02-21-2015, 04:05 AM | #26 |
Re: I'm Back!
The only thing that leads me to believe that it is not is the location of the pad...if it were a V8, then I could think that a machinist machined the deck and wiped out the number, but the 292 pad is in an area that wouldn't be machined, plus the lettering looks like the GM stamps I've seen on my other V8 engines. No, I almost wonder if that "P" is for the P-Series chassis vehicles. Everything I've read up on says that the "F" means it was built in Flint.
Fred 1974 C-20 Fleetside White/Crimson Red 292/SM465 4.10:1 open 1976 AMC/Jeep CJ-5 Lime Green 258/T150 3.54:1 open 1972 C10 Suburban - SOLD White/Medium Spruce Metallic/White Avocado Highlander Pkg 402/TH400 3.08:1 open |
02-21-2015, 04:08 AM | #27 | |
Re: I'm Back!
02-21-2015, 04:17 AM | #28 |
Re: I'm Back!
Another explanation might be that the engine was replaced by the original owner. He owned an auto repair shop here in Nampa. Possibly the original engine blew and he had another on hand?
02-21-2015, 04:20 AM | #29 |
Re: I'm Back!
By the way in an earlier question you asked, I get my parts from a few places.
LMC http://www.lmctruck.com/ Classic Industries http://www.classicindustries.com/ Classic Parts http://www.classicparts.com/ I also get stuff from Summit, Ebay, Craigs List, etc. Personally I do a lot of business with Classic Parts They have some OEM stuff too.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
02-21-2015, 04:38 AM | #30 | |
Re: I'm Back!
Even though your 292 did not come with certain smog equipment like AIR injection or EGR, it still had some emissions equipment that required model year certification. A spark control system and a thermostatic air cleaner also a closed PCV system and maybe Evaporative system. But I'd have to check on that one though.
02-21-2015, 04:51 AM | #31 | |
Re: I'm Back!
What it could be is a factory crate engine. The GM Targetmaster line had a 292. But its been 30+ years and I don't remember the codes for them. The only problem with that theory is Targetmaster engines were black not Chevy orange. Yours does not look like it was ever black.
02-21-2015, 06:03 AM | #32 |
Re: I'm Back!
No it is definitely Chevy Orange.
02-21-2015, 11:04 PM | #33 |
Re: I'm Back!
Last night I was looking at eBay and came across the correct 7044026 Rochester MV. It's in need of a rebuild, so I bought a rebuild kit for it, as well as a choke pull-off and linkage.
02-22-2015, 12:26 PM | #34 |
Re: I'm Back!
Quick question...I'm trying to figure out what gear ratio I have. The Service Parts Identification decal doesn't list it. Short of popping the cover, which I really don't want to do at the moment, is there an axle code on the 14-bolt itself? If so, is there a list of axle codes somewhere? I've looked and couldn't find anything.
Thanks.
02-22-2015, 01:19 PM | #35 |
Re: I'm Back!
I did find this:
10.5-inch with case number 6258336: • The 10.5-inch 14-bolt differential, with the case number 6258336, is found is found on 1/2-ton and 3/4-ton vehicles manufactured by GM 1973 and later. This differential is available in three gear ratios: 3.42:1, 3.73:1 and 4.10:1. This differential is stock supplied on a variety of GM vehicles containing 1/2-ton and 3/4 engine designs. This differential is not restricted to specific product lines or vehicle types. 10.5-inch with case number 6258340: • The 10.5-inch 14-bolt differential, with the case number 6258340, is installed on larger 1/2-ton and 3/4-ton vehicles manufactured by GM 1973 and later. This differential is available in three gear ratios---4.56:1, 4.88:1 and 5.13:1. This differential is stock supplied on a variety of GM vehicles lines with a rear differential that turns significantly more times at the rear end than does the 4.10:1 and lower ratio line of differentials.
02-22-2015, 03:13 PM | #36 | |
Re: I'm Back!
02-22-2015, 07:33 PM | #37 |
Re: I'm Back!
What I found was "G3414" and nothing else, other than the letter J, right by the pumpkin.
02-22-2015, 07:45 PM | #38 |
Re: I'm Back!
Found it, "KJJ"
02-22-2015, 09:53 PM | #39 |
Re: I'm Back!
KJJ = 4:10 ratio with posi-track, 1978 C20
02-22-2015, 10:01 PM | #40 |
Re: I'm Back!
Just '78? Jesus, this truck is one hell of an anomaly.
02-22-2015, 10:20 PM | #41 |
Re: I'm Back!
Following!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
02-22-2015, 10:20 PM | #42 |
Re: I'm Back!
No, I only have books to 78. 78 was the first year for the code by my books. It may carry up for many years. I probably should look into getting later books ;
02-22-2015, 11:33 PM | #43 |
Re: I'm Back!
Okay, next question, I take it the G3414 is the date code? To what does it translate?
02-22-2015, 11:51 PM | #44 |
Re: I'm Back!
I can tell you what some of it means. "G" stands for the plant it was built at which is listed as "gear & Axle" which I think is the Flint Mi. plant. "341" is the actual date code. The "4" is the shift code.
02-23-2015, 12:01 AM | #45 |
Re: I'm Back!
341, is that the ordinal date? April 1st, 1973 (3/4/1) was a Sunday; January 10th 1973 (3/41) was a Saturday; Friday December 7th, 1973 (341).
02-23-2015, 12:11 AM | #46 | |
Re: I'm Back!
Also I was in my book again and found KJJ listed in 74 and 75 on a C20 but in 74 and 75 it is non posi. Sorry not sure how I missed it the first time through. I think I went back and checked 77 and then 76 saw none listed and assumed. My bad
02-23-2015, 12:33 AM | #47 |
Re: I'm Back!
I figured it wouldn't be posi, given it's such a base model truck. At least it has the SM465.
02-23-2015, 10:27 PM | #48 |
Re: I'm Back!
Sweet find! Looks like you got a good deal.
1973 K10 Super 8 http://67-72chevytrucks.com/vboard/s...d.php?t=645525 Sold 1988 S10 http://www.s10forum.com/forum/f135/p...-papaw-470214/ 2010 Nissan Frontier 4wd DD 2008 Ford Escape Limited Awd Momma's Ride 1978 C20 Farm truck Sold |
02-23-2015, 11:13 PM | #49 |
Re: I'm Back!
I went to the local pick 'n pull today, The Jalopy Jungle. Got my list of where the mid-70's Chevy/GMC trucks were, took my toolbox and went hunting. I got a coolant overflow bottle from a '77 C10, a heater control unit from a '74 C10 and a glove box liner from a '75 GMC.....$24 for the lot.
I don't know which "engineer" designed the glove box liner, but he ought to be castrated, hanged and shot. What a stupid design, guaranteed to eventually split along the seam that folds. I also found out that the '77 overflow bottle's holes only match two of the three holes on mine...the top hole is about 1" lower...everything else seems to match. It beats the brittle and cracked bottle that was on there.
02-24-2015, 12:15 AM | #50 | |
Re: I'm Back!
