Old 02-13-2015, 01:37 PM   #26
Bigstevex4
Bigstevex4's Avatar
Re: what exhaust are you running?
Glass pacck dumped out in front rear axle Thank God its only a 6 banger. Resonates under box bad going to extend it out back soon.
Bigstevex4 is offline   Reply With Quote
Old 02-13-2015, 03:23 PM   #27
gasmn1620
Originally Posted by homemade87 View Post
It will be loud and have drone . If you like loud that's ok . But if not you may want to call them .
I don't drive it every day and I'm ok with loud. No long distance driving. Can't be much louder than my Harley.
gasmn1620 is offline   Reply With Quote
Old 02-13-2015, 03:38 PM   #28
kevinr1970
I notice a few of you are going big pipe into muffler and then scaling down after; is there a reason for this?
Also, I have had FM's give drone, and some that didn't.
Would placement help with this?
If you had your mufflers as far back as possible, just before the pipe turns to go up and over the rear axle, so the mufflers are not directly under the cab.
I have a crew that needs exhaust and was planning on going with FM's...
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-13-2015, 03:50 PM   #29
rich weyand
rich weyand's Avatar
It won't be that loud. There will be some drone, mostly at 40 mph constant speed. I have FM 40s on my DD, and it doesn't bother me at all.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 02-13-2015, 04:17 PM   #30
gasmn1620
Just picked it up. Sounds pretty good. Quiet at idle and not super loud while driving. Sounds good.
Old 02-13-2015, 05:09 PM   #31
SCOTI
SCOTI's Avatar
Flow/sound related for me. I wanted minimal flow restrictions leaving the motor & through the mufflers. After the mufflers the exhaust pressure drops so downsizing pipe size doesn't impact flow & it helps reduce the noise level.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-13-2015, 09:02 PM   #32
77K10Silverado
77K10Silverado's Avatar
What did it cost you gasmn1620?
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 02-14-2015, 01:37 AM   #33
05duramaxhd
flows only because I already had them
05duramaxhd is offline   Reply With Quote
Old 02-14-2015, 10:32 AM   #34
mattcrp1
mattcrp1's Avatar
Originally Posted by SkinnyG View Post
Flowtech headers to 2-1/2" to cheapest generic mufflers, 2-1/4" out the back. All done with Mandrel-bent U's
No drone, Almost too quiet.
Sounds like: https://www.youtube.com/watch?v=zOHo...C0xHopIWIKsT9A
I like the way your truck sounds in the video, are those a "turbo" style muffler?
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-14-2015, 06:01 PM   #35
SkinnyG
SkinnyG's Avatar
I guess. They were the all-time cheapest mufflers my local parts house sold. They might be walkers, but I'm not sure. They are not a "performance" muffler per se, just oem replacement for something.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 02-14-2015, 08:51 PM   #36
gasmn1620
$325. True duals with turn downs right in front of the axle.
Old 02-14-2015, 09:36 PM   #37
outlaw1972
outlaw1972's Avatar
I have a mild 350 with pypes race pro mufflers with 2 1/2 in tubes running all the way out the back then turned down at the rear wheels on my 85 and they are nice sounding. No drone at all and they are nice at crusing speed, but sound mean when you get on it.
outlaw1972 is offline   Reply With Quote
Old 02-15-2015, 09:32 AM   #38
motornut
78K & 79C Jimmys
motornut's Avatar
some pics
all pipes are 2.25
mufflers on the grass are dynomax turbos (78 C Burb)
others are cherry bombs (78 K Jimmy) and Flow masters(79 C Jimmy)
the 78 K now has the turn downs after the bombs
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 02-15-2015, 06:45 PM   #39
MikeB
MikeB's Avatar
Much of the exhaust energy is given up in the mufflers, meaning a smaller pipe can be used after the mufflers with no loss of power. Very common for car and truck mfrs to do this.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 02-15-2015, 11:29 PM   #40
USSkoval
I've got two trucks with Flowmaster 40's on them. One is a big block with 3 inch pipes to the mufflers and 2.5 out, while the small block truck has 2.25 pipes. Neither drone, but I think it's just because both of them are geared fairly steep.
Surprised nobody had mentioned Hooker Aerochambers yet, I love them. They produce a very muscular sound without being too loud, especially at idle. I've run them on a 305 with 2.25 pipes as well as a 454 with 3 inch pipes that end before the axle, absolutely love them.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 02-16-2015, 03:26 PM   #41
kevinr1970
Maybe this is a subject for a different thread, but the first set of FM's I bought were put on a '70 Buick GS 350 in about '89.
They had a cool sounding idle, but when you got on it, they seemed to get quieter as the RPM went up. I thought that was part of their sales pitch too?
Now it seems they (and just about anything else I have heard?) get a raspy sound as you get into it, like glass packs?
2000 Tahoe Limited
