Old 05-28-2015, 07:55 PM   #26
jjzepplin
jjzepplin's Avatar
Re: ECE Front Sway Bar Fitting Issues 71 C10
Still looks wrong. Return it and try elsewhere.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-28-2015, 08:00 PM   #27
Paul V
That's the issue, shipping it back to them is going to cost more than i paid for the bar!
I agree it looks wrong to, i have the correct year truck, i am fitting it correctly, but still it is not working.
1971 C10 Short Bed Fleet Side
1990 Ferrari 348TB
2005 Ferrari F430
Too many 2 Stroke Motorcycles To List !
Paul V is offline   Reply With Quote
Old 07-14-2015, 11:01 AM   #28
Coursey
Coursey's Avatar
Sorry i just seen where you had posted on my thread.
Did you get this resolved?
Coursey is offline   Reply With Quote
Old 07-15-2015, 10:46 AM   #29
Paul V
Hi there, yes still have the issue with the front sway bar.
ECE said there new stock that had in was they same as they sent me but could not provide me with a photo or a drawing to compare with what they have sent me.
I have moved on to the rear suspension as i have sort of stalled on the front end because of the problem.
How did you get on with yours ?
1990 Ferrari 348TB
2005 Ferrari F430
Old 07-15-2015, 11:12 AM   #30
chevy_mike
Never Ending Projects
chevy_mike's Avatar
One thing I am noticing in those two pics is your A-arms don't have as much vertical area on the front of the arm and kind of rolls up to the flat area on top. If you look at the ECE pic, it has a much larger area that has a squared rolled edge. Looking at things now, my guess is the bottom part of the bushing is not sitting flush to the arm all the way around. This extra space under the bushing is allowing it to rock and push itself out.
Definitely the arms are not made the same a stock.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-15-2015, 11:16 AM   #31
jjzepplin
jjzepplin's Avatar
Just went and looked at my bar and yours appears to be missing a bend. That would explain why mine comes 3" off the ground and yours does not. Yours seems to go into the bushing at the wrong angle.
Old 07-15-2015, 11:19 AM   #32
Paul V
To be honest that was going to be my next move, i am going to make some spacers up to fit between the arm and the underside of the bush. This would lessen the angle and also give a flat surface for the bush to sit on.
1990 Ferrari 348TB
2005 Ferrari F430
Old 07-15-2015, 11:31 AM   #33
Paul V
This is what i have been saying to ECE that is it bent wrong, it is bent wrong to the one fitted to there truck in there showroom but they say that is years old and they are all like the one i have now.
Is your arm a ECE one ?
1990 Ferrari 348TB
2005 Ferrari F430
Old 07-15-2015, 01:53 PM   #34
Coursey
Coursey's Avatar
http://67-72chevytrucks.com/vboard/s...=656258&page=2
Look at post #36.
This is how it needs to be installed.
Old 10-03-2015, 05:27 AM   #35
jjzepplin
jjzepplin's Avatar
I had a thought yesterday while cursing out my electronic fan controller.
What if you did the caster mod?
Or is that built into your control arms?
If your arms are not stock that might be why stock sway bars do not fit.
Old 10-03-2015, 04:02 PM   #36
Paul V
Thanks for thinking about me
Not sure what the caster mod is ?
The arms are stock replacement arms from CCP as someone had welded the bushes into my old ones, i stupidly put them in the bin when the new ones arrived so could not compare them.
I have made some angled spacers to do 2 things,
  1. Make the contact point flat where the brackets fit
  2. Make it a better angel for the sway bar
Here is the spacers
I have fitted them and it has fixed the problem
1990 Ferrari 348TB
2005 Ferrari F430
Old 10-03-2015, 08:17 PM   #37
jjzepplin
jjzepplin's Avatar
That's fancy.
Here's the mod= http://67-72chevytrucks.com/vboard/s...ght=caster+mod
