Old 05-18-2015, 05:52 PM   #26
68 short step
Re: my twin turbo sleeper nova
Originally Posted by Zoomin View Post
You got my Good Lord Award on this one.
Very cool.
thanks
Originally Posted by Advanced Design View Post
Really awesome work!
thank you..
68 short step is offline   Reply With Quote
Old 05-18-2015, 05:55 PM   #27
68 short step
welp, with the hot side off getting coated, I turned my attention to the cold side. first thing was to mount the intercooler.
because im going for that sleeper look, I definitely want to hide it behind the grille and keep it looking "stockish"... so off comes the front grille assy, again, and then I placed the IC in the location I wanted...so the hood latch assy. was the determining factor on how high I could mount the IC (I don't want to do hood pins), so I had to modify the latch assy..first thing I did was remove the center grille bracket (drilled out a couple of rivets), then I cut the 'pull' to open the hood off, shortened it, did a slight rebending, and welded it to the latch assy. effectively just moving my hood pull up about 6"...and finally painted it again.
Old 05-18-2015, 05:55 PM   #28
68 short step
here is a couple of pics of the IC. its a 12"x30"x3".. in these pics its just sitting on the front subframe cross bar, so I could verify my modified latch assy, would clear it...
Old 05-19-2015, 06:16 PM   #29
68 short step
ok, got the intercooler mounted, the front cross member of the subframe was in the perfect spot for mounting the IC. so I drilled a couple of 1" holes from the bottom, then mounted some studs in the IC, and bolted it down.
once it was bolted down, I trimmed my lower filler panel to fit around the IC, I'm sure it'll get trimmed on more, once I run the cold side piping, but here is how it is now. then finally, I had to remove the lower 1" aluminum lip of the grille to give me clearance from the IC.
Old 05-20-2015, 02:52 PM   #30
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work! I'm sure it'll be getting real filled up in there once you get the piping built!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-22-2015, 01:24 PM   #31
NONHOG
NONHOG's Avatar
Originally Posted by 68 short step View Post
yes it is a 4 door 'ol grandma car'
Now a "really cool" "Ol grandma car" .
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 05-22-2015, 06:06 PM   #32
68 short step
thank you
Old 05-23-2015, 08:48 AM   #33
EZ SPEED
EZ SPEED's Avatar
awesome build..im in
Eric
1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509
2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq
2016 Camaro SS - Satin Pearl Nero wrap
My 2010 Camaro SS Magazine feature (SOLD)
http://www.superchevy.com/features/g...of-perfection/
EZ SPEED is offline   Reply With Quote
Old 05-23-2015, 10:46 AM   #34
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Nice build so far bud
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-30-2015, 11:56 AM   #35
68 short step
so with that center piece removed from the grille assy., it tied my hood latch assy., grille, and lower filler piece together, and since I no longer have that, I needed to add rigidity back to all them again, and tie my IC into the mix too. so my simple solution was to make a cross bar on the IC, and have a stand off connecting to my hood latch assy. (my hood latch assy. also attaches to the grille, so it stiffens everything up more so then the factory center bracket that I had to do away with)
Old 05-30-2015, 11:57 AM   #36
68 short step
And got exhaust hotside back from coaters, here are a few teaser pics
Old 05-31-2015, 12:22 AM   #37
tommys72
tommys72's Avatar
Exhaust looks great, nice and shiny
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 05-31-2015, 09:30 AM   #38
Advanced Design
Advanced Design's Avatar
Does look good. Who did the coating?
Advanced Design is offline   Reply With Quote
Old 06-02-2015, 07:26 PM   #39
68 short step
Thompson metal coating, in Owasso ok. really nice job he did..
Old 06-02-2015, 08:55 PM   #40
Dieselwrencher
Those hot side pieces look great!
Ryan
Old 06-07-2015, 08:10 PM   #41
68 short step
thank you, they did turn out real nice...and here are a few reassembly pics of the turbos getting put back together
Old 06-07-2015, 08:11 PM   #42
68 short step
also got the headers, turbos, and downpipes installed. before I installed the down pipes, I had to transfer over my O2 sensors and install my wideband..
Old 06-08-2015, 07:24 PM   #43
Dieselwrencher
Very nice! Those oil drains are sweet!
Ryan
Old 06-09-2015, 10:32 AM   #44
Advanced Design
Nicely packaged! Looks really good. Curious, do you do this fab work as a day job too? You are really talented on this.
Old 06-09-2015, 05:53 PM   #45
68 short step
ya, those oil drains are pretty cool I thought too...
no, im a aircraft mechanic as my day job... car builder by night
Old 06-12-2015, 08:55 PM   #46
68 short step
for the oil feed, I tapped off the rear, top, of block (same location as stock oil sending unit).... I bent up some 1/4" stainless steel hardline, then ' T ' it off, to feed both turbos...for the drain, I used -10 AN fittings and braided SS hose. I drilled and tapped the oil pan to accept the fittings..
Old 06-12-2015, 08:55 PM   #47
68 short step
while I had the intake manifold off, routing my oil feed line under it. I changed out my stock 85mm TB to a 102mm TB (see pic below for comparison, the 102is a big'un) . to do this required some porting of the intake manifold, but once I had manifold ported, it worked out nicely.....then I painted the TB,and re-assembled everything...
Old 06-13-2015, 11:39 PM   #48
tommys72
tommys72's Avatar
Looking good! I'm still following
Old 06-14-2015, 07:48 AM   #49
Willowrun
Willowrun's Avatar
Very impressive!
Old 06-15-2015, 10:04 PM   #50
Dieselwrencher
Great work! The SS line looks like it bent nicely too!
Ryan
