Old 02-21-2015, 11:18 AM   #26
JonnyR
JonnyR's Avatar
Re: Hello, New to forum 62 c10
We got snow and school closed... Got to test fit the engine and trans this week. Need to shim the mounts. Will get pictures when they are complete.
Not sure yet what to do with trans mount. Thinking of just making a bracket and tying it to the existing torsion bar crossmember? It is Sooo close... Only issue I see (not knowing much) is might have to weld the torsion bar crossmember to give it a little more strength.
JonnyR is offline   Reply With Quote
Old 02-21-2015, 11:26 AM   #27
62 Longbed
62 Longbed's Avatar
Welcome to the site !!! Here is a picture of my 62 before I sold it ... Has the 1960 Grill in it ..
62 Longbed is offline   Reply With Quote
Old 02-21-2015, 11:29 AM   #28
JonnyR
JonnyR's Avatar
Also was able to start cleaning up the rear frame some.
Not sure yet what to do with the rearend...? keep it? or swap? or rebuild stronger? Any thoughts? Thanks in advance.
I don't think power will be an issue. Motor should make about 340hp & maybe 450tq
Have not checked ratio yet and it's an open rear
Also, received new power steering and radiator this week!!
John
Old 02-21-2015, 12:03 PM   #29
pwrbrkpadguy
pwrbrkpadguy's Avatar
I don't even know you but I'm proud of you! Great job! Wish my sons would have loved old trucks like you do.
pwrbrkpadguy is offline   Reply With Quote
Old 02-21-2015, 12:38 PM   #30
Joe Pass
Joe Pass's Avatar
I used a 64 12 bolt rear end (same width)....Rebuilt it with new bearings, axles and used a 3:42 ratio...Had to relocate the spring perches outward and reattach the pan hard bar bracket and I kept the 6lug. Lots of kits offered to do this, makes it simple and some what period correct
Name:  62 chevy 008.JPG
Joe Pass is offline   Reply With Quote
Old 02-21-2015, 01:05 PM   #31
boat
boat's Avatar
Nice job John going to be a cool ride when finished
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline   Reply With Quote
Old 02-21-2015, 02:01 PM   #32
Too Slow '90
Too Slow '90's Avatar
Great progress in a little time.
Too Slow '90 is offline   Reply With Quote
Old 03-27-2015, 06:07 PM   #33
JonnyR
JonnyR's Avatar
Quick update on the build.
Power steering box installed. The kit made it pretty easy work,
(but I did have help)
Also, got a gas tank installed. Again, thank you all for your posts with options to use different tanks. I really did not want to fill through the bed. But, I was able to find a new 65 mustang tank that had been "sitting around" for several years. So it made my decision easy.
I think it turned out nice. I used the spare tire holder to support the rear of the tank. And just used some nuts to adjust the bolts to the height i needed it to be. And then used a piece of boxed stock to support the front of the tank. Wasn't sure if this was going to be enough support but IT IS ROCK SOLID.
Cleaned up the door panels. Both are done now and painted both sides primer.
Thanks, John
Old 03-27-2015, 07:48 PM   #34
64jmb
64jmb's Avatar
Welcome and nice truck! I have a 1962 C10 as well, here is a picture of mine! We have been working on getting all the old repaint off mine to the original Sea Mist jade paint. Were almost there too!
64jmb is offline   Reply With Quote
Old 03-28-2015, 02:24 AM   #35
Grizz1963
Grizz1963's Avatar
Builds like yours make me happy, as my son has no interest in cars, bikes or anything mechanical.
Keep up the good work, you will be the cool kid in class, even if you don't care.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
