Old 05-04-2015, 06:30 PM   #26
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Re: is 600 cfm carb on a 400 SBC to small?
Originally Posted by justin4260 View Post
ok so i found out that i have on the passenger side the heads that are prone to cracking and on the driver side i have a corvette head. so thats one of the reasons its running like crap
either the head cracked or i blew a head gasket...either way next thing I'm doing is new heads and gaskets. any suggestions for some nice but still cheap heads that will be a just for now until i can afford the $1500 heads? and best gaskets for the money
350 heads will not work on a 400 CID there are extra water jackets in the 400 heads.
Felpro Perma torque gaskets are good gaskets.
fwiw... if you need 1500 for heads, forget that and buy a crate engine
good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 05-04-2015, 08:15 PM   #27
DonnieB
350 head will absolutely work on a 400, done it several times. You can drill the steam holes and be good to go! If you want to save money and still get some performance look for a set of dart iron eagles or even some old 461 camel hump heads.
'70 2wd swb, 406 sbc, air ride and a big smile on my face!
DonnieB is offline   Reply With Quote
Old 05-04-2015, 09:38 PM   #28
gonnuts
gonnuts's Avatar
I would suggests looking for set of Vortec heads & drill steam holes, you won't be disappointed I love mine. Should be able to find used set for fairly cheap.
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
