Old 02-03-2015, 10:54 AM   #26
Mr_Shamrock
Re: DJM, or any 3" spindles questions
This thread has a picture that might help...
http://67-72chevytrucks.com/vboard/s...ad.php?t=84318
LifeTime GM guy. Current collection...
2006 Z-71 Suburban
1985 C-10
1990 Suburban
1966 C-10 (me & dad's project)
Mr_Shamrock is offline   Reply With Quote
Old 02-03-2015, 01:55 PM   #27
gasmn1620
hmmm....the brake lines seemed a bit short. I should probably just buy new ones and install them when I tear this thing back apart.
gasmn1620 is offline   Reply With Quote
Old 02-03-2015, 03:15 PM   #28
kevinr1970
Hey Mr. Shamrock, is your Tahoe Limited stock height?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-03-2015, 05:30 PM   #29
Mr_Shamrock
Yes, I have contemplated putting it down 2" all the way around, but haven't yet.
2006 Z-71 Suburban
1985 C-10
1990 Suburban
Old 02-06-2015, 11:44 AM   #30
MikeB
MikeB's Avatar
Please let us know what solves the problem. I'm very curious.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-06-2015, 12:42 PM   #31
gasmn1620
haven't had time to tear it apart again yet. Probably get into it next week one evening. My son had baseball camp this weekend so I'm going back home for that.
Old 02-09-2015, 10:45 AM   #32
Custom06
Custom06's Avatar
I'm having a similar problem with some McGaugy's spindles. Ever since I installed them my right front tire and wheel sits too far in the fender and the the driver side seems to be too far out and very noticably so. I'm not sure if the spindles are the problem or not but I've never seen this before.
Custom06 is offline   Reply With Quote
Old 02-09-2015, 12:46 PM   #33
gasmn1620
sounds like you have a camber problem. Did you change ball joints? Did you take the control arms off?
Old 02-09-2015, 01:06 PM   #34
Custom06
Custom06's Avatar
I redid my whole suspension and steering. All bushings, ball joints tie rod ends etc. . . . . It don't look like a camber issue but what do I know. The tire and wheel looks to be straight up and down and was aligned after all was done.
Old 02-09-2015, 04:08 PM   #35
gasmn1620
did you remove the upper control arms? Dip you change the upper control arm cross bars? Are you sure all the camber spacers went back where they belong?
I would take it back where it was aligned. If one is sitting outside the fender you have too much positive camber and the other would have to much negative. If those wheels and tires are set correctly you have bigger fish to fry.
Old 02-09-2015, 04:12 PM   #36
MikeB
MikeB's Avatar
McGaughy's drop spindles move the wheels out a little, but I'm sure it's equally on both sides.
With the steering wheel centered, I'd measure the distance from the lower control arm shaft bolt to the tire sidewall, or to the backing plates. That distance should be the same on each side, assuming the wheels are truly centered, and have the same width and backspacing. If it is the same, the problem isn't the spindles.
Mike
Old 02-09-2015, 10:40 PM   #37
gasmn1620
got the passenger side on tonight after a lot of grinding on the slot where the caliper slides in.... then bending the brake line and removing the inner fender well. Had to modify the battery box and I'm gonna have to relocate the radiator overfill bottle. AAny ideas on that?
Old 02-10-2015, 07:56 PM   #38
piecesparts
Parts and more parts
piecesparts's Avatar
How much drop are you putting on the truck? Did you change out the spring, too? I put 3" drop spindles and then dropped the spring a 1/2" and I still have more than enough room, without taking the out of the truck.
You appear to have a 3" drop spindle and a 1" drop spring combination.
Frank
piecesparts is offline   Reply With Quote
Old 02-11-2015, 12:33 PM   #39
gasmn1620
3" spindle, 3" spring, 265/35/22 tires on 22x9.5 wheels. I'm ordering some trailer fenders this weekend. Going to go ahead and cut out the inner fender area, weld in some sheet metal and then put the trailer fenders in. I drove it home after doing the drivers side and it only scrubbed a couple of time on pretty significant bumps. I rolled the fenders a good bit. I'll probably end up cutting some of the fender lip off, welding in some sheet metal, and then smoothing it out so it's not a sharp edge near the tires. I might as well start working on all of this since I'll be bagging it soon anyway.
Old 02-11-2015, 12:34 PM   #40
gasmn1620
it actually sit a bit lower since the other side is done. I measured 27.5 inches from the ground to apex of the wheel opening in the fender. about 1.5 inches between the top of the tire and the bottom of the inner fender.
Old 02-11-2015, 12:48 PM   #41
gasmn1620
Old 02-11-2015, 12:49 PM   #42
gasmn1620
Pic sucks..... sorry
