Old 03-18-2015, 12:35 PM   #26
First c10
First c10's Avatar
Re: 4L60E/241C info
Here is one of the braces clinebarger talked about. I got this with my TC out of the 91 burb.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-18-2015, 12:50 PM   #27
A1971Blazer
A1971Blazer's Avatar
Re: 4L60E/241C info
Originally Posted by First c10 View Post
This is the mating surface of the TC 241c.
Is the top mount hole at 12:00 o'clock? If so I think the adapter clinebarger posted a link to will work.
The TC is scheduled to be delivered tomorrow and there were 10 of those adapters available on Ebay. I think I may be getting closer......
Also the bracket you show in the post above........is it like a torsion bracket that would go from the TC to the frame? I've got all kinds of steel material to fab brackets from if I can just figure out how it needs to be braced.
The old NP205 had a torsion mount on the right side between the TC and the frame.
BTW, thanks for all the good info.......much appreciated!
A1971Blazer is offline   Reply With Quote
Old 03-18-2015, 01:12 PM   #28
First c10
First c10's Avatar
Re: 4L60E/241C info
If you look at the trans picture I posted there is no 12 o'clock bolt hole. More like a 11 and 1 o'clock. After I rebuilt the TC i bolted it up to the 4l60e trans and factory 2008 adapter and it looked good. I can't remember what position the front drive line yoke was but looked correct when I set the 1991 burb crossmember under it.
The second picture was a bracket that went to both halfs of the TC case (Hense the 2 holes at one end) the other end went to the transmission to engine bell housing bolt. Not to the frame.
GO GO!!!
Old 03-18-2015, 01:31 PM   #29
A1971Blazer
Re: 4L60E/241C info
OK......great.......thanks! As long as the adapter mount comes parallel to the cross member it should work as long as it's clocked such that the drive shaft and all will clear.
The bracket looks like it's some kind of stiffener to perhaps offset some torque when the 4WD is engaged.....
I'm probably doing too much thinking.....just need to wait for the TC and go forward from there......
Old 03-18-2015, 02:22 PM   #30
First c10
First c10's Avatar
Re: 4L60E/241C info
The brace I think just holds the TC together with the trans/motor, as far as torque I am not sure this really would support rotational torque. More of a triangular support for the aluminum TC would be my guess.
You are probably thinking to much!!!! Sometimes you just need to get your feet wet!!!
GO GO!!!
Old 03-18-2015, 02:28 PM   #31
First c10
First c10's Avatar
Re: 4L60E/241C info
Thanks....!
I'm not sure about the picture...I put the wrong one, deleted it, then put in the correct one......who knows......?
I asked the seller to throw in the adapter....hopefully he will.....just in case it's the correct one.
Another try.......back of 4L60E tranny case
Attachment 1378496
Picture from post #18
Also I was thinking that you may need a different seal and plugs to stop the trans fluid at the transmission before it gets to the output shaft. my sons 6L80E I had to remove the seal and plugs so that I would have fluid to the tail shaft. I converted from a 4x4 trans to a 2x4 trans..
Hopefully someone has performed this conversion on a 4L60E can chime in!
I guess I can look at the tail shaft on my 4L60E at the shop.... I will try and take picture tonight
GO GO!!!
Old 03-18-2015, 02:44 PM   #32
A1971Blazer
Re: 4L60E/241C info
That was another consideration....because I'm doing the opposite....converting a 2WD to a 4WD.....I just assumed the fluid migrated into the cavity in the adapter since it has an o-ring at the tranny and a gasket at the TC mount?
Old 03-18-2015, 03:04 PM   #33
First c10
First c10's Avatar
Re: 4L60E/241C info
My 6L80E Had that same configuration(o'ring and gasket) but had a seal at the shaft and no other opening in the trans to adapter...
check this out. This is what I did!
6L80E conversion to 2wd from 4wd
GO GO!!!
Old 03-18-2015, 08:54 PM   #34
clinebarger
Re: 4L60E/241C info
No mods needed, The T-case has a seal to prevent the Trans & T-case from swapping fluid with each other. The Trans case has a drain hole to drain the fluid from the adaptor.
clinebarger is offline   Reply With Quote
Old 03-18-2015, 09:49 PM   #35
A1971Blazer
Re: 4L60E/241C info
So basically all I need to do is swap the output shaft on the 4L60E to a 4wd?
Also what mods would you recommend doing to the 4L60E while it's apart. The LS1 will remain stock and I plan on running 33" tires with 4.56 gears.
Old 03-19-2015, 01:37 AM   #36
clinebarger
Re: 4L60E/241C info
Yes, Just the output shaft.
Sonnax, Smart Shell (Reaction Sunshell), 77749-02K
Sonnax, Performance pack, HP-4L60E-01
Sonnax, Wide sungear bushing, 77010-01
Sonnax, Wide rear stator bushing, 77002BT-01
Sonnax, Front stator bushing, 35007A
Sonnax, Input drum reinforcement kit, 77733-51K
Sonnax, Front pump bushing, 77005T
Borg Warner, 29 element input sprag, 29236AM
Most true LS1 4l60E's have a "093" Corvette 2nd servo piston. If the 1-2 shift is to harsh for your liking.... Get a "159" Trailblazer SS 2nd servo.
Hi-Energy frictions for the 3-4 clutch, 7 & 8 count stack-up's work well.
Raybestos, Borg Warner, & Alto make friction modules with Hi-energy frictions.
2/4 Band... Pick your poison.
Old 03-19-2015, 08:15 AM   #37
Mjminino
Re: 4L60E/241C info
ill trade you i have a 4l60e 4x4 with transfer case and i need a 4x2 4l60e mine came from a 2001 suburban. meet half way or something i am located in Omaha Ne
Mjminino is offline   Reply With Quote
Old 03-19-2015, 08:50 AM   #38
A1971Blazer
Re: 4L60E/241C info
Thanks for the offer but mine is already disassembled and being prepped for rebuild.
Old 03-19-2015, 08:51 AM   #39
Mjminino
Re: 4L60E/241C info
dang, too bad we didn't get in touch earlier, would have saved us both time and money!
Old 03-19-2015, 09:03 AM   #40
A1971Blazer
Re: 4L60E/241C info
......story of my life.......day late, dollar short........
Old 03-19-2015, 07:46 PM   #41
A1971Blazer
Re: 4L60E/241C info
OK.....got the transfer case today......looks well used and as if it's been apart before?
Here is the adapter that was on it...700R4 early 4L60...
Looking at the adapter and bolt circle on the TC, it looks like the top hole will clock a 12:00.
That means the adapter will likely need to be.......... THIS ONE......... maybe.....?......looks like it would clock it correctly.
Old 03-19-2015, 08:24 PM   #42
clinebarger
Re: 4L60E/241C info
Looks like the stock late 4L60E adaptor will work, That will eliminate some work....Though it looks like you work in some kind of machine shop?
Old 03-19-2015, 09:02 PM   #43
A1971Blazer
Re: 4L60E/241C info
Good catch!.....I actually own a small CNC manufacturing "job shop."
It's me, my son and another guy that's been with me for 10 years. We do contract machining for industrial customers.
Pretty much just make parts to their specifications. It's a living...plus I get to buy some cool tools and stuff for me on the company's dime.
Unfortunately I stay so busy that I don't get to do as much of "fun" stuff as I would like....
Thanks again for all your advise/input......it is much appreciated......probably be looking for more before it's over....
Old 03-20-2015, 09:03 PM   #44
First c10
First c10's Avatar
Re: 4L60E/241C info
This is the part number to the 2008 TC adapter
GO GO!!!
Old 03-20-2015, 09:04 PM   #45
First c10
First c10's Avatar
Re: 4L60E/241C info
Here is a side view of my adapter install from the factory on the 4l80e.
GO GO!!!
Old 03-21-2015, 10:10 AM   #46
A1971Blazer
Re: 4L60E/241C info
OK........I ordered an adapter off Ebay that I think will work....we'll see?
Meanwhile, I did a quick teardown to look inside.......all looks good.......bearings feel good but I will probably replace them and the seals just because. Magnet had very little sludge and no big steel particles. Synchronizer looks good too. I think I did OK....
Looking at the rebuild kits......there are two different input bearings.....I needed to pull it out to measure for the correct one.
What is the tolerance for chain slack? It's been awhile since I worked on a chain drive TCs but this one seems to have a little more slack than I remember them having?
Anyway a quick trip to the bead blast cabinet and it's starting to look like new.
First.......what kind of paint did you use on yours?
I was looking for something that will stick on aluminum?
Old 03-21-2015, 11:06 AM   #47
First c10
First c10's Avatar
Re: 4L60E/241C info
Correction to my earlier post. I have a 4l60e not 80.
GO GO!!!
Old 03-21-2015, 11:11 AM   #48
First c10
First c10's Avatar
Re: 4L60E/241C info
Looking good. I used VVT engine primer and paint. I also bead blasted my case. I ordered a complete kit and changed all bearing and seals. I am not sure on the chain I can't remember what I found when I did mine but it was in good shape so I did not replace it. I wish I had taken pictures but I didn't have camera or my phone with me when I rebuilt it.
GO GO!!!
Old 03-21-2015, 01:44 PM   #49
A1971Blazer
Re: 4L60E/241C info
I was thinking when I saw that........."that looks exactly like the rear of my 4L........."
Old 03-21-2015, 02:22 PM   #50
A1971Blazer
Re: 4L60E/241C info
Now.......Do you have the front output flange or yoke? This one has the square flange.
I need to find a CV yoke for the front output. JB conver... has one that measures the same but specifies it as a rear yoke, pretty sure it would work.
I like the CV driveshafts.......much smoother.
I found a real good CV joint shaft that we cut off something. Also have a '79 F250 front shaft with a good CV.
The one on the right is the K5 factory shaft.......CV is shot.
The left one I found when I started cleaning my barn to put the lift in.
Spicer
