Old 02-17-2015, 06:49 PM   #26
Hubscrub
Cruzin
Hubscrub's Avatar
Re: What do I do with my hacked 72 cheyenne?
I was told that the late beds.needed to be raised to line up right, don't no if that's true but we need pics of the frame. Also I would get the proper paper work with another frame a title, some form of ownership to be right with dmv
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 02-17-2015, 08:11 PM   #27
Rod Run
Rod Run's Avatar
Originally Posted by esahic View Post
Okay so most everyone is saying fix the frame or buy another 67-72 frame.
So swapping the body onto the 2002 gmc would be more work then what its worth?
I have never welded anything, but it is something I want to learn how to do!
Honestly, if you've never even welded before, then you are WAY OVER YOUR HEAD in thinking about a swap from a newer vehicle.
Not what you want to hear, but the best advice isn't always the nicest you'll hear.
As others said, just get yours welded and be done with it. That's the cheapest and easiest route
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-17-2015, 10:54 PM   #28
Trixxterr
Texas= cab= title.
Trixxterr is offline   Reply With Quote
Old 02-18-2015, 01:08 PM   #29
cooperhw
cooperhw's Avatar
I would pull the bed or cab off and take it to a competent welding shop. They can cut out the bad and weld in a section of good frame from another donor and plate over everything. This is exactly how Open Road added 18" to my 68 frame to extend the wheelbase from 157" to 175". When I pulled the body off it looked as perfect as the day they welded it up after 62,000 miles. They were a factory dealer for GM so it had to be approved. What I am getting at is for probably around that $500 number someone mentioned earlier you can more than likely get your truck straightened out. Whole lot less work and effort than the other options. Just don't expect them to do it under the cab/bed with them in place.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 02-18-2015, 01:47 PM   #30
Doug's68SS
Trixxterr according to the Highway Patrolman that use to run the Vehicle theft division in Austin the Title has to Match the Frame. I was going to use my cab off my LWB on a short frame and he told me i had to have the title to the frame i used.
Doug's68SS is offline   Reply With Quote
Old 02-18-2015, 02:50 PM   #31
Mock1
Dude,
Post some pics. From both sides of the frame as best you can. Take the bed off if need.
I just gotta get out here and do it, why?
Cause nobody will do it for me...
Mock1 is offline   Reply With Quote
Old 02-18-2015, 08:10 PM   #32
boraxman
Keepin an eye out
boraxman's Avatar
So you bought it as an advertised short bed?...Did you pay short bed money for it only to find out it was a hack job?
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 02-18-2015, 09:25 PM   #33
mechanicalman
Originally Posted by 65standard View Post
I would just repair the frame on the truck.
X2, at least make an attempt. Maybe these could be used? Do you have any friends that weld? These channels may simplify the work.
http://www.cmwtrucks.com/index.php/c...long-pair.html
Last edited by mechanicalman; 02-18-2015 at 09:30 PM. Reason: I see you don't weld yet.
mechanicalman is offline   Reply With Quote
Old 02-19-2015, 03:28 AM   #34
64chevtruck
Originally Posted by 1968aj View Post
get frame welded properly then drive it like you stole it.
This,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 02-19-2015, 08:36 AM   #35
jjzepplin
jjzepplin's Avatar
I would find a good frame and be done with it. I found my 71 Blazer frame on CL for $175 and the guy delivered it to as a roller with a HD 73 front end with disc brakes and a 12 bolt rear posi. The rear was NOT a posi but I did not care. Sold the rear and some pieces from my old bent frame and it ended up paying for the new frame...Even had good steelies on it so I just bought some 73 hubcaps. Doesn't look too bad.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-21-2015, 01:03 AM   #36
crazyjeenyus
crazyjeenyus's Avatar
put it on the new frame and take advantage of all the newer technology in the suspension, brakes, etc.
crazyjeenyus is offline   Reply With Quote
Old 02-21-2015, 02:28 AM   #37
Raider Rudy
Raider Rudy's Avatar
Originally Posted by Greasey Harley View Post
I keep seeing people saying this, but it's not true in every state. If you have the titled cab on an untitled frame, there are multiple states that you can never register that vehicle in.
Some states will even impound the vehicle, pending further investigation!
It is always a good idea to document frame changes with the DMV.
This is true! The title (pink slip) should stay with the frame.The vin number on the cab is just a secondary number. The vin number on the frame is the primary number & true identity of a vehicle. In California if a vehicle has cab & frame numbers that don't match the CHP can put on another vin number (blue tag) on the frame & one on the cab to match it. The vehicle will then no longer be identified by the prior vin.
1969 Chevy Long Fleet Custom C/10 (2nd owner)
1971 Chevy Short Fleet Custom C/10 (2nd owner)
2001 Chevy Silverado Ext Cab
Raider Rudy is offline   Reply With Quote
Old 02-21-2015, 11:19 PM   #38
Hubscrub
Cruzin
Hubscrub's Avatar
of the frame
Proverbs 3:5,6
