Old 12-22-2003, 06:49 PM   #26
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
If the brake light comes on, what is it indicate?
That the brake light is working, of course!
Seriously, though. I believe it's just a low fluid warning. It could be a pressure sender, but I'm not 100% certain.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 12-22-2003, 07:05 PM   #27
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Usually it indicates that the fluid is low or the rod is bottoming out. If it bottoms out it is usually out of fluid or out of adjustment. Someone correct me if I'm wrong. I don't remember where I got my tach, but I bought a repro and its a beautiful thing. Just wish I could figure out how to make the lights look red at night like those pontiac dashes. PS, painting the bulbs does not work. hehe.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-22-2003, 07:10 PM   #28
bigger=better
bigger=better's Avatar
So in my '68 sub with gauges I could just swap in the tach itself ?
'68 GMC Sub 4X4 new project
'69 Pontiac GTO 20 year project
Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from.
bigger=better is offline   Reply With Quote
Old 12-22-2003, 08:15 PM   #29
red71cheyenne
Back in the sticks
With a little cutting and new lens and wiring, yes. You have to cut out the hole for the tach lens in the black part of the dash, then cut a hole for it to mount in in the outer part of the back as well. Screw it to the plates, wire it, and off you go. I also bought a new tach type printed circuit, but your could get around that with a little more work as well. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 12-22-2003, 08:31 PM   #30
rage'nrat638
rage'nrat638's Avatar
42.00 for this baby
rage'nrat638 is offline   Reply With Quote
Old 12-28-2003, 03:52 AM   #31
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
To make your lights glow red, take apart your insterment panel, and paint all that funny looking green metal white.
Then reasemble it all with red lights.
Old 12-28-2003, 05:01 AM   #32
dinnut
dinnut's Avatar
ur smart!
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-28-2003, 09:41 AM   #33
Andy4639
Old member
Andy4639's Avatar
Question BIG TRUCK TACHS
I was just reading this and noticed no one said anything about the gear driven tachs that came in them. I now for a fact that they had them because I bought one out of a truck in the yard years ago before I found my electric one. If I remember correct it was a 427 motor, what the guy said was a heavy duty motor. I asked my dad what that meant and he said it just meant more metal between the water passages. (DAD) 31 years in Chevy trucks. Retired now. He work at the Chevorlet ZONE Office in Charlotte NC.
shuttermutt,
I would think it means the same thing as it did before, just has the other red lens over the light now. I would think you could peel the lens off if you are careful enough and swap them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
