08-05-2015, 02:47 AM | #26 |
Re: temp gauge
I have no idea how this thread got so complex. with so much insight. hope the best of luck
08-05-2015, 11:52 AM | #27 | |||
Msgt USAF Ret
Re: temp gauge
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
08-05-2015, 12:58 PM | #28 |
Re: temp gauge
Thanks for your reply. I thought that too about the thread sealant. But my reading of 333ohms tells me the sender is working. Right? The cart temp was right in line too. Please let me know if I'm missing something here.
Posted via Mobile Device |
08-05-2015, 01:56 PM | #29 | |
Msgt USAF Ret
Re: temp gauge
Have a look at post 20 in this thread.
08-05-2015, 02:25 PM | #30 |
Re: temp gauge
I to had issues with the temp gauge on my 74 I ended up buying the correct sender unit and a new wire from lectric limited. now if I have time to get it installed.
08-05-2015, 05:26 PM | #31 |
Re: temp gauge
Does anyone know what the ohms reading of the correct sender to have a stock gauge read in the 190 degrees range?
08-05-2015, 06:24 PM | #32 | |
Re: temp gauge
1970 CST long bed Fleetside |
08-05-2015, 06:49 PM | #33 | |
Re: temp gauge
08-05-2015, 08:47 PM | #34 |
Hey, thanks moon. That's the chart I found and was referring to in my original post. Which is why I'm still questioning my sender being bad. I get 333ohms after a nice little drive. So according to the chart the sender is telling the gauge to "display" somewhere in the 180 degrees F area. Thanks guys for your patience haha
08-05-2015, 09:14 PM | #35 |
Re: temp gauge
Phil, where are you taking your resistance measurement? If from the sender there could be resistance in the wiring to the gauge. Either way look for more resistance from where you are taking your reading and to the gauge itself. If you are taking it from the gauge then maybe it is time for a new one.
Brad 72 Blazer CST 350/350/205 |
08-05-2015, 09:23 PM | #36 |
Re: temp gauge
I'm taking it from the nail head on the sender to ground. You bring up a great point about the wire adding resistance. Gives me something else to look into. Thank you!
