Old 01-24-2015, 05:08 PM   #26
Daze57
Daze57's Avatar
Re: 1959 Chevy Truck Windshield Wiper Help
That is a really cool motor - is there a chance of gettin it to work ? or is it too far gone?
i think it would clean up pretty well ;
things like this i love to work on and try to rebuld - make it work again and shine up them linkages - first time i have seen this type with 2 switches .
hope you get it to function.
Daze57 is offline   Reply With Quote
Old 01-27-2015, 11:30 PM   #27
AZ59apacheguy
Hi Softpatch. Tried private messaging you, but your mail box is full. Please message me when your mailbox allows it. Thanks!
AZ59apacheguy is offline   Reply With Quote
Old 02-03-2015, 04:14 PM   #28
Softpatch
Softpatch's Avatar
little update did put the effort in making this wiper a go'r
my main problem was the on/off two speed switch was dead inside
took it apart cleaned it reassembled and glued it back together with JB weld
the transmission arms were rusted stuck IE motor stuck made smoke come out of
park switch and motor bushes nothing was damage beyond repair
but while removing the transmission arm I broke one of the park switch cam washers
ear off
repaired with JB weld
and now understand why two switches to work it Because the contacts on the park relay were worn and dirty and dirty motor contact
(live in the North Wet) the whole system got used and abused
the extra on/off switch was installed when wiper didnot want to park as designed
here are some pictures
the arms are marked L/R
used wires to hold com, brushes in to re intall motor
this is why I don't have nice things
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 02-03-2015, 04:28 PM   #29
octanejunkie
octanejunkie's Avatar
Originally Posted by Softpatch View Post
any body hear of a task force truck with two speed wiper set up.?
Mine '59 has a 2-speed wiper with a single 3-pole switch.
I plan to add a powered washer to it.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-03-2015, 04:36 PM   #30
OrrieG
OrrieG's Avatar
Nice work softpatch, JB Weld rocks, I always carry it and have used it in the boonies to get home.
OrrieG is offline   Reply With Quote
Old 02-04-2015, 01:09 PM   #31
Daze57
Daze57's Avatar
good job softpatch !!!!
Old 12-23-2015, 01:37 AM   #32
dew468
dew468's Avatar
lot of good info in this post and wanted to share
this is my 1959 chevy Viking and I'm renewing the wiper system
here some pictures of the original wiper set up
In truck
.that's my exact wiper motor setup. I need the arm mounts with the eccentric linkage. if anyone has an old motor with this, let me know if you want to get rid of it, or just the arm mount parts. Thanks, Doyle
removed wiper The mount
I couldn't find a date on the wiper but on the heater box there is a date 9-58
I must be special because the wiper has two switches.? .. for more power? must be
dew468 is offline   Reply With Quote
Old 12-24-2015, 10:17 PM   #33
Softpatch
Softpatch's Avatar
sent you a message...Sp
Old 12-25-2015, 07:52 PM   #34
Coupeguy2001
Coupeguy2001's Avatar
I bought a firewall out of a 58 AZ government truck, and it had the single switch.
I sold most of the stuff I didn't need, and don't remember two switches.
Coupeguy2001 is offline   Reply With Quote
Old 12-26-2015, 01:47 AM   #35
dew468
dew468's Avatar
Softpatch, the piece that broke is the piece I need for mine. sorry for the trouble, but thanks for your help. Doyle
Old 12-26-2015, 08:58 PM   #36
Softpatch
Softpatch's Avatar
no problem good luck
Old 02-24-2016, 12:36 AM   #37
dew468
dew468's Avatar
FYI, that switch with the two terminals (on and off switch) works as a ground. took me awhile to figure that out. 12V goes directly to motor.
Old 08-11-2016, 01:39 PM   #38
dew468
dew468's Avatar
Non-working do to rust
my father said one switch was (on-off) the other was for two speed
i asked if he was sure after 37yrs he said best he remember
but I'm skeptical about he's answer
Sp
I have factory 2 spd wipers on my 59, and an extra motor also. most people don't know but they work on a ground switch. the hot goes directly to the wire panel on the motor itself (it took me forever to find that out). As far as I could find out there are no replacement switches made due to it being a switched ground to make it work. hope this helps, Doyle. (dew468)
Old 08-14-2016, 09:58 PM   #39
dew468
dew468's Avatar
my 59 Apache only has 1 switch and it has 2 blade connecters and a ground from the switch base to the motor. they may have changed during mid 58 like the other things they changed. who knows. mine work and i'm a happy camper.
