to if you want the 3/4 ton suspension or the Toyota suspension. We have pulled full cords of wood out of the woods with short bed Yotas with out any problems.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#28 | |
The Toyota front axles/ hub does not allow a CHEVY RIM to go on. The center of the rim is to small. Or is there a certain year that works?
1964 GTO 1931 MODEL A 1950 ![]() |
#29 |
I have not run into this issue before. Probably because I always run aftermarket rims and the center hole is bigger so they can be used for a variety of applications. If you want to use original Chevy rims any machine shop will be able to open the center hole to the size you need. When I run into things like this I take the parts to work and use our lathe or mill.
#30 |
wow you guys are awesome i thought i was the only one on this sight that did wild and crazy things to their trucks i turned my 69 2wd into a 4wd and all i got was most people bustin my b@lls about it nice to know there is more of us out there.
here is a few of what i did |
#31 |
Nice...Lots of work I know.... New question, I'm using the toyota axels, on the 50 frame. I am wondering if the original type front springs will support the 350 motor? The 50 truck is originally a 3600 3/4 ton. I would like to replace the leaf springs front and rear wondering what others have used. Aftermarket or Toyota or ????? Thanks
