#26 |
Re: 62 c/10 engine swap
Is the jeep shaft something you can buy from a parts store or have to buy another trans to rob from?
#27 | |
LINK for one on eBay.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#28 |
Looking at the pics, the only difference I see is the spline count. Would it not still have to be cut or use the adapter plate. The length looks the same as the s10.
#29 | |
I'm doing this swap for a customer and will document it with photos.
#30 |
3/8 off the tip and nothing done to splines? That sounds easy enough. How about driveshaft. Shortened? How about yoke for u joints
#31 | |
Proshaft Turbo 350 / 700R4 / T5 yoke. Manufacturer Part Number: PS2-3-6081X Drive shaft needs to be shortened too and new U-joints put in to match the yoke. Cross member for the tail shaft is always something people argue about. I have my ideas but will share them another time. I know a lot of people who don't use one if their bell housing is mounted to a cross member.
#32 |
Thank you sir. Some great info that will definatly be put to use. If I get up around Columbia,I'll let you know.
#33 | |
#34 | |
Post Whore
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#35 |
One more question on the T5. Do the shaft modifications need to be done to the trans if you go behind the small block?
#36 | |
If you find a V8 Camaro/Firebird T5, then the shaft is the correct length already. A V6 Camaro/Firebird T5 with 14 splines will work well too. All it needs is 3/8" cut off. If you go shopping for a T5, make sure it has a Muncie bolt pattern. You can see more info including a list of things to look for and inspect before the purchase on my website. You have my phone number so feel free to call if you have more questions.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 04-28-2015 at 07:57 AM. |
#37 |
Thank you sir.
#38 | |
![]() Join Date: Nov 2013
Thanks!
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 Last edited by 53Sparky; 04-28-2015 at 09:17 AM. Reason: photo didn't post the way I wanted |
#39 | |
#40 | |
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 |
#41 |
Just a heads up... I removed my low hump for high one with tko 600 and PORTERBUILT clip. If you need a bolt in that was cut for many reasons and fabed up for T5 I have a bolt on one. I did raise mine in middle to clear and fill three speed hole cut by others.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#42 | |
Your TKO 600 has a different profile than a T5, so I think you are just saying that you switched to high hump for that reason, right? Very nice of you to offer your low hump to those in need. You used that low hump when you had a T5 in your truck and it was fine, right?
#43 |
After a lot of consideration, when I get to that point, I will be going small block with a T5 behind it. Got motor stands on the way. On the lookout for the right T5 now. This truck has hydraulic clutch and would like to keep it that way. So my question is what is best option on bell housing. I'm thinking if I can find a T5 in a v8 camaro along with the bell housing ,then all I would need is to add a rear cross member,am I correct?
#44 | |
Any T5 you buy should bolt right up just fine as long as it has a Muncie pattern case. A Camaro V8 T5 (either WC or NWC) is a good choice but I recommend calculating your RPMs at cruising speed. If you have a 3.73 rear diff then the 0.63 OD in most WC Camaro V8 T5s might not be as good of a choice as the 0.73 OD gear in a V6 Camaro T5. Some of the earlier V8 Camaro T5s have a 0.73 OD but they are getting scarce. Also keep in mind that in order to stay with your cable speedometer, you'll need to find an S10 tail stock from 1988 or earlier. Those are the ones with a cable connection. All Camaro T5s have a cable speedo connection on the tail stock. If you keep the Camaro tail stock, then the shifter will come up under the bench seat which means you'd have to swap to bucket seats. You should have my ph# just in case you wanna go over the options. They get kinda twisted and can become confusing. But what you want is very do-able.
#45 |
I have read the 235 bell housing wouldn't bolt to the small block.
#46 |
You may be right. I have no experience with the 235 bell. Got any pics?
#47 |
No, its still bolted in the truck. From all I've read, the 235 has a bolt pattern of its own. The later 250 will bolt to small block.
#48 |
Post Whore
Guy on youtube has a 55 chevy with a 235 and he said his pretty much bolted right up with minor mods.
https://www.youtube.com/watch?v=vf3TV8zsCFk
#49 | ||
He's not worried about bolting a T5 to a 235 bell. He thinks he can't bolt a 235 bell to a SBC engine. Thus he'll probably need to find a new bell. One that will bolt to a SBC AND allow him to keep his hydraulic clutch system.
#50 |
The only thing I will add to this is that I went through 2 used T5's before giving up and buying a rebuild from a local trans shop. Each one lasted only a few months before something would break. Buying a rebuild was the Best thing I ever did, it's been running strong for 2 years now and no problems.
Oh and make sure you get the V8 T5, and not the V6 T5. Some the junk yards around here tried to pawn off a V6 T5 as the V8 version.
1963 Chevrolet C10 Stepside 1972 Pontiac GTO 1998 Dodge Viper GTS 1999 Jeep Cherokee XJ 2018 Chevy Camaro ZL1-1LE It's never too early to beef up my obituary |
