04-24-2015, 12:33 PM | #26 | |
Re: What carburetor came with my '77 K20 Camper Special?
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt. 1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt. |
04-24-2015, 01:24 PM | #27 |
Look here for choke stove parts.
http://quadrajetparts.com/ |
04-24-2015, 02:04 PM | #28 |
A little late, but does anyone see any reason why the carb I bought on eBay might not work?
I just matched the model number, saw that the seller has largely very good feedback and appears to be in the carburetor business. Anything it's missing I will need to get the truck going in original stock configuration, including the factory cruise control? |
04-24-2015, 03:00 PM | #29 |
Sure it'll work!!
You'll still need a long stud for the cruise to hook up. And hopefully you have the right intake for a choke stove. Do you have a better pic of the intake on the passenger side below the carb? |
04-24-2015, 08:10 PM | #30 |
The seller of the carb found this stud and said it was the correct part. I've ordered it too.
Couple of more pics of the passenger side exhause manifold and carb: |
04-24-2015, 09:03 PM | #31 |
Nice pics but we need to see right on the intake below the black cap on the choke.
It's possible you have a hot air choke manifold and not a divorced choke manifold. Your new carb may or may not work choke wise. |
04-24-2015, 09:53 PM | #32 |
I'm not exactly certain what you're requesting but I'll take a whole bunch of pics and post them up.
04-24-2015, 10:07 PM | #33 |
04-24-2015, 10:21 PM | #34 |
Looks like you have the pad for a choke stove. It's right between the two intake bolts.
04-24-2015, 10:38 PM | #35 |
Purchased carb ok or no?
04-24-2015, 11:05 PM | #36 |
From what I can see.
In this link post #5 shows a hot air choke and post #15 shows a divorced choke. Looks like yours has the divorced choke pad. http://67-72chevytrucks.com/vboard/s...d.php?t=585035 If your carb looks like the one in post #15 you should be good. |
04-25-2015, 12:29 PM | #37 |
I just had a thought.
Since the transmission isn't the TH400 that originally came with the truck, I wondering if the engine isn't the original 400. Where are the numbers I check, andwhat should they be? |
04-25-2015, 12:46 PM | #38 |
The engine code will be on a pad in front of the right head. Where the head sits on the deck of the block.
For you the engine should be: Light duty 3/4 is a TLS Heavy duty 3/4 is a TLM
04-25-2015, 01:15 PM | #39 | |
http://www.mortec.com/ There's a link to find where to look and links to figure out what the numbers mean. |
04-25-2015, 02:07 PM | #40 |
Man, I really appreciate all your help.
04-25-2015, 02:08 PM | #41 |
Is the pad facing the firewall or the passenger side?
04-25-2015, 03:03 PM | #42 |
Right in front of the passenger side head!
http://www.mortec.com/locatpg2.htm |
04-25-2015, 03:25 PM | #43 |
front of engine passenger side between the alternator and water pump. Nothing should need to be removed to see it, except grease.
If it is not one of the two I posted, post up the 3 letter code you find and I can see if I can narrow it down
04-30-2015, 12:27 PM | #44 |
Nice truck!
05-06-2015, 11:02 AM | #45 |
http://www.73-87chevytrucks.com/tech...se_Control.pdf
Troubleshooting guide for Cruisemaster cruise control |
05-12-2015, 04:11 AM | #46 |
Anyone know of a source for the diaphragm thing (I think it's called a servo) and the chain/cable drive for the Cruisematic system?
05-12-2015, 11:35 AM | #47 |
Anyone?
05-12-2015, 04:05 PM | #48 |
I believe this is the servo, fairly rare and pricey
http://ec2-107-20-252-117.compute-1....com/item/2312/ Your truck is awesome by the way |
05-12-2015, 04:38 PM | #49 | ||
Thanks! |
05-12-2015, 04:44 PM | #50 |
GM 6494922 part for servo
