#26 |
Re: What to bring on 1000 mile road trip with a truck I've never seen?
First off, I want to say thank you for the very warm welcome...the fact some people are willing to help out a complete stranger means a lot.
![]() I bought a CAA (Canadian AAA) premier membership this morning so I've got a 320km tow in my pocket now. I'm planning on taking I29 the whole way from Siloam Springs to the Pembina, ND border crossing. Departing from AR midday on Friday Feb 6....my customs paperwork including the new AES filing is all in order. Adding electrical tape, coat hangers/wire, and a coil to my list of things to bring. Someone mentioned to me I should buy a boat gas tank instead if a jerry can, that way I can temporarily replace the whole fuel system up to the carb if needed, and I think that's a decent idea. Can anyone tell me what kind of car I should ask a parts store clerk for when buying a coil or HEI module? I remember from school there are 4 pin and 7 pin HEI modules and I don't know which this truck has. |
#27 |
Don't forget WD40 or JD80 which ever you prefer
![]() and the pre-work on the truck before setting off should consist of no less than: - check for leaks, - fluid levels - gear selection - engine cold start and idling - drive of and at 20mph, set it in neutral and see if it'll continue without brake's dragging. and whether it'll run straight without pulling to one side. -listen for any suspicious sounds (also when aplying the brakes, again it shouldn't pull to one side) -tire pressure! (often a forgotten part) bon voyage!
Feedback is always welcome! projects: 1969 Chevy C10 1950 GMC 100 1958 Chevy C60 Viking ratrod |
#28 |
![]() Join Date: Nov 2001
chances are that's a 4 pin module. ask for 75 chevy pickup for the module and coil.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
#29 | ||
"I ain't nobody, dork."
7 pins were later models... so anything say pre-79 should be fine.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#30 |
![]() Join Date: Nov 2004
Well, it's running in the engine pic, that's a good sign.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#31 |
a spare alternator.
also bailing wire and some good pliers.....just in case. or even wire hangers you can cut and use as temporary hangers
1967custom |
#32 |
![]() Join Date: Sep 2010
Your list and these suggestions look great. I did a trip like this from Idaho to NY when I got my truck. I had almost all the stuff mentioned here. I had mostly good luck and it was a great experience. The only trouble I ran into was that the tires were old. They looked good, so we decided to chance it. Got a nasty blowout on day 2 and ended up buying 4 new tires. Other than that it was great.
Best of luck on your trip! I hope you have a great time like we did (without the little bit of bad luck). |
#33 |
Bring another chevy!
#34 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
You are going to go right by LMC Truck and Classic Truck,and if it was me I'd be filling up with parts, both are right around Kansas city.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#35 |
Thanks Already Gone, another good idea. I know I'll be needing new rockers...
Packing my toolbag tonight. Does anybody know what size socket I'll need for the front spindle nut? 1-1/8" maybe? Also picked up belts, 4 pin HEI module, coil, front wheel bearings, and a pair of U-joints while I was at work today. ![]() |
#36 |
Manuals are very good to have, even more so when they are factory and model/year specific.
RTFM ... Read The Factory Manuals... download 'em here
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
#37 |
![]() Join Date: Dec 1999
I just noticed. This truck has no mirrors. No Side or Rearview. Might need to stop in KC at one of the parts places and get something. Or maybe the seller has some.
I went back and checked the ebay listing to confirm. Might want to take one of these: ![]() |
#38 |
I think this is a great idea, also take at least a couple of fuel filters, looks like it has an inline filter so that is an added benefit. The fuel filter has been the biggest pain I have had with my original truck that sat for an extended amount of time, too much rust in the tank. I could only make it about 100 miles before the q-jet filter plugged, granted its small but still.
#39 |
Restoring it $200 at a time...
Two choices in KC for restoration kinds of parts:
LMC (15-20 minutes SW of downtown) 15450 West 108th Street, Lenexa, KS (913) 492-8756 · lmctruck.com Classic Parts of America (10 minutes NW of downtown) 1 Chevy Duty Drive, Riverside, MO (816) 741-8029 · classicparts.com I'm 30 miles west of KC. Have a great trip. Loren
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
#40 | |
have all your T's crossed and I's dotted and you are good to go... Darren.
1967 C10 Shortbox 1971 Monte Carlo SS buckets and console #'s car 1970 350 Monte Carlo bench seat 1970 El Camino SS |
#41 | |
He PM'd me and had all his paperwork done. What is an Inter Border Crossing Inspection, I've done lots of importing and never heard of such a thing. Are you talking about the RIV Inspection for vehicles 15 years old and newer? Sounds like you may have had a bad experience while importing something.
#42 |
He should be on the road now. I hope he posts along the way.
#43 | |
yes so just a bad time but could see them possibly being sticklers on his truck. Darren.
#44 |
I am a Referee of life.
You need to read this thread before any road trip. It will help you be prepared for just about any non mechanical problem you may have. Do not be drinking any liquids. I am not responsible for you spewing whatever you're dinking all over your keyboard.
http://67-72chevytrucks.com/vboard/s...d.php?t=322870
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#45 |
Brains.
Take back roads til to get a feel for it. Drive slow. Oils, coolant, brake, well all fluids, and a not so clever friend you don't mind abusing. |
#46 |
Best advice I can give ya is to look over the truck real good before setting out and have your paperwork sorted out 72 hours before you cross the border and you should be fine. I did this a couple years back when the Canadian dollar was still worth something, drove 1700 miles from Albuquerque to Alberta in a 1970c10 lol. I documented the whole trip but cant find the thread now that the search isn't working, Good Luck
#47 |
I wonder if MacGyver is still around! Him and a gum wrapper and you'd pretty much be set!!! 😄
Good Luck!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!) |
#48 |
![]() Join Date: Nov 2012
Any updates?
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
#49 |
I am late to the party but I am on I29. Greg, or anyone else, if you hear from Run Away and he/she needs help text/call if you have my number, or PM me if you don't.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#50 |
Thanks Shawn. I will do that and i still have your number. I'm surprised he hasn't posted anything yet. Maybe no news is good news.
