Old 04-30-2015, 10:52 PM   #26
naphtali5725
naphtali5725's Avatar
Re: Rebuilding ol' whitey
looking good!
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 05-06-2015, 10:25 PM   #27
CodyWorks
So, today I bought oil and a filter and an oil pan gasket. Gonna drop the oil pan this week and see what kind of main I'm working with here. I'm not sure if this is the factory motor or not. I think I remember reading that the factory 350's in this truck was a 2 bolt main, but I could be wrong. Also gonna clean up the oil pan while I've got it out. Pictures to come.
CodyWorks is offline   Reply With Quote
Old 05-22-2015, 09:57 PM   #28
CodyWorks
Couple of updates. I was able to get the oil pan dropped and turns out I have a 2 bolt main. Kinda sucks but it's ok. It'll work for now. Got the oil pan reinstalled. Oil changed as planned. We decided to try our hand at polishing aluminum while I had the shroud off of the bottom of the tranny. Maybe its called a torque converter cover? Any way, pics to prove it!
My buddy getting bolts started on the pan.
Torque converter looks almost new. I was told by the PO that he had the tranny rebuilt.
The bottom end.
The oil pan was surprisingly clean for a 78. I'm guessing the motor has had some work.
The the oil pan cleaned up and back in. No leaks so far!!!
Here were sanding the tranny shroud w/ 1000 grit and then 1500 grit.
Here is after a few hours of sanding and polishing. Also, a pic of the inside as the inside looks like what the outside started as.
Here is the part number to the shroud in case anyone needs it.
Also, the shroud has a 7 cast on the bottom... Anyone know what this means?
Old 05-22-2015, 10:03 PM   #29
CodyWorks
SEAT BELTS!!! I got my seat belts in. They're not original GM equipment but they're what I can afford for now. I had to build some brackets to mount them to the floor and I didn't document it all very well but I've only done the driver side. I'll document the pass. side mo better. Here's a few pics.
Also, these are in rough shape. they're free if anyone wants them for some reason.
Old 05-22-2015, 10:51 PM   #30
77K10Silverado
77K10Silverado's Avatar
Good work son!
Mike B.
77 K10 - http://67-72chevytrucks.com/vboard/s...=1#post6752641
77K10Silverado is offline   Reply With Quote
Old 05-22-2015, 10:53 PM   #31
CodyWorks
Originally Posted by 77K10Silverado View Post
Good work son!
Thanks. Slow but steady. Bought new U-joints for her today. Gonna put those in this coming week. Wednesday maybe??
Old 06-07-2015, 12:17 PM   #32
CodyWorks
Can anyone recommend a good exhaust kit for theseveral trucks? I don't have the pipe bender needed to build my own.
Old 11-13-2015, 01:41 PM   #33
Matt Man
Matt Man's Avatar
Any updates?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
1987, 350, 4x4, sbc, tbi
