Old 02-10-2015, 07:20 AM   #26
502ms
502ms's Avatar
Re: Cutting Bed for Laying Frame.......Question
I did a raised floor. Strong enough to hold a human and a motorcycle or a fully dressed LS engine. Build thread in signature
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 02-10-2015, 07:40 AM   #27
502ms
502ms's Avatar
https://www.facebook.com/YoungbloodK...type=1&theater
http://youtu.be/Mxx55butwvQ
Best Regards,
Leon M.
Old 02-10-2015, 09:59 AM   #28
SCOTI
SCOTI's Avatar
It all depends on how it's done.
The original pics showed the body lift pucks & an original floor cut out between the wheel tubs. My warning was if the lift puck method is used or just raising a steel floor as a faux floor & rewelding it higher, it should be braced additionally or it can bow.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-10-2015, 11:17 PM   #29
dec010974
dec010974's Avatar
the money shot. as usher says, "i don't mind".
dec010974 is offline   Reply With Quote
Old 02-11-2015, 01:33 AM   #30
502ms
502ms's Avatar
Agreed. Not sure if you saw the pic in my post, I was showing it done on mine. Lays frame and raised bed.
Best Regards,
Leon M.
Old 02-11-2015, 02:06 AM   #31
SCOTI
SCOTI's Avatar
Yes, I saw the pic but didn't read any mention about the need for bracing. I mentioned it because I didn't want those who were asking the question to skip past possible steps in the process.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-11-2015, 07:10 PM   #32
Woodnears
While I'm no expert fabricator I was able to fashion a raised bed support in just a few hours last night for 100 bux worth of 1" square tubing. For the inner bedside panels I'm just gonna bead roll them and brake a 90 in the bottom and bolt them to he original bedside. Here's what I've got. And the middle raises to gain access to the compressors and fuel systems. I'm having some 1.5" round tube bent to support this steel bed frame. Then I'll fill in any cross pieces needed for support after that is all installed. I'll finish it all off with a hood latch to hold the middle down.
Woodnears is offline   Reply With Quote
Old 02-11-2015, 10:40 PM   #33
dec010974
dec010974's Avatar
@woodnears, I definitely want to see more pics.
Old 02-12-2015, 11:59 AM   #34
Hart_Rod
Hart_Rod's Avatar
Here's how I'm doing mine. I pretty much copied what Seth did on Olrosa.
Hart_Rod is offline   Reply With Quote
Old 02-12-2015, 12:25 PM   #35
dec010974
dec010974's Avatar
@ hart Rod, thanks for sharing. I get the Picture.
Old 02-14-2015, 10:55 PM   #36
C10agent
C10agent's Avatar
Thanks for the posting guys! Hart_rod, that last picture, I found that post on instgram and that is exactly what in was thinking.
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 02-16-2015, 01:59 PM   #37
Woodnears
Here's what I've done so far. I've been working on this here and there throughout the weekend. We just had a baby so my work will remain intermittent. I drew a side profile pattern of some bent 1.5" roll bar tubing. Bent them up and left the legs of each long so I could adjust the height to fit. Welded brackets using existing frame holes for the lower part of each leg. All I did to set the height was clamp a straight edge to the top of the upper bag mount and measured up on each leg for the appropriate height. Adding an inch to clear the line fitting for the bags. I left these straight edged in place while gabbing up the brackets to assure I was maintaining the correct height. All in all I have a few hours in it. The middle of the frame frame will fold up like a car hood to gain access to fuel tank and air ride. The forward most bed support will also double as a mount for the tanks and compressors and vu4 manifold. If you have any questions on this shoot me a message and I can provide dimensions or answers the best I can.
Old 02-16-2015, 02:03 PM   #38
Woodnears
Another shot
Old 02-16-2015, 02:05 PM   #39
Woodnears
Keep in mind I've never done much metal fab before so if you think this is too much to tackle you're are doubting yourself. I've managed to do all of this in a two car garage with minimal tools and a little ingenuity. One more of the rear
Old 02-16-2015, 05:46 PM   #40
Hart_Rod
Hart_Rod's Avatar
very nice!!!!
Old 02-16-2015, 06:26 PM   #41
C10agent
C10agent's Avatar
You guys are talented!!
Neil...............
TEXAS Y'ALL!!
Old 02-16-2015, 10:09 PM   #42
rwade
rwade's Avatar
"Woodnears", give me some info on your wheels and center caps please. Where did you get them?
Thanks, Wade
rwade is offline   Reply With Quote
Old 02-16-2015, 11:52 PM   #43
Woodnears
22" transit wheels with old beat up hub caps. The wheels come black then I painted them white and took a little white back off to reveal some black in spots. I had to fashion up the hubcap clips to fit which was the hardest part. Here is a pic of them before I took the white back off.
Old 02-17-2015, 12:30 AM   #44
rwade
rwade's Avatar
The wheels and the metal fab work look real nice. I'd like to see some pictures as it progresses. Congrats on the baby too!
Wade
Old 02-17-2015, 12:47 AM   #45
Woodnears
I really should start a build thread huh?
Old 02-17-2015, 10:56 AM   #46
rwade
rwade's Avatar
I'd love to see it but that's up to you. I like what I see so far 😀
Wade
Old 12-27-2015, 07:57 AM   #47
510ChevyC10
Question Re: Cutting Bed for Laying Frame.......Question
Did you ever start that Build thread?
Because Chevy
510ChevyC10 is offline   Reply With Quote
