Re: Heat sucks
From defrost to floor heat is one blend door that has nothing to do with heat, the other has to do with outside air to just from the heater core. I think thats the one Boog is referring to. Is that the one you say opperates good?
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Re: Heat sucks
Great thread......my hoses are not correct connected.
Re: Heat sucks
Sorry, I typically refer to the blend door as the one which controls the temperature. In my case the door either allows air to bypass the heater core (open on the inside of the cab), or forces air through the heater core. I have checked the operation through the inspection port and it I'd working correctly.
Old member
I still say put the inlet on bottom to take care of any air pockets.
![]() This is my old TPI motor water lines. You maybe right on the lines but I would still run the intake to bottom of heater core then top out to water pump. As I stated I have always had AC truck so I followed this drawing out of the service manual. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
Re: Heat sucks
Was the picture you posted in post #19 one of your motors as well? It has the hose connected with the inlet to the top and exit to the water pump. Last edited by clemsonteg; 02-18-2015 at 09:06 PM. |
Old member
Nope that was just one I pulled off google. I thought I had some pictures of my old 305 TPI hoses routed but I can't find them. Why do you think the heater core maybe blocked if you got a good stream of water out of it. I assume you flushed it both ways right!
You also said you have a 195* stat so that should be plenty. The hoses getting hot means the system is working. If you run the truck with the cap off try to put the front of truck on jack stand are at least jack it up to help remove the air pocket which is what I think you have. Putting cardboard in front of the radiator is fine but keep a close eye on it. Don't let it over heat. ![]()
Re: Heat sucks
Good one on the heater hose valve! That'd have been funny... Non-AC though I think.
I'm just going to throw out a couple of troubleshooting things I've run across as the years have gone by. Might help here, might help someone later, might never help! First, when you check the hoses going into and out of a heat exchanger in our vehicles you can't conclude very much. For example, in the Saskatchewan winter I had the HOT light come on. I assumed must be the thermostat was stuck shut. But the upper rad hose was plenty hot and in some cold-start-warmup testing it got hot at about the time the thermostat should open. So, with the thermostat ruled out I chased a lot of things. New water pump. Flushed block, flushed the radiator, and I don't remember all what else. But I do know it was -30F and I was working in my Dad's dirt driveway laying on cold, cold ground to do all of this. In the end, it was the thermostat. Enough hot water can get by even a significant restriction (like a stuck thermostat) to make the hoses appear like its flowing even if they aren't. In this heater core case, you can't tell a whole lot just by knowing the two hoses are hot. Also, I think it'd be hard to determine, by hand, whether the core was good by trying to detect a temperature difference between input and output. With a thermal gun (cheap now, everyone should have one) you might. But what's the right drop? Who knows? What you -could- do would be to measure the temp change with the gun with the blower off. Then on Medium. Then on High. If the core itself is allowing are to pass through it, you should see a BIGGER drop on high than medium and off. That tells you the airflow part. I'd then pull both hoses off and flush it in-place. If you have compressed air, set your regulator appropriately and, without plugging it (remember, they only live with 16psi even on a bad day) blast air through it. Protect yourself and be ready for a mess. Then you could also blast your garden hose through it to make sure its really flowing well (but a garden hose can be 150psi too). If you have access to it, a new core is good insurance anyway (but buy a quality one, or recore a Harrison original).
Re: Heat sucks
No need to mess with the radiator. Your heater core gets water before it goes to the radiator. You may have just enough buildup that you're not getting good heat transfer. If both hoses are hot you have flow so either have the core repaired by a good shop or replace it.
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
Re: Heat sucks
Thanks everyone. I flushed the heater core again tonight. Not much debris, at least not enough to cause a significant clog. I dropped all the air out of the rear bags and inflated the fronts all the way. I also jacked up the front as high as I could. I was able to squeeze another half gallon or so of 50/50 into the radiator.
I think my issue may be a compound of a few issues. I think my engine runs on the cool side, especially when it's moving with air flowing through it (see picture of my temp gauge below). I noticed with a piece of cardboard blocking the radiator that the gauge moved further than I have ever seen it, maybe to 1/3 the way between C and H (assuming the picture shows around 1/4). ![]() |
Old member
That picture shows a normal reading on a stock 307. Is it getting any hotter inside the truck?
Re: Heat sucks
Old member
You do have all the cab vents closed and any holes in the fire wall sealed up.
Both the kick panel vents need to be closed off. Driving it shouldn't make any differance unless you have a lot of holes letting in cold air. Once the truck is warmed up it should stay. Does the needle go down on the gauge once you start driving it? The gauge is motor temp not radiator temp. ![]()
#13 |
![]() Join Date: Dec 2012
Re: Heat sucks
Hmmm from which vents? The only one that should be blowing out heat is the bottom vent or the defrosters if in defrost mode.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#14 |
Re: Heat sucks
#15 |
Re: Heat sucks
ah I keep forgetting this is a NON AC truck...duh
#16 |
Re: Heat sucks
So let me get this right, no insulation, current temperature of about 25 deg, with a high of around 50 deg. First off air is a poor conductor of heat. With that said, the warm air, cause that's about all your getting at those outside air temps, is mixing with the cold steel and air contained near the floor, causing you lower extremities to feel cool, which in turn sucks the heat from your core body temperature, which eventually makes everything feel colder. I would suggest getting some type of carpet, even if it is only one of those carpet squares that have some insulation on the bottom, as a temporary measure to make things feel warmer. From reading the thread, it seems your system is working properly, but you not only have mother nature against you, but also air fighting general issues with air. Just me 2 cents.
#17 | |
Re: Heat sucks
#18 |
Re: Heat sucks
That's where my gauge reads even when hot, and a mechanical gauge reads at 190-200.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#19 |
Re: Heat sucks
5 bucks says your daily driver has insulation, which goes up the inside of the firewall, where your truck is a big hunk of cold steel with a heating system that is almost 50 years old. Put a thermometer on the floor, the seat, and the headliner and see how much of a variation in temperature there is, then do this to your daily driver. Think the results might shock you.
#20 | |
Re: Heat sucks
I have insulation on the firewall of the truck. Floors are bare since I just painted them. The plan is to put down sound deadening mat followed by insulation and carpet. I guess my main point was the heat sort of works when sitting still, but the air temperature of the heat coming from unit cools off when moving. I guess I will find out Saturday morning when I take it for a drive and determine if any of m y changes improved the situation. I don't particularly care about my comfort, but my 2 year old son loves riding in "his truck" and I want to make as many memories as I can with him. |
#21 |
laying low
![]() Join Date: Mar 2001
Re: Heat sucks
Have you checked the cowl air intake door to see if its working? It's been a long time since mine was on the road so memory is questionable on this. It is vacumn operated. That cowl door when closed will allow the fan to pull air from inside the cab to recirculate it thereby warming the cab better.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#22 | |
Re: Heat sucks
I have also read that the fan should be multi speed. I have never tried the air fan control lever in different positions, only all the way right or all the way left. Are either of those items factory installed on a non-ac truck? |
#23 |
laying low
Re: Heat sucks
Oh. I assumed you had an air cab. For sure the air cab has that cowl door but a heat only cab may not. And you definitely have a multi speed fan even on your setup.
